Szpunar200 0 Opublikowano 15 Kwietnia 2019 Udostępnij Opublikowano 15 Kwietnia 2019 (edytowane) Witam Zeskanowalem auto programem bluetooth i wyskoczylo mi coś takiego. Pogrubilem to co mnie ciekawi. Mode $06 report generated by Torque for Android================================================VIN samochodu:WAUZZZ8K9CA078862Producent:AudiID kalibracji pojazdu:8K2907115AF 0002Test report:------------------MID:$01 TID:$83- O2 Bank 1 Sensor 1Max: 1,99882 Min: 0,3499Test result value: 1,13094PASS----MID:$01 TID:$84- O2 Bank 1 Sensor 1Max: 0,06997 Min: -0,06997Test result value: 0,00061PASS----MID:$02 TID:$81- O2 Bank 1 Sensor 2Max: 0,6549V Min: 0VTest result value: 0,64514VPASS----MID:$02 TID:$82- O2 Bank 1 Sensor 2Max: 1,26002V Min: 0,6549VTest result value: 0,66466VPASS----MID:$02 TID:$83- O2 Bank 1 Sensor 2Max: 0,25352V Min: 0VTest result value: 0VPASS----MID:$21 TID:$84- Catalyst Monitor Bank 1Max: 1,99882 Min: 0,20304Test result value: 0,49971PASS----MID:$35 TID:$80- Max: -7,62° Min: -23,62°Test result value: -15,16°PASS----MID:$35 TID:$81- Max: -7,62° Min: -23,62°Test result value: -15,16°PASS----MID:$3d TID:$80- EVAP Monitor (0.020")Test incomplete or dependant test failed--MID:$3d TID:$88- EVAP Monitor (0.020")Max: 65 535 Min: 3Test result value: 5PASS----MID:$41 TID:$85- O2 Heater Monitor Bank 1 - Sensor 1Max: 1 239,90002°C Min: 754,90002°CTest result value: 819,40002°CPASS----MID:$42 TID:$81- O2 Heater Monitor Bank 1 - Sensor 2Max: 1 638Ohm Min: 0OhmTest result value: 138OhmPASS----MID:$a2 TID:$0bEWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 DataMax: 65 535Count Min: 0CountTest result value: 2CountPASS----MID:$a2 TID:$0cMisfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 DataMax: 65 535Count Min: 0CountTest result value: 0CountPASS----MID:$a3 TID:$0bEWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 DataMax: 65 535Count Min: 0CountTest result value: 3CountPASS----MID:$a3 TID:$0cMisfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 DataMax: 65 535Count Min: 0CountTest result value: 0CountPASS----MID:$a4 TID:$0bEWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 DataMax: 65 535Count Min: 0CountTest result value: 1CountPASS----MID:$a4 TID:$0cMisfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 DataMax: 65 535Count Min: 0CountTest result value: 0CountPASS----MID:$a5 TID:$0bEWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 DataMax: 65 535Count Min: 0CountTest result value: 4CountPASS----MID:$a5 TID:$0cMisfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 DataMax: 65 535Count Min: 0CountTest result value: 0CountPASS---- Edytowane 15 Kwietnia 2019 przez Szpunar200 Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
MarcinOslo 17 Opublikowano 15 Kwietnia 2019 Udostępnij Opublikowano 15 Kwietnia 2019 Z tego czegos nie da sie nic wywnioskowac .. Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
kixi4 18 Opublikowano 15 Kwietnia 2019 Udostępnij Opublikowano 15 Kwietnia 2019 Dokladnie, te chinskie obd2 to tragedia, niby odczytuje, ale zmienia niekiedy nr bledow.. a tlumaczenie bledow nijak ma sie do faktycznego kodu bledu sterownika.. Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
