Czy turbo walnięte?
tomasimo
Mam małe pytanie . Chyba turbo mi strasznie przeładowywuje . Na postoju przy obrotach normalnych turbo ma 998 bar ale np przy 2600 obr/min turbo łauje 1800 a powinno byc 1244 . Cos zepsute , a moze filtr powietrza do wymiany , dodam ze z egr leje mocno .
038 906 019 CG ,,1.9l R4 EDC G000SG 1366,
,Group A:,'013,,,,Group B:,'004,,,,Group C:,'011
,,Cyl 1,Cyl 2,Cyl 3,Cyl 4,,Engine speed,Spec start of inj.,Spec inj. duration,Synchro. angle,,Engine speed,Spec. intake press.,Actual intake press.,D.cycle MAP
,TIME,-2.8 to +2.8 mg/H,-2.8 to +2.8 mg/H,-2.8 to +2.8 mg/H,-2.8 to +2.8 mg/H,TIME,790-870,4BTDC-2ATDC,3-8 °Ck.,-3..+3°Ck.,TIME,2850-3150,2200-2400,2100-2600,35-80%
MARKER,STAMP, mg/R, mg/R, mg/R, mg/R,STAMP, /min, °ATDC, CF, CF,STAMP, /min, mbar,, %
,0.62,0.00,-0.47,0.24,0.19,1.25,882,0.0,7.1,1.1,0.00,882,1040.4,1006.2,19.9
,2.51,0.07,-0.52,0.26,0.16,3.13,882,0.0,7.1,0.6,1.87,882,1040.4,1006.2,19.9
,4.40,0.07,-0.49,0.21,0.14,5.02,1092,0.0,6.6,0.6,3.77,882,1040.4,1006.2,19.9
,6.27,0.16,-0.42,0.24,0.02,6.89,1197,0.6,6.6,1.1,5.65,1092,1050.6,1029.6,19.9
,8.14,0.19,-0.35,0.12,0.00,8.77,1323,0.9,6.6,0.6,7.52,1260,1071.0,1064.7,23.5
,10.03,0.12,-0.16,0.00,0.02,10.65,1407,1.2,6.6,1.1,9.39,1365,1081.2,1099.8,27.9
,11.92,-0.12,-0.07,0.00,0.16,12.54,1554,1.9,6.6,0.6,11.29,1449,1091.4,1134.9,29.9
,13.79,-0.33,-0.02,0.07,0.26,14.41,1764,2.2,6.6,0.6,13.17,1596,1132.2,1181.7,33.5
,15.68,-0.33,-0.02,0.07,0.26,16.30,1974,2.8,6.1,1.1,15.04,1827,1152.6,1298.7,36.3
,17.55,-0.33,-0.02,0.07,0.26,18.17,2226,3.4,5.1,0.6,16.91,2058,1173.0,1450.8,39.0
,19.42,-0.33,-0.02,0.07,0.26,20.04,2352,4.3,5.1,1.1,18.80,2247,1183.2,1602.9,41.4
,21.29,-0.33,-0.02,0.07,0.26,21.92,2625,6.8,4.1,0.6,20.67,2394,1234.2,1696.5,43.4
,23.16,-0.33,-0.02,0.07,0.26,23.79,2751,8.7,4.1,1.1,22.54,2646,1244.4,1813.5,47.0
,25.02,-0.33,-0.02,0.07,0.26,25.65,2478,5.3,-2.0,0.0,24.40,3591,1356.6,1848.6,80.5
,26.90,-0.33,-0.02,0.07,0.26,27.52,903,0.0,7.1,0.6,26.27,1554,999.6,1158.3,34.7
,28.77,-0.26,-0.16,0.05,0.31,29.37,882,0.0,7.1,0.6,28.14,882,1040.4,1029.6,19.9
,30.62,-0.05,-0.35,0.12,0.26,31.31,882,0.0,7.1,0.6,30.00,882,1040.4,1006.2,19.9
,32.62,0.00,-0.47,0.12,0.28,33.27,882,0.0,7.1,1.1,31.96,882,1040.4,1006.2,19.9
,34.55,0.07,-0.52,0.09,0.26,35.18,882,0.0,7.1,0.6,33.91,882,1040.4,1006.2,19.9
,36.43,0.07,-0.49,0.05,0.31,37.06,882,0.0,7.1,1.1,35.80,882,1040.4,1006.2,19.9
Na początek zrób komplet logów według instrukcji w dziale diagnostyka i wrzuć na tę stronkę : http://vaglog.rtnet.pl/. Tego co wkleiłeś teraz nie da się w żaden sposób zinterpretować- można oczopląsu dostać ;)
