michasssxDD 0 Opublikowano 23 Sierpnia 2019 Udostępnij Opublikowano 23 Sierpnia 2019 (edytowane) Witam, ktoś mi zerknie na błędy? Jutro jadę sprawdzić turbo bo coś chyba kiepsko z nim... To logi VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77 Address 01 ------------------------------------------------------- Controller: 8E0 909 518 AA Component: 1.8L R4/5VT 0004 Coding: 0011501 Shop #: WSC 63351 4 Znalezione: 16683 - Boost Pressure Regulation: Control Range Not Reached P0299 - 002 - Lower Limit Exceeded 16891 - Idle Control System RPM Higher than Expected. P0507 - 001 - Upper Limit Exceeded - Intermittent 17956 - Boost Pressure Regulation Valve (N75): Open Circuit P1548 - 004 - No Signal/Communication - Intermittent 17511 - Oxygen (Lambda) Sensor Heating: B1 S1: Performance too Low P1103 - 008 - Implausible Signal - Intermittent Readiness: 0010 1001 Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 1726 Coding: 04475 Shop #: WSC 00460 1 B³¹d Zapis.: 01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30 35-10 - - - Intermittent Address 08 ------------------------------------------------------- Controller: 8E0 820 043 H Component: A4 Klimaautomat 1116 Coding: 00000 Shop #: WSC 63351 3 Znalezione: 01809 - Actuating Motor for Temperature Flap: Left (V158) 41-10 - Blocked or No Voltage - Intermittent 01841 - Potentiometer/Actuator for Temperature Flap: Left (G220) 30-10 - Open or Short to B+ - Intermittent 01274 - Air Flow Flap Positioning Motor (V71) 41-10 - Blocked or No Voltage - Intermittent Address 09 ------------------------------------------------------- Controller: 8E0 907 279 C Component: int. Lastmodul RDW 0203 Coding: 00001 Shop #: WSC 63351 Nie ma b³êdów . Skipping Address 15-Airbags Address 16 ------------------------------------------------------- Controller: 8E0 953 549 F Component: Lenksáulenmodul 0308 Coding: 00012 Shop #: WSC 63351 1 B³¹d Zapis.: 01333 - Door Control Module: Rear Left (J388) 49-10 - No Communications - Intermittent Address 17 ------------------------------------------------------- Controller: 8E0 920 900 L Component: KOMBI+WEGFAHRS. RB4 D36 Coding: 00100 Shop #: WSC 00186 WAUZZZ8E83A225490 AUZ6Z0B0312309 2 Znalezione: 00562 - Sensor for Oil Level/Temperature (G266) 27-00 - Implausible Signal 01304 - Radio 49-00 - No Communications Address 46 ------------------------------------------------------- Controller: 8E0 959 433 AS Component: Komfortgerát T01 1210 Coding: 06976 Shop #: WSC 63351 7 Znalezione: 01336 - Data Bus for Comfort System 80-10 - Single-Wire Operation - Intermittent 01559 - Drivers Door 59-10 - Can't Unlock - Intermittent 01560 - Passenger Door 61-00 - Won't De-Safe 00933 - Electric Window Motor: Passenger Side (V148) 62-10 - No or Incorrect Adjustment - Intermittent 01332 - Door Control Module: Passenger Side (J387) 80-10 - Single-Wire Operation - Intermittent 01333 - Door Control Module: Rear Left (J388) 80-00 - Single-Wire Operation 01561 - Left Rear Door 61-00 - Won't De-Safe End ------------------------------------------------------- Edytowane 24 Sierpnia 2019 przez michasssxDD Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
przem8 778 Opublikowano 23 Sierpnia 2019 Udostępnij Opublikowano 23 Sierpnia 2019 (edytowane) Logi to się robi w blokach pomiarowych i musisz zrobić 2+33, 3+20, 115+118. Więcej w dziale diagnostyka. Ty wrzuciłeś błędy, których tłumaczenie i opis znajdziesz w necie, wszystko na Ross-Tech Wiki WIKI.ROSS-TECH.COM Masz problem z doładowaniem, sondą, n75, zajrzyj do zaworka jednokierunkowego odmy. Do zrobienia logi te co wspomniałem. Edytowane 23 Sierpnia 2019 przez przem8 1 Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
michasssxDD 0 Opublikowano 24 Sierpnia 2019 Autor Udostępnij Opublikowano 24 Sierpnia 2019 N75 wymieniony... Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
