Audi A4 B6 2.0 ALT. Prośba o interpretacje błedów
Krzychududi
Witam,
tydzień temu kupiłem sobie własnie Audi A4 B6 2.0 alt, zrobiłem wraz ze znajomym raport błędów ale nie za bardzo wiem jak je interpretować. Zwracam sie do was z prosbą o małą pomoc i interpretacje oewgo raportu.
Oto i on:
VCDS-Lite Version: Release 1.2
Thursday, 17 May 2018, 19:47:12:0
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77
Address 01: Engine       Labels: 06B-907-557-ALT.LBL
   Controller: 8E0 907 557
   Component: 2.0L R4/5VS         0006
   Coding: 0011501
   Shop #: WSC 77631
   VCID: EEAFCDBBB98F
2 Faults Found:
17544 -  Fuel Trim: Bank 1 (Add): System too Lean
            P1136 - 001 -  Upper Limit Exceeded - Intermittent
18010 - Shareware Version. To Decode all DTCs
            P1602 - 002 - Please Register/Activate - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes       Labels: 8E0-614-517.LBL
   Controller: 8E0 614 517
   Component: ABS/ESP front       D620
   Coding: 04275
   Shop #: WSC 06435
   VCID: E5BDB2976C79
2 Faults Found:
01826 -  Sensor for Steering Angle (G85); Supply Voltage Terminal 30
            35-10 -   - - Intermittent
01206 -  Signal for Duration of Ignition Off Time
            27-10 -  Implausible Signal - Intermittent
Address 08: Auto HVAC       Labels: 8E0-820-043.LBL
   Controller: 8E0 820 043
   Component:   A4 Klimaautomat   0406
   Coding: 00000
   Shop #: WSC 63351
   VCID: DECF9D7B492F
No fault code found.
Address 09: Cent. Elect.       Labels: 8E0-907-279-8E2.LBL
   Controller: 8E0 907 279
   Component: int. Lastmodul  RDW 0510
   Coding: 00001
   Shop #: WSC 63351
   VCID: EF91D0BFBE85
Address 15: Airbags       Labels: 8E0-959-655-84.LBL
   Controller: 8E0 959 655
   Component: Airbag 8.4E         3001
   Coding: 0010602
   Shop #: WSC 63351
   VCID: F49BDFD3D7A3
Address 16: Steering wheel       Labels: 8E0-953-549.LBL
   Controller: 8E0 953 549 F
   Component: Lenksáulenmodul     0302
   Coding: 00001
   Shop #: WSC 63351
   VCID: 361FA5DB015F
Address 17: Instruments       Labels: 8E0-920-9xx-8E2.LBL
   Controller: 8E0 920 900 F
   Component: KOMBI+WEGFAHRS. RB4 D12
   Coding: 00000
   Shop #: WSC 00006
   VCID: 2721789FD6F5
   WAUZZZ8EZ1A042744     AUZ6Z0A0056652
Address 46: Central Conv.       Labels: 8E0-959-433-MIN.LBL
   Controller: 8E0 959 433 N
   Component: Komfortgerát T87    0112
   Coding: 06720
   Shop #: WSC 63351
   VCID: 3C0BB7F33F73
8 Faults Found:
01561 -  Left Rear Door
            59-10 -  Can't Unlock - Intermittent
01562 -  Right Rear Door
            61-10 -  Won't De-Safe - Intermittent
01703 -  Footwell Lighting; Right (W10)
            29-10 -  Short to Ground - Intermittent
01697 -  Footwell Lighting; Rear Right (W46)
01696 -  Footwell Lighting; Rear Left (W45)
00912 -  Window Regulator Switch; Front Left (E40)
01560 -  Passenger Door
Address 56: Radio       Labels: 8E0-035-1xx-56.LBL
   Controller: 8E0 035 152
   Component: chorus II   GRO    0001
   Coding: 00000
   Shop #: WSC 63351
   VCID: DDCD9A774429
End   --------------------------------------------------------------------------------------------------
Z góry dziekuje!
http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
masz tu wszystko
Po skasowaniu pojeździj trochę i sprawdź jakie błędy pozostaną bo  Intermittent to błędy sporadyczne i mogły wyskoczyć jak np aku był bardzo słaby itp. Zajmij się tymi które zostaną po 2 skanowaniu.
Edytowane przez sitar
A czy za pomocą tego programu da radę usuwać błędy? Jeśli tak to w jaki sposób bo jestem w tym nieco zielony ? obecnie używam VCDS-Lite 1.2
Usuniesz za pomocą vcds - jak robiłeś auto scan i pokazał ci się raport to masz obok ikonkę wyczyść-kasuj.
Ok, co prawda inaczej się tam kasuje w tym lite ale się udało. Po zrobieniu 250 km pojawia się tylko błąd:
Uboga mieszanka. Masz lpg w samochodzie? Możesz wrzucić logi statyczne i dynamiczne 2+33
Tylko benzyna, tankowana na shellu i orlenie
Edytowane przez Krzychududi
Może to głupio zabrzmi ale nie wiem jak je uzyskać ? dzialam na programie VCDS LITE 1.2 jak ogarnąć owe logi w tym programie?
Wchodzisz w bloki pomiarowe, wybierasz grupy i logujesz. Jest multum instrukcji oraz filmików co i jak. W benzynie dynamiczne robisz do odcinki.
Nic trudnego ?
Ok dzięki postaram się ogarnąć to po pracy.
Ale chyba coś jest na rzeczy bo wymieniłem w weekend tłumik, i przy sprawdzaniu szczelności woda leciała prawie że strumykiem
załączam linki do logów statycznych
http://vaglogi.pl/log-001_002_003_Mvf2DH.html
http://vaglogi.pl/log-004_005_006_PVpwc.html
Bardzo proszę o interpretacje.
Kolego jakie grupy miałeś zrobić? 2+ 33 statycznie i dynamicznie. To co wkleiłeś w sumie do niczego się nie nadaje. Po logu statycznym gr. 2 można mieć podejrzenie, że coś z przpływką.
Edytowane przez przem8
http://vaglogi.pl/log-002_033_001_uTKWmlf.html
już sie poprawiłem. Na początku minuta na jałowym, później, po przescrollowaniu niżej jest odczyt dynamiczny.
2 minuty temu, Krzychududi napisał:
odczyt dynamiczny.
Log dynamiczny robimy na 3 biegu od 1,5 tys do odcinki, a Ty chyba przegazowałeś na postoju?
No tak, sorry za to że trzeba do mnie mówić jak do młotka :D po prostu raczkuje dopiero w tych tematach także jeszcze raz przepraszam :D w takim razie na dynamiczny trzeba będzie trochę poczekać, bo muszę znaleźć jakaś boczna drogę.
A czy z tego co zrobiłem mozna juz mniejwiecej coś odczytać? Czy też do niczego sie nie nadaje?
Przepływka trochę zaniża na jałowych, bo jest poniżej 2g/s , a norma jest 2-4,5 ale korekty niby ok. Zrób jeszcze dynamiczny.
świece w silniku były wymieniane?
Zrób dynamiczne, bo faktycznie przepływka zaniża, ale przy dynamicznej wyjdzie co boli ;)
Ok, zajmę się tym po pracy. Ale tylko logi z grupy 002 i 033? Czy coś jeszcze spróbować?
Niestety, świec jeszcze nie ruszalem, samo auto mam od 2 tygodni takze wszystko przede mną
