marjan83 0 Opublikowano 26 Września 2017 Udostępnij Opublikowano 26 Września 2017 Witam, prosiłbym o interpretację loga , dodam ze problem z dpf, podczas jazdy auto zgasło i wszystko się wyłączyło, możliwy jest problem z kluczykiem ? Spoiler Monday,25,September,2017,23:12:20:62939 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: Release 12.12.0 (x64) Data version: 20130910 VIN: WAUZZZ8K39A223502 License Plate: Mileage: 226710km-140871mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8K (8T0) Scan: 01 03 05 07 08 09 0E 10 15 16 17 19 1E 37 42 46 47 52 53 56 62 69 72 77 VIN: WAUZZZ8K39A223502 Mileage: 226710km/140871miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1E-Media Player 2 -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 69-Trailer -- Status: Sporadic communication error 1000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CGKA) Labels: 059-907-401-CAP.clb Part No SW: 8K1 907 401 K HW: 8K1 907 401 A Component: 2.7TDI EDC17 H01 0008 Revision: 15H01--- Coding: 010C002C18070118 Shop #: WSC 06335 000 00000 ASAM Dataset: EV_ECM27TDI0118K1907401K 001009 ROD: EV_ECM27TDI.rod VCID: 3467FA5B9FCEB4BE40B-8061 4 Faults Found: 4807 - EGR System P0401 00 [096] - Insufficient Flow Intermittent - Not Confirmed - Tested Since Memory Clear 18660 - Start Interruption due to Insufficient Engine Speed P151D 00 [032] - - Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 32 Mileage: 226689 km Date: 2017.09.23 Time: 17:55:56 5308 - Throttle Body Actuator Bank 1 (J338) P0638 00 [175] - Implausible Signal MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 12 Mileage: 226689 km Date: 2017.09.23 Time: 17:55:59 5418 - Cylinder 6 Glow Plug Circuit (Q15) P0676 00 [109] - Electrical Fault Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 210131 km Date: 2016.09.03 Time: 08:44:38 Readiness: 1 1 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb Part No SW: 8K0 907 379 AG HW: 8K0 907 379 AG Component: ESP8 front H04 0240 Revision: -------- Serial number: -------------- Coding: 198D00 Shop #: WSC 47091 141 00222 VCID: 7EF31873E902AEEEE6F-802B No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 M HW: 8K0 907 064 M Component: BCM2 1.1 H80 0145 Revision: 00002001 Coding: 030200 Shop #: WSC 06335 000 00000 VCID: 3A7BD463B5AA42CE9A7-806F Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H37 0060 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: J764 ELV MLB H36 0042 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: Redir Fail! Part No SW: 8T0 035 769 C HW: 4L0 035 730 B Component: MMI Cockpit H60 0630 Revision: C61030BE Serial number: AUZ6Z3I3IB07S3 Coding: 0164301 Shop #: WSC 00493 128 73884 VCID: 3D71DF7F648475F6BF5-8068 Subsystem 1 - Part No: 8T0 919 609 Component: E0380 BedienteilH08 0100 Subsystem 2 - Serial number: 00000000254923 Subsystem 3 - Serial number: 0114.03.090000000100010034˙ Subsystem 4 - Serial number: 010034˙ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA Component: KLIMA 1 ZONE H06 0150 Revision: A1000000 Serial number: 01250320090582 Coding: 36000000 Shop #: WSC 06335 000 00000 VCID: 70EF364BA356C89E643-8025 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 D HW: 8K0 907 063 D Component: BCM1 1.0 H24 0253 Revision: 05024001 Serial number: 00000000342905 Coding: 690040B1003400010001000300005F5F0F1C260800000001000000 Shop #: WSC 47091 141 00222 VCID: 306FF64B63D6889E243-8065 Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB Component: WWS 250309 H06 0070 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 941 531 P HW: 8K0 941 531 P Component: E1 - LDS H07 0090 2 Faults Found: 01517 - Control Module for Trailer/Towing Sensor (J345) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 254 Reset counter: 211 Mileage: 210125 km Time Indication: 0 Date: 2016.08.31 Time: 18:25:00 02071 - Local Databus 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 202 Mileage: 226430 km Time Indication: 0 Date: 2017.09.20 Time: 16:30:00 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: None VCID: 55A167DFBCF48DB6975-8000 No Faults Found or DTCs not supported by controller or a communication error occurred ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb Part No SW: 8K0 919 475 F HW: 8K0 919 475 Component: PARKHILFE 4K H06 0040 Revision: 11001001 Serial number: 40140908211015 Coding: 010003 Shop #: WSC 47091 141 00222 VCID: 3C77D27BBF9E7CFE88B-8069 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 8K0-959-655.clb Part No SW: 8K0 959 655 B HW: 8K0 959 655 B Component: AirbagVW-AU10 H27 0410 Serial number: 0038JD1EZ73H Coding: 30343435363030303030554A304C384B3053 Shop #: WSC 06335 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 A02007 ROD: EV_AirbaECUVWAUDI010_AU48.rod VCID: 3C77D27BB79E7CFE88B-8069 Crash sensor for side airbag; driver side: Serial number: 6334MSME46350B63B Crash sensor for side airbag; passenger side: Serial number: 6344MSME455419024 Crash sensor for side airbag; rear driver side: Serial number: 6352QSME721C5738M Crash sensor for side airbag; rear passenger side: Serial number: 6362QSME621E0F0CS Crash sensor for front airbag; driver side: Serial number: 63732SME5D212F02$ Crash sensor for front airbag; passenger side: Serial number: 63832SME581E4F06A No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H16 0014 Revision: -------- Serial number: 90315ICP0002Z Coding: 000017 Shop #: WSC 06335 000 00000 VCID: 3D71DF7FA48475F6BF5-8068 Component: E221 - MFL H02 0003 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb Part No SW: 8K0 920 900 D HW: 8K0 920 900 D Component: KOMBIINSTR. H18 0224 Revision: 00000000 Serial number: 9DT207L39 Coding: 0F04100003000008000000 Shop #: WSC 06335 000 00000 VCID: 2B55E1274AF0EB46111-807E No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 P HW: 8T0 907 468 K Component: GW-BEM 4CAN-M H09 0095 Revision: EB500046 Serial number: 4600E093170144 Coding: 000303 Shop #: WSC 06335 000 00000 VCID: 4E9388B31922FE6E56F-801B Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E Component: J367-BDM H06 0160 1 Fault Found: 01517 - Control Module for Trailer/Towing Sensor (J345) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 254 Reset counter: 211 Mileage: 210125 km Time Indication: 0 Date: 2016.08.31 Time: 18:25:59 ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 8T1 035 110 C HW: 8T1 035 110 C Component: MP3-Changer H43 0390 Revision: 00043003 Serial number: AUZ5ZBI8772991 Shop #: WSC 00000 000 00000 VCID: 2A5BE423850AF24EEA7-807F No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: Redir Fail! Part No SW: 8T0 035 769 C HW: 4L0 035 730 B Component: MMI Cockpit H60 0630 Revision: C61030BE Serial number: AUZ6Z3I3IB07S3 Coding: 0164301 Shop #: WSC 00493 128 73884 VCID: 3D71DF7F648475F6BF5-8068 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb Part No SW: 8K0 959 793 D HW: 8K0 959 793 D Component: TSG FA H11 0250 Revision: Serial number: 0000008686368 Coding: 011C02204000410001 Shop #: WSC 06335 000 00000 VCID: 4189A38FD87C1116DBD-8014 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 M HW: 8K0 907 064 M Component: BCM2 1.1 H80 0145 Revision: 00002001 Serial number: 0117791138 Coding: 0100062020390040012002 Shop #: WSC 06335 000 00000 VCID: 3A7BD463B5AA42CE9A7-806F No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: 8T0-035-223-BAM.clb Part No SW: 8T0 035 223 AE HW: 8T0 035 223 R Component: DSP Basic H08 0300 Revision: S2600000 Coding: 010101 Shop #: WSC 06335 000 00000 VCID: 71E9334FA85CC1966BD-8024 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb Part No SW: 8K0 959 792 D HW: 8K0 959 792 D Component: TSG BF H11 0250 Revision: Serial number: 0000008693857 Coding: 011C02204000410001 Shop #: WSC 06335 000 00000 VCID: 408FA68BD376181ED43-8015 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 G HW: 8K0 907 801 G Component: EPB Audi B8 H08 0080 Revision: 00000003 Serial number: 00000000336659 Shop #: WSC 00000 000 00000 VCID: 3365F94792C0B386591-8066 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: Redir Fail! Part No SW: 8T0 035 769 C HW: 4L0 035 730 B Component: MMI Cockpit H60 0630 Revision: C61030BE Serial number: AUZ6Z3I3IB07S3 Coding: 0164301 Shop #: WSC 00493 128 73884 VCID: 3D71DF7F648475F6BF5-8068 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb Part No SW: 4F0 959 795 N HW: 8K0 959 795 C Component: TSG HL H10 0251 Revision: Serial number: 0000008695095 Coding: 010C02204000210001 Shop #: WSC 06335 000 00000 VCID: 4487AA9BC76E043EF0B-8011 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer Labels: 8K0-907-383.clb Part No SW: 8K0 907 383 E HW: 8K0 907 383 E Component: Anhaenger H07 0070 Coding: 0100000000000000 Shop #: WSC 00000 000 00000 VCID: 3663C05381B2A6AE7EF-8063 5 Faults Found: 02562 - Trailer; Brake Lamps 015 - Cannot Be Tested at this Time - Intermittent - MIL ON 02563 - Trailer; Right Tail Lamps (M61) 001 - Upper Limit Exceeded 02564 - Trailer; Left Tail Lamps (M60) 001 - Upper Limit Exceeded - MIL ON 02565 - Trailer; Right Turn Signals (M63) 010 - Open or Short to Plus - Intermittent - MIL ON 02566 - Trailer; Left Turn Signals (M62) 010 - Open or Short to Plus - Intermittent - MIL ON ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb Part No SW: 4F0 959 795 N HW: 8K0 959 795 C Component: TSG HR H10 0251 Revision: Serial number: 0000008695119 Coding: 010C02204000210001 Shop #: WSC 06335 000 00000 VCID: 4487AA9BC76E043EF0B-8011 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4E0 910 336 M HW: 4E0 862 335 Component: Handyvorb2 H20 1130 Revision: 00000000 Serial number: 00000005309566 Coding: 0020910 Shop #: WSC 06335 000 00000 VCID: 2C57E23B8FFEEC7E18B-8079 No fault code found. End --------------------------------------------------------------------- Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
edraven 10 Opublikowano 26 Września 2017 Udostępnij Opublikowano 26 Września 2017 Wygląda że klapa gasząca zacięła się. Zdjemij rurę doprowadzającą powietrze do silnika (obok lampy od strony kierowcy) i rozruszaj klapkę. Jeżeli pomoże i odpali to wyczyść całość, ale bardzo możliwe że nastawnik do wymiany będzię bo sie mogł rozsypać w środku. Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
