Servotronic - wali błędami
l.e.s.t.e.r
Cześć,
Wymieniłem przekładnie na Servotronic, niestety po zakodowaniu nie działa, dodatkowo wali strasznie błędami.
Proszę o jakieś wskazówki.
Tuesday,10,May,2016,15:48:15:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAUZZZ8K69A217614 License Plate:
Mileage: 189170km-117544mi Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 03 05 07 08 09 0E 10 15 16 17 19 37 42 46 47 52 53 56 62
72
VIN: WAUZZZ8K69A217614 Mileage: 189170km/117544miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAGB) Labels: None
Part No SW: 03L 906 022 ML HW: 03L 906 022 B
Component: R4 2,0L EDC X01 4376
Revision: 11X01---
Coding: 0104002C18072118
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM20TDI03L906022ML A01004
ROD: EV_ECM20TDI03L906022.rod
VCID: 7BF51167F210BBC6C11-802E
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AE HW: 8K0 907 379 AE
Component: ESP8 front H04 0240
Revision: -------- Serial number: --------------
Coding: 160500
Shop #: WSC 06325 000 00000
VCID: 7CF7127BFF1EBCFEC8B-8029
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 N HW: 8K0 907 064 N
Component: BCM2 1.1 H80 0145
Revision: 00002001
Coding: 030200
VCID: 3B75D167BA907BC6811-806E
Subsystem 1 - Part No SW: 8K0 959 754 D HW: 8K0 959 754 D
Component: FBSAUDIB8 IDG H71 0083
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H36 0041
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 N HW: 4E0 035 729
Component: Interfacebox H43 5150
Revision: 00000000 Serial number: 329C1097639975
Coding: 0040013
Shop #: WSC 00000 000 08192
VCID: 4487AA9B076E043EF0B-8011
Subsystem 1 - Part No: 8T0 919 609
Component: E0380 BedienteilH08 0100
Subsystem 2 - Serial number: 00000000244800
Subsystem 3 - Serial number: 0121.02.090000000100010376ÿ
Subsystem 4 - Serial number: 010376ÿ
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA
Component: KLIMA 1 ZONE H06 0150
Revision: A1000000 Serial number: 01120320091706
Coding: 34000000
VCID: 70EF364BA356C89E643-8025
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H21 0253
Revision: 05021001 Serial number: 00000000121120
Coding: 260010B10134AF300001000300001D0D001C060800000101000000
Shop #: WSC 12345 123 12345
VCID: 306FF64B63D6889E243-8065
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 130309 H06 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
2 Faults Found:
03110 - Active Steering Control Module (J792)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 155
Mileage: 189176 km
Time Indication: 0
Date: 2016.05.10
Time: 15:43:00
03207 - Charisma Switch Module
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 155
Mileage: 189176 km
Time Indication: 0
Date: 2016.05.10
Time: 15:43:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 8T1 035 110 C HW: 8T1 035 110 C
Component: MP3-Changer H43 0390
Revision: 00043003 Serial number: AUZ5ZBI8762529
Shop #: WSC 00000 000 00000
VCID: 2A5BE423850AF24EEA7-807F
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 F HW: 8K0 919 475
Component: PARKHILFE 4K H06 0040
Revision: 11001001 Serial number: 40140907104230
Coding: 100003
Shop #: WSC 06325 123 12345
VCID: 3C77D27BBF9E7CFE88B-8069
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H27 0410
Serial number: 0038JD1ER447
Coding: 30343435363030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3C77D27BB79E7CFE88B-8069
Crash sensor for side airbag; driver side:
Serial number: 6334MSME41056233/
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME45242143%
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME541A1918G
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME151B24046
Crash sensor for front airbag; driver side:
Serial number: 63732SME6C1B1A085
Crash sensor for front airbag; passenger side:
Serial number: 63832SME6C1B4E3CK
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304ICB0002T
Coding: 000017
VCID: 3D71DF7FA48475F6BF5-8068
Component: E221 - MFL H06 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 930 C HW: 8K0 920 930 C
Component: KOMBIINSTR. H18 0224
Revision: 00200000 Serial number: 9E227A239
Coding: 0D0D100002000008010000
VCID: 2D51EF3F74E4E5760F5-8078
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 P HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0095
Revision: EB500046 Serial number: 4600E092248043
Coding: 000303
VCID: 4E9388B31922FE6E56F-801B
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0160
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H52 1060
Revision: 00000000 Serial number: 333CZ097649853
VCID: 3B75D1677A907BC6811-806E
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 E HW: 8K0 959 793 E
Component: TSG FA H11 0250
Revision: Serial number: 0000008548479
Coding: 011002204000410001
VCID: 428BAC83DD7A0A0EC27-8017
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0117351890
Coding: 013A062020390040022002
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Address 47: Sound System (J525) Labels: 8T0-035-223-BAM.clb
Part No SW: 8T0 035 223 AE HW: 8T0 035 223 R
Component: DSP Basic H08 0300
Revision: S2600000
Coding: 010101
VCID: 71E9334FA85CC1966BD-8024
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 E HW: 8K0 959 792 E
Component: TSG BF H11 0250
Revision: Serial number: 0000008674364
Coding: 011002204C00410001
VCID: 4189A38FD87C1116DBD-8014
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 G HW: 8K0 907 801 G
Component: EPB Audi B8 H08 0080
Revision: 00000003 Serial number: 00000000327621
VCID: 3365F94792C0B386591-8066
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 N
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 357CV097525913
Coding: 0000001
VCID: 3169F34FA8DC81962BD-8064
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 N HW: 8K0 959 795 C
Component: TSG HL H10 0251
Revision: Serial number: 0000008613625
Coding: 010002204000210001
VCID: 4487AA9BC76E043EF0B-8011
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000008618067
End ---------------------------------------------------------------------
Moduł z końcówką D
Piny są
Edytowane przez l.e.s.t.e.r
rozumiem że zmieniłeś samą maglownicę bez kolumny? Z magla pociągnąłes dwa przewody do wtyku zgodnie ze schematem, magiel miał numer 8T1 422 066 B i do czarnej wtyczki 17 pin wpiąłeś przewody na 1 i 12 pin w MCE ?
Podeślij kodowanie w MCE. Kodowałeś tylko 7 Bajt, bit 0? czy jeszcze coś?
kodowanie MCE
Na rysunku w poście wyżej czerwonymi kóleczkami zaznaczyłem piny które są podpięte.
Wymieniłem magiel na ten z pierwszego posta w tym temacie, dwa kable od magla do modułu MCE.
Jedynie co mi do głowy przychodzi to że coś z tymi pinami jest.
A widzisz co wogóle zakodowałes ?
Bo ze scanu widac ze nie masz aktywnego ukladu kierowniczego oraz AUDI DRIVE SELECT
Tu masz :
KODOWANIE SERVOTRONIC :
MCE 09 ---> LongCodingHelper ---> Coding 07 ---> BYTE 7 ---> Bit 0 zmiana z 0 na 1 .
ło matko jak ja to czytałem :facepalm:
Już wszystko pięknie bangla, różnica powalająca.
Dzięki za pomoc.
Witam mam też problem z servotronikiem proszę o pomoc w kodowanie vcds po polsku
Tu masz :
