Co to za błąd ?
Gibons
Czy to będzie CP ?
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 T HW: 8T0 035 223 F
Component: DSP Prem H14 0400
Revision: 00H14003 Serial number: 34814000151300
Coding: 020101
Shop #: WSC 12336 024 394758
VCID: 3F8DA577AE8867E6AD9-806A
2 Faults Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2064.00.00
Time: 00:03:30
Freeze Frame:
Voltage: 14.00 V
Temperature: 17.0°C
Temperature: 21.0°C
Bin. Bits: 00000100
Bin. Bits: 00000100
Bin. Bits: 00000000
02095 - Component Protection Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 124
Freeze Frame:
Voltage: 12.00 V
Temperature: 22.0°C
Temperature: 23.0°C
Bin. Bits: 00000100
Drugi blad wskazuje na aktywne CP ,ale ten pierwszy jest gorszy ,wskazuje na uszkodzony modul ,ewentualnie uszkodzony soft.
