Poduszki czujniki modul airbag
Matix131991
Witam. Jestem stluczce i wystrzeleniu wszystkich poduszek oraz pasow. Czy ktos wie czy w B9 wystarczy reset modulu airbag czy w gre wchodzi tylko wymiana modulu? Jezeli chodzi o czujniki sa one jednorazowe czyli wymagaja wymiany czy daja sie one zresetowac? Z gory dzieki
Wszystko zalezy jakie błedy sa zapisane w AIR BAG 15 , podaj scan .
Czujniki to czujnik nie wymieniasz
Airbag
    System description: Airbag10.44
    Software number: 8W0959655
    Software version: 0084
    Hardware number: 8W0959655
    Hardware version: H52
    Serial number: 003M600017C8
    ODX name: EV_AirbaAU10BPAAU736
    ODX version: 005012
    Long coding: AECCF0C00C800000585400F3C00C00000000
    Subsystems:
        System description: BeltPretRevFL
        Software version: 2033
        Hardware version: 205
        Serial number: 8W0857705A0258P01022
        Long coding: 88001B
        System description: BeltPretRevFR
        Serial number: 8W0857706A0258P01302
        Long coding: 88001B
        System description: SideSensor_Df
        Software version: 0887
        Hardware version: 1E2
        Serial number: 3577Y00991A537D4623%
        Long coding: 2D2D2D
        System description: SideSensor_Pf
        Serial number: 3587Y00A71A537D09441
        Long coding: 2D2D2D
        System description: SideSensor_Dr
        Software version: 0148
        Hardware version: 1C7
        Serial number: 3517700B11C3DEB4721H
        Long coding: 2D2D2D
        System description: SideSensor_Pr
        Serial number: 3527700B71C3DEB5722Q
        Long coding: 2D2D2D
    Trouble codes:
        B101A13 - Crash sensor for front airbag, driver side Open circuit
            static
                Date: 2020-05-16 22:21:16
                Mileage: 104809 km
                Priority: 2
                Malfunction frequency counter: 1
                Unlearning counter: 255
        B101B13 - Crash sensor for front airbag, front passenger side Open circuit
            static
                Mileage: 104809 km
                Priority: 2
        B10E913 - Center pedestrian protection crash sensor Open circuit
            static
                Mileage: 104809 km
                Priority: 2
        B148D04 - Driver side pedestrian protection crash sensor 2 Faulty
            Intermittent
                Date: 2020-05-16 22:21:14
                Mileage: 104809 km
                Priority: 2
        B148E13 - Passenger side pedestrian protection crash sensor 2 Open circuit
            static
                Mileage: 104809 km
                Priority: 2
        B100011 - Driver airbag igniter Short circuit to ground
            Intermittent
                Date: 2020-05-16 22:22:08
                Mileage: 104809 km
                Priority: 2
        B10001B - Driver airbag igniter Resistance too high
            static
                Mileage: 104809 km
                Priority: 2
                Malfunction frequency counter: 2
        B120E1A - Driver airbag release valve igniter Resistance too low
            static
                Mileage: 104809 km
                Priority: 2
        B100211 - Passenger airbag igniter Short circuit to ground
            static
                Mileage: 104809 km
                Priority: 2
        B10021B - Passenger airbag igniter Resistance too high
            Intermittent
                Mileage: 104809 km
                Priority: 2
        B100311 - Front passenger airbag igniter 2 Short circuit to ground
            static
                Date: 2020-05-16 22:21:17
                Mileage: 104809 km
                Priority: 2
                Malfunction frequency counter: 3
        B10031B - Front passenger airbag igniter 2 Resistance too high
            Intermittent
                Mileage: 104809 km
                Priority: 2
        B120F1A - Igniter for frt.pass. air bag release valve Resistance too low
            static
                Mileage: 104809 km
                Priority: 2
        B10061B - Driver side seat belt tension igniter Resistance too high
            static
                Mileage: 104809 km
                Priority: 2
        B10071B - Front passenger side seat belt tension igniter Resistance too high
            static
                Mileage: 104809 km
                Priority: 2
        B10091B - Driver side rear safety belt tension igniter Resistance too high
            static
                Mileage: 104809 km
                Priority: 2
        B10081B - Passenger side rear safety belt tension igniter Resistance too high
            static
                Mileage: 104809 km
                Priority: 2
        B100511 - Driver head curtain airbag igniter Short circuit to ground
            Intermittent
                Mileage: 104809 km
                Priority: 2
        B10051B - Driver head curtain airbag igniter Resistance too high
            static
                Mileage: 104809 km
                Priority: 2
        B100411 - Front passenger head curtain airbag igniter Short circuit to ground
            static
                Mileage: 104809 km
                Priority: 2
        B10131B - Driver side belt force limiter igniter Resistance too high
            static
                Mileage: 104809 km
                Priority: 2
        B10141B - Front passenger side belt force limiter igniter Resistance too high
            static
                Mileage: 104809 km
                Priority: 2
        B10151B - Igniter for battery interrupt Resistance too high
            static
                Mileage: 104809 km
                Priority: 2
        B102800 - Front crash data stored
            Intermittent
                Mileage: 104809 km
                Priority: 1
        B13BCF2 - Multiple collision brake No function
            static
                Date: 2020-05-16 23:35:09
                Mileage: 104809 km
                Priority: 2
                Unlearning counter: 205
        U112300 - Databus error value received
            static
                Date: 2020-05-20 12:24:38
                Mileage: 104809 km
                Priority: 2
Ja po wypadku wymieniłem poduszki, kurtyny i wszystkie pasy. Kasowałem błąd w sterowniku ale to niepotrzebny zabieg bo zapisuje tylko zdarzenie z której strony uderzyło. Tak dla potomnych jak podepnie kompa i widzi zdarzenie i z której strony. Nie zapomnij o bezpieczniku przy aku też tam jest. Żadnych czujników nie wymieniałem.
