[ALL B5] Kody wyposażenia - prośba o przetłumaczenie
dominiks18
nie ktore wiem co oznaczaj ale nie wszystkie
X4C = national sales program Italy
B0A = component parts set without country-specific design requirement
C1L = cast alloy wheels 7J x 16 five-arm style, offset 45
G0G = five-speed manual transmission for four-wheel drive vehicle
H6U = tires 205/55 R 16 91W
JIP = code not found :-(
M9L = 4-cylinder gasoline engine 1.8 L/110 kW 20V turbo, MVEG 2, base engine is T8B/T8C
Q1A = standard front seats
1AH = electronic differential lock (EDL)
1G3 = alloy spare wheel with original equipment tires
2PG = steering wheel
5RD = outer right rear view mirror: convex, powered, heated, electrically foldable
3BK = outer left rear view mirror: flat, powered, heated, electrically foldable
T8B = components for, base engine, unit 058.D
3S0 = without roof rails/roof load rack
4UE = airbag for driver and front seat passenger
0G1 = gearshift lever
8AV = without radio, with loudspeaker connections
8GD = alternator 90A
8RE = four loudspeakers (passive)
1LB = disc brakes, front
3FA = without roof insert (standard roof)
1BA = standard suspension/shock absorption
Odnośnik do komentarza
Udostępnij na innych stronach
X4C = national sales program Italy wersja przeznaczona na włochy
B0A = component parts set without country-specific design requirement części składowe ustawione bez planu do wyboru wg. specyfikacji krajowej
C1L = cast alloy wheels 7J x 16 five-arm style, offset 45 fefgi z lekkich stopów 7cali szerokie; 16"
G0G = five-speed manual transmission for four-wheel drive vehicle 5 biegowa skrzynia do auta napędzanego na 4 koła
H6U = tires 205/55 R 16 91W rozmiar opon
M9L = 4-cylinder gasoline engine 1.8 L/110 kW 20V turbo, MVEG 2, base engine is T8B/T8C opis - model silnika
Q1A = standard front seats - standardowe przednie fotele
1AH = electronic differential lock (EDL) elektroniczna blokada dyferencjału
1G3 = alloy spare wheel with original equipment tires zapasowe koło ze stopów
2PG = steering wheel - kierownica ??
5RD = outer right rear view mirror: convex, powered, heated, electrically foldable zewnętrzne prawe lusterko wypukłe podgrzewane i sterowane elektrycznie
3BK = outer left rear view mirror: flat, powered, heated, electrically foldable zewnętrzne lewe lusterko wypukłe podgrzewane i sterowane elektrycznie
3S0 = without roof rails/roof load rack dach bez szyny załadunkowej - bez relingów??
4UE = airbag for driver and front seat passenger poduszka dla kierowcy i pasażera z przodu
0G1 = gearshift lever dzwignia zmiany biegów
8AV = without radio, with loudspeaker connections bez radia, z głośnikami
8GD = alternator 90A wiadomo
8RE = four loudspeakers (passive) 4 pasywne głośniki
1LB = disc brakes, front tarcze hamulcowe z przodu
3FA = without roof insert (standard roof) bez wkładki dachu - standardowy dach
1BA = standard suspension/shock absorption standardowe zawieszenie
foldable = składane
chodzi tu o te elektryczne lusterka, będziesz miał trochę inny 'dzyngiel' w sterowaniu lusterkami (była już na ten temat dyskusja na forum)
też bym poprosił chętnego mającego troszkę czasu :wink:
E0A = no special edition
1KD = disc brakes, rear
F0A = no special purpose vehicle, standard equipment
T1R = components for, base engine, unit 028.R
1MR = leather steering wheel
7G0 = without humidity sensor
3L3 = manual height adjustment for front seats
1SA = without additional engine guard
J0R = battery 380 A (80 Ah)
0L2 = electric throttle actuation
3NZ = rear seat bench unsplit, backrest split folding
C8N = alloy wheels 6J x 15 style not designated 4B0 601 025 L offset 45"
BGL = code not found :-(
8JH = ellipsoidal headlight for driving on the right
8Q1 = headlight-range adjustment
7K0 = without tire pressure warning light
6XD = outer rear view mirrors: powered, heated
5MY = decorative aluminum inserts "stars graphite"
U2A = instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometer
9Q0 = without multi-function indicator/on-board computer
4X1 = side airbag front
3Y0 = without roll-up sun screen
5SL = outer left rear view mirror: non-spherical
1AC = anti-lock brake system (ABS)
7X0 = without park distance control
0YE = weight category rear axle weight range 5
X0A = national sales program Germany
8Z5 = engine cooling system, type 1
2K1 = reinforced bumpers
4K4 = radio remote controlled central locking operated from inside and separate trunk release
5RQ = outer right rear view mirror: convex
4R2 = power windows front, mechanical window regulators rear
0JG = weight category front axle weight range 7
M6N = 4-cylinder turbo diesel engine 1.9 L/81 kW TDIwith MVEG 2, base engine is T1R
6R2 = leather gearshift boot
5D1 = carrier frequency 433.92 MHz
4GH = windshield tinted with windshield sunshield
E0A = no special edition brak specjalnej edycji
1KD = disc brakes, rear tarczowe hamulce tylne
3FA = without roof insert (standard roof) brak szyberdachu
F0A = no special purpose vehicle, standard equipment standardowe wyposazenie (nie jest to pojazd specjalnego przeznaczenia)
T1R = components for, base engine, unit 028.R czesci dla podstawowego silnika, jednostka 028.R (jakis kod silnika?)
1MR = leather steering wheel skorzane kolo kierownicy
7G0 = without humidity sensor brak czujnika wilgoci
3L3 = manual height adjustment for front seats reczne ustawianie wysokosci przednich siedzen
1SA = without additional engine guard brak dodatkowego zabezpieczenia silnika (jak mniemam, chodzi o zabezpieczenie antykradziezowe)
J0R = battery 380 A (80 Ah) akumulator 380 Amperow (80 Amperogodzin)
0L2 = electric throttle actuation elektryczne sterowanie przepustnica ?
3NZ = rear seat bench unsplit, backrest split folding tylne siedzisko niedzielone, oparcie dzielone
C8N = alloy wheels 6J x 15 style not designated 4B0 601 025 L offset 45" felgi aluminiowe 6Jx15 nie oznaczane, ET45
4UE = airbag for driver and front seat passenger poducha kierowcy i pasazera przedniego fotela
1LB = disc brakes, front tarczowe hamulce przednie
BGL = code not found :-( nie znaleziono kodu :P
8JH = ellipsoidal headlight for driving on the right elipsoidalne reflektory dla ruchu prawostronnego
8Q1 = headlight-range adjustment regulacja zasiegu reflektorow
7K0 = without tire pressure warning light brak kontrolki cisnienia w oponach
6XD = outer rear view mirrors: powered, heated zewnetrzne lusterka: sterowane elektrzynie, podgrzewane
5MY = decorative aluminum inserts "stars graphite" dekoracyjne wstawki aluminiowe
0G1 = gearshift lever dzwignia zmiany biegow
U2A = instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometer wskazniki z predkosciomierzem w km/h, zegarek sterowany falami radiowymi, obrotomierz (?) i licznik chwilowy przejechanych kilometrow
9Q0 = without multi-function indicator/on-board computer brak FISu :)
4X1 = side airbag front boczne airbagi przednie
3Y0 = without roll-up sun screen brak rolety przeciwslonecznej
Q1A = standard front seats standardowe przednie fotele
5SL = outer left rear view mirror: non-spherical zewnetrzne lewe lusterko wsteczne: nie sferyczne
1AC = anti-lock brake system (ABS) :P
7X0 = without park distance control brak 'parktronica'
0YE = weight category rear axle weight range 5 kategoria wagowa tylnej osi, zakres wagowy 5
X0A = national sales program Germany narodowy program sprzedazy w Niemczech
8Z5 = engine cooling system, type 1 typ 1 chlodzenia silnika
2K1 = reinforced bumpers wzmacniane zderzaki
4K4 = radio remote controlled central locking operated from inside and separate trunk release centralny zamek sterowany radiowo zdalnie obslugiwany z wewnatrz i oddzielne otwieranie bagaznika
5RQ = outer right rear view mirror: convex zewnetrzne prawe lusterko: wypukłe
1BA = standard suspension/shock absorption standardowe zawieszenie / tlumienie
4R2 = power windows front, mechanical window regulators rear elektryczne szyby przednie, mechaniczne sterowanie tylnych
0JG = weight category front axle weight range 7 kategoria wagowa przedniej osi, zakres wagowy 7
M6N = 4-cylinder turbo diesel engine 1.9 L/81 kW TDIwith MVEG 2, base engine is T1R 4-cylindrowy turbognojek 1.9L/81kW TDI z MVEG 2 (?), bazowym silnikiem jest T1R
6R2 = leather gearshift boot skorzany mieszek skrzyni biegow
5D1 = carrier frequency 433.92 MHz czestotliwosc (prawdopodobnie pilota od centralnego) 433.92 MHz
4GH = windshield tinted with windshield sunshield przednia szyba przyciemniana z pasem przeciwslonecznym
pedał gazu bez linki ;)
FISa Zdeniu nie ma u Ciebie ?
MVEG 2
Motor Vehicle Emissions Group
Czyli zdaje się Euro-2 (norma emisji spalin)
Zaktualizowałem kody, które już zostały opisane. Tych jeszcze nie odgadłem, pls o pomoc:
5RU outer right rear view mirror: convex (large viewing field)
5TD decorative aluminum inserts
7X1 ultrasonic park distance control
4R4 power windows with comfort operation andcircuit breaker
FOA no special purpose vehicle, standard equipment
8GU alternator 140A
OYJ weight category rear axle weight range 9
T9J components for, base engine, unit 038.K
X2C national sales program the Netherlands
1N1 power steering
2ZQ leather trimmed multi-function steering wheel for airbag system
9Q2 multi-function indicator/on-board computer with check control
8Z6 engine cooling system, type 2
D3E 4-cylinder turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system, EU 3, base engine is T9J/TG0
7QO without navigation device
C1W forged alloy wheels 7J x 15 type 1, offset 39
4XC exterior pillar lining
4KC side and rear windows tinted
OGE emissions concept EU 3
Q1D sports front seats
Z góry dziękuje
Chyba temat dla leniwcow :P Znalazlem troche juz troche tlumaczen ale ciagle mi brakuje kilku :
C0V = steel wheels 6J x 15 offset 45 (five-hole)
G0C = 5-speed manual transmission
(manualna skrzynia 5 biegowa?)
H6S = tires 195/65 R 15 V
J1P = battery 220 A (44 Ah)
(akumulator?)
1G2 = steel spare wheel with original equipment tires
4VE = two 3-point seat belts and one static lap belt in third row of seats
G1A = six-speed automatic transmission
2RM = nameplate set "GTI 16V" for special color trim"
1BE = sports suspension/shock absorption
Jesli ktos by byl skory do pomocy w tlumaczeniu to dzieki z gory xD
Kiors :
G0C = 5 biegowa, manualna skrzynia biegów5
H6S = opony 195/65 R 15 V
J1P = akumulator 220 A (44 Ah)
1G2 = stalowe koło zapasowe z normalną oponą
2PG = kierownica :rotfl:
4VE = pasy 3-punktowe i jeden pas bezwładnościowy na środku na tylniej kanapie
G1A =automatyczna skrzynia biegów (6) - to są Twoje kody ? U góry już masz skrzynie
M9L = 4 cylindrowy silnik benz. 1.8 L/110 kW 20V turbo, MVEG 2,
T8B = jakieś informacje na temat silnika
2RM = specjalna kolorystyka (oznaczenie GTI) - to na pewno dla A4 ?
1BE = zawieszenie sportowe
Kody przepisywalem na kartke i niewyrazne napisalem :P pomyliem w sumie 2 kody bo teraz zrobilem zdjecie i na kompie odczytalem ze zamiast :
G1A -> Q1A standard front seats - standardowe przednie fotele
4VE -> 4UE airbag for driver and front seat passenger - airbag dla kierowcy i pasazera
Kod 2RM dobrze wpislalem oto zdjecie wycinka gdzie jest ten kod:
Jakos nie widze tego specjalnego malowania :P Moze auto bylo cale malowane i przykryto jakies odjechane barwy, jakos nie chce mi sie zdzierac powloki lakierniczej zeby sie o tym przekonywac :P
Kod 1BE moze troche mi tlumaczy ale patrzac na autko zdaje mi sie ze jest troche podniesione z przodu o_0 Nie wiem czy to mozna przez to tlumaczyc ale tak mi sie zdaje. Musze zrobic zdjecie z boku i sami ocenicie czy jest na "poziomie"
Jeśli ktos sie nudzi proszę o dokladne przetłumaczenie:
Q0C = 5-speed manual transmission
HGS = tires 195/65 R 15 V
M51 = 4-cylinder gasoline engine 1.8 L/92 kW 20V with MVEG 2, base engine is T0V/T5Z
1GS = front shock absorption (Audi TT)
T5Z = components for, base engine, unit 058.B
4UC = airbag for driver
0Q1 = label for brake-proportioning values
8QD = key for locking system
1LH = disc brakes, front
Co prawda wiekszosc slowek jest znana, ale moze jeszcze sie czegos dowiem o
swoim samochodzie.
Najważniejsza sprawa: 4UC = airbag for driver
Kiedys byla juz dyskusja na ten temat 1 czy 2 poduszki.
No i okazuje sie, ze jednak takie egzemplarze wychodziły?
No pewnie , że wychodziły.Już kiedyś o tym pisałem :wink:
Zastanawia mnie jeszcze 1LH = disc brakes, front, dlaczego tylko przód?
Mam podgrzewane lusterka!!!? Nigdzie nie widzialem wlacznika, a moze grzeją się automatycznie ? :)
[ Dodano: 02-05-2007, 22:11 ]
X4C =przeznaczony do sprzedaży na rynek włoski
B0A = bez dodatkow wymaganych dla jakiegos kraju
C0V = felgi stalowe 6J x 15 offset 45 (pięć otworów)
G0C = 5-cio biegowa skrzynia
M51 = silnik benzynowy 4-cylindry 1.8 L / 92 kW 20V z MVEG 2, silnik bazowy T0V / T5Z
Q1A = standardowe siedzenia przednie
1AC = system antypoślizgowy (ABS)
1GS = front shock absorption (Audi TT) ?????????????
2PG = kierownica
5RD = zewnętrzne prawe lusterko: wypukłe, podgrzewane, elektrycznie regulowane i składane
3BK = zewnętrzne lewe lusterko: płaskie, podgrzewane, elektrycznie regulowane i składane
T5Z = komponenty, dla bazowego silnika, część 058.B
3S0 = bez relingow i uchwytow dachowych
4UC = airbag kierowcy
0Q1 = label for brake-proportioning values ???????????????
8AV = bez radia, połączenie z głośnikami
8QD = klucz do zamykania systemu ? (immo ? )
8RE = cztery głośniki (pasywne)
1LH = hamulce tarczowe z przodu
3FA = bez szyberdachu (dach stadardowy) ~
1BA = zawieszenie standardowe shock absorption ???????????~
Dziwne, ze nic nie pisze o klimie.
Jesli mozna chcialbym sie podłączyć do pytania.... :)
Zdekodowalem listę wyposazenia mojej :a4fan:
2K1 = reinforced bumpers -- co to za czort ? Wzmocnione zderzaki ? :eek:
D3E = 4-cylinder turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system, EU 3, base engine is T9J/TG0 -- moj silnik to wg. specyfikacji "papierowej" AVF, o co chodzi z tym t9j ?
8GU = alternator 140A -- były jakieś inne wersje alternatora ?
6R0 = selector lever cover -- ??
5RU = outer right rear view mirror: convex (large viewing field) --takie lusterko to standard czy jakas specjalna wersja ?
3S0 = without roof rails/roof load rack - bez relingow i uchwytow dachowych
B0A = component parts set without country-specific design requirement - czyli bez dodatkow wymaganych dla jakiegos kraju
Ja mam 70 A przynajmniej tak na obudowie pisze..
8RM = eight loudspeakers (passive)
to taki kod według mnie...
[ Dodano: 03-05-2007, 10:54 ]
masz ogrzewanie szyby tylnej ?
W kodzie wyposażenia audi 100 c4 figurują dane:
H0P = tires 205/60 R 15 V
C3T = alloy wheels 7J x 16 offset 35
Ktory rozmiar felgi jest standardowy 15 czy 16? Te informacje wzajemnie sie wykluczają.
3bs
3BS = outer left rear view mirror: non-spherical, powered, heated
