BartekWSH 1 Opublikowano 15 Lutego 2013 Udostępnij Opublikowano 15 Lutego 2013 Witam, czy z wymienionych poniżej kodów, można odczytac jaką skórę posiada auto ? a dokładnie, czy jest to skóra naturalna i jaki kolor ? 1 0CS L AED vehicle class differentiation 8E0 2 0F3 L KRS fuel system for diesel engine 3 0G1 L GES gearshift lever 4 0GE L AGM emissions concept EU 3 5 0JH L GKV weight category front axle weight range 8 6 0LW L SIZ special plates/stickers/ safety certificates for Germany 7 0TD E ZFM front and rear floor mats 8 0VC L BTA information kit in German 9 0W1 L AKZ label for central electric German-speaking countries 10 0YJ L GKH weight category rear axle weight range 9 11 1BA L DAE standard suspension/shock absorption 12 1C1 L FRO antifreeze up to -25 degree celsius tolerance up to -30 degree C 13 1D0 L AHV without towing attachment 14 1EX L TYP special identification plate for EC 15 1G3 E RER alloy spare wheel with original equipment tires 16 1KD L BAH disc brakes, rear 17 1LB L BAV disc brakes, front 18 1N1 L LEN power steering 19 1PA L ABR standard wheel bolts 20 1S7 L BOW tool kit and aluminum jack 21 1SA L TWU without additional engine guard 22 1T3 L VBK First aid kit with warning triangle 23 1VG L TWL installation parts for four-cylinder engine 24 1W0 L KBX without refrigerator/glove compartment cooling system 25 1WG L GFW transmission shaft w/ 88mm in diameter 26 1X0 L ATA front wheel drive 27 1YA L GFH without transmission shafts f. rear axle 28 1Z0 L KRM initial standard fuel filling 29 2A4 P UEA delivery equipment for shipment (transitcoating) with thick seat cover 30 2G0 L EBB without insert for the filling up of fuel 31 2K1 L SFS reinforced bumpers 32 2KR L SAU labels/plates in English and German 33 2PV P LRA leather trimmed sports steering wheel 34 2T0 L DAT without double-sized standard (DIN) 35 2V1 L FRI dust and pollen filter 36 2WA L ZBR without additional tires 37 2Z1 L TYZ type sign at rear and "Quattro" nameplates respectively 38 3B9 P ZKV child seat anchor for child seat system ISOFIX front and rear 39 3C7 P SHM 3-point seat belt for center rear seat 40 3CA L TRW without partition 41 3FA L DEI without roof insert (standard roof) 42 3L3 L SIE manual height adjustment for front seats 43 3NZ E HIS rear seat bench unsplit, backrest split folding 44 3Q6 P KOH three rear headrests 45 3S0 L DAR without roof rails/roof load rack 46 3X0 L DLS without load-through provision 47 3Y0 L SSR without roll-up sun screen 48 4A4 P SIH seat heater for front and rear seats separately controlled 49 4E0 L SDH tailgate/trunk lid unlocking from outside 50 4GH L WSS windshield tinted with windshield sunshield 51 4K4 L TKV radio remote controlled central locking operated from inside and separate trunk release 52 4KC L SSH side and rear windows tinted 53 4L2 L IRS dipping breakaway inside rear view mirror 54 4N0 L INT standard dashboard 55 4P2 L PBH rear floor panel module, type 3 56 4R4 E FEH power windows with comfort operation andcircuit breaker 57 4UF P AIB driver's and front passenger airbag with front passenger airbag deactivation 58 4W0 L KBO without cassette and CD storage unit 59 4X4 E SAB side airbag, front and rear with curtain airbag 60 4ZE L ZIE black moldings 61 5C0 L KSA without special body measures 62 5D1 L TRF carrier frequency 433.92 MHz 63 5K1 L LAC paint preservative (wax) 64 5MG E EIH decorative burr walnut inserts 65 5RU L ASR outer right rear view mirror: convex (large viewing field) 66 5SL L ASL outer left rear view mirror: non-spherical 67 6E3 E MAS center armrest front 68 6M0 L GPS without tie down straps/luggage net 69 6PC P HBV leatherette hand brake lever handle 70 6Q2 P SAG leather gearshift knob/handle 71 6R2 P SHV leather gearshift boot 72 6SS L KBB luggage compartment floor covering 73 6U0 L ZTD without additional seals outside 74 6V1 L HEB rear trim panel (ECE) 75 6W5 L KZV front license plate bracket 76 6XC L ASE outer rear view mirrors: powered 77 7A2 E CDW CD changer 78 7AA L EDW electronic vehicle immobilization device 79 7B0 L STD without socket 80 7CA L AKF without label for radio remote control 81 7K0 L RDK without tire pressure warning light 82 7M0 L EIL plastic scuff plates in door apertures 83 7P0 L LOR without lumbar support in front and rear seats 84 7Q0 L NAV without navigation device 85 7QA L CDR without CD ROM 86 7X0 L EPH without park distance control 87 8GU L GEN alternator 140A 88 8JH L HSW ellipsoidal headlight for driving on the right 89 8K0 L FLS without special low beam mode 90 8KA L KUE w/o catalytic converter warning light 91 8N4 L SWS windshield wiper intermittent control with potentiometer (four speeds) 92 8Q1 L LWR headlight-range adjustment 93 8T0 L GRA without cruise control system (CCS) 94 8TC L NEL rear fog light for driving on the right 95 8UD E RAO radio "concert" 96 8X0 L SWR without headlight washer system 97 8Z5 L MKU engine cooling system, type 1 98 9AK L HKA "Climatronic" with impact pressure control free of cfc 99 9M0 L ZUH without auxiliary/parking heater 100 9NX L FAS without electronic logbook 101 9P0 L SGK without seat belt warning light 102 9Q3 L MFA multi-function indicator, without on-board computer and check control 103 9T0 L BWD without heated washer nozzles 104 9VD E LSE speaker (active) 105 9W0 L VTV w/o car phone preparation/installation 106 A00 L SAH no self-collection 107 A8S I AUS standard equipment 108 B0A L BLB component parts set without country-specific design requirement 109 B99 L TPL type approval EC 110 C01 E COC operating permit, alteration 1 111 C1W L RAD forged alloy wheels 7J x 15 type 1, offset 39 112 D3E L MOT 4-cyl. turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system, EU 3base engine is T9J 113 E0A L AAU no special edition 114 F0A L FZS no special purpose vehicle, standard equipment 115 FA0 L SVO control of standard production 116 FC0 L IND without customized installation 117 FM0 L MDS basic equipment variant 118 G0C I GSP 5-speed manual transmission 119 H6S L REI tires 195/65 R 15 V 120 J0R L BAT battery 380 A (80 Ah) 121 K8B I KAR notchback 122 L0L L LEA left-hand drive vehicle 123 N1H P SIB leather seat covering 124 P16 G leather-covered sports steering wheel, three spokes 125 PID G ISOFIX child's seat mounting for passenger seat 126 PKA G centre head restraint at the rear 127 PLD G Buffalino leather 128 PSH G seat heating for the front and rear seats 129 Q1A L VOS standard front seats 130 QE0 L ALG without tray areas package/box 131 QH0 L SPR without voice control 132 QQ0 L LCP without add. lights (interior lighting) 133 QV0 L TVE w/o TV reception/digital radio reception 134 SA7 E SNR inventory control model 2 135 T9J I GMO 4-cylinder diesel engine 1.9 L unit 038.K 136 U1A L INS instrument insert with km/h speedometer,clock, tachometer and trip odometer 137 V0A L REL tires w/o specification of tire brand 138 VB0 L ADR without automatic distance control 139 VC0 L GRT w/o remote-controlled garage door opener 140 VR0 L RAM without impact protection measures 141 X0A G national sales program Germany Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
marcin303 0 Opublikowano 17 Lutego 2013 Udostępnij Opublikowano 17 Lutego 2013 Pozycja 127. Czy skóra jest naturalna tego nie wiem ale kolorek taki: eBay | NEW AUDI A6 C5 REAR PLATINUM BUFFALINO LEATHER HEADREST COVER 4B0 885 921 T 4D6 Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Dranek 1 Opublikowano 17 Lutego 2013 Udostępnij Opublikowano 17 Lutego 2013 Skóra pewnie naturalna, w B6 eko skóry nie było Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
BartekWSH 1 Opublikowano 17 Lutego 2013 Autor Udostępnij Opublikowano 17 Lutego 2013 Dzięki Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
eskey90 0 Opublikowano 27 Lutego 2013 Udostępnij Opublikowano 27 Lutego 2013 wiam mam pytanie. mam fotele s-line polskora. chwieja mi sie bo sa wyrobione tulejki i moje pytanie czy bedzie pasowal szkielet z fotela soul o takich samych opcjach. czyli elektryczne ledzwie wysuwany przod i dwie raczki pod fotelem? Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
