Ocena logów nagłośnienia i wentylatora
davis693
Address 01: Engine (J623-CAGA)       Labels: 03L-906-022-CAG.clb
   Part No SW: 03L 906 022 MK    HW: 03L 906 022 B
   Component: R4 2,0L EDC   H14 8441
   Revision: 11H14---
   Coding: 0104002C02072920
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_ECM20TDI03L906022MK A01009
   ROD: EV_ECM20TDI03L906022C.rod
   VCID: 7AFC29AAFD441991A7-802E
1 Fault Found:
4527 - Coolant Fan Control Circuit 1
          P0480 00 [036] - Electrical Malfunction
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 198895 km
                    Date: 2019.08.18
                    Time: 10:28:53
                    Engine speed: 852.00 /min
                    Normed load value: 29.4 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 45 °C
                    Intake air temperature: 27 °C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 12.740 V
                    Unlearning counter according OBD: 40
                    Crankshaft speed (RPM): 852.0 /min
                    Vehicle speed: 0.00 km/h
                    Intake air temperature: 27.0 °C
                    Coolant temperature: 45.2 °C
                    Ambient temperature: 27.0 °C
                    Coolant fan 1: activation: 10.00 %
                    Coolant fan 2: activation: 0.00 %
Readiness: 0 0 0 0 0
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
   Component: DSP Prem      H10 0190
   Revision: 00010001    Serial number: 34804007408802
   VCID: 7AFC29AAF5441991A7-802E
2 Faults Found:
00003 - Control Module
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 130042 km
                    Time Indication: 0
                    Date: 2014.03.11
                    Time: 13:34:47
             Freeze Frame:
                    Voltage: 13.60 V
                    Temperature: 13.0°C
                    Temperature: 18.0°C
                    Bin. Bits: 00000100
                    Bin. Bits: 00000100
                    Bin. Bits: 00000000
03029 - Subwoofer (R157)
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 130042 km
                    Time Indication: 0
                    Date: 2014.03.11
                    Time: 13:34:47
Pierwszy błąd dotyczący wentylatora wyskakuje z reguły po wypalaniu DPF'a(przynajmniej tak zakładam), co tam mogę sprawdzić.
Kolejne 2 błędy to dla mnie zagadka, bo co usunę to wracają z tym samym mileage, co i jak tam popaczeć bo nie wiem dlaczego tak się dzieje. Czy trzeszczący głośnik w prawych drzwiach może mieć coś z tym wspólnego? Bo już denerwuje mnie, że co jakiś czas jakby sie obracał i rezonował o obudowę. Podkładam tam co jakiś czas papierek :D żeby to ograniczyć ale no i tak powraca problem.
Na koniec pytanie bonusowe, logi z Tiguana 5n
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
   Component: J234__20J VW10 HI   3018
   Revision: 32022000    Serial number: 003L7P228GTR
   Coding: 0012362
   Shop #: WSC 01357 011 00200
   VCID: 7CF02FB23F7027A1B5-8028
   Subsystem 1 - Serial number: 6332MTS667680326
   Subsystem 2 - Serial number: 6342MTS642050236
   Subsystem 3 - Serial number: 6351HTS65UPI6EKR
   Subsystem 4 - Serial number: 6361HTS6BSFA5EKJ
   Subsystem 5 - Serial number: 00000000000000000
   Subsystem 6 - Serial number: 00000000000000000
No fault code found.
Dlaczego sub 5 i 6 nie maja numeru? Bo trochę mnie to zdziwiło.
Dzięki i pozdrawiam!
Jakieś wskazówki co do tych błędów? Z wentylatorem to pewnie kable luźne ale mniejsza, a co  tym nagłośnieniem? Czy jest możliwe, żeby sterownik zapisywał błąd ze złym przebiegiem i datą, czy to ciągle ten sam błąd z przed kilku lat?
