volium1990 Opublikowano 12 Września 2012 Opublikowano 12 Września 2012 Hej Kupiłem kabel VCDS i jak się pewnie domyślacie odrazu polecialem podpiąć. Zrobiłem Auto-Scan i troche sie zmartwiłem bo wywaliło mi pare blędów, teraz nie wiem jak to ugryźć pomóżcie: Bledy: Address 01: Engine Labels: 038-906-019-AVF.lbl Part No: 038 906 019 CG Component: 1,9l R4 EDC G000SG 1366 Coding: 00002 Shop #: WSC 63351 VCID: 5EB89C26B66D83EC 2 Faults Found 17563 - Manifold Pressure Sensor (G71): Short to Plus P1155 - 35-00 - - 17994 - Engine Mount Solenoid Valves (N144/N145): Short to Plus P1586 - 35-10 - - - Intermittent Readiness: 0 0 X X X ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 Component: ABS/ESP front D1320 Coding: 04255 Shop #: WSC 38512 VCID: E5CA33CA133B5034 2 Faults Found 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 35-10 - - - Intermittent 01206 - Signal for Duration of Ignition Off Time 27-10 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 37: Navigation Labels: Redir Fail! Part No: 4B0 919 887 C Component: BNS 4.1 H05 BNO 0002 VCID: 336E1D926D6F7E84 1 Fault Found 01300 - Control Module for Navigation with CD-Rom (J401) 37-10 - Faulty - Intermittent ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: Part No: 8E0 959 433 J VCID: 38742ABE74099DDC 4 Faults Found 01561 - Left Rear Door 60-00 - Won't Safe 01562 - Right Rear Door 59-10 - Can't Unlock - Intermittent 01562 - Right Rear Door 61-10 - Won't De-Safe - Intermittent 01560 - Passenger Door 61-10 - Won't De-Safe - Intermittent ------------------------------------------------------------------------------- Address 56: Radio Labels: 8E0-035-1xx-56.lbl Part No: 8E0 035 186 Component: concert II GRO 0002 Coding: 00011 Shop #: WSC 63351 VCID: E4CC2ECE1801293C 2 Faults Found 01300 - Control Module for Navigation with CD-Rom (J401) 49-10 - No Communications - Intermittent 00858 - Connection; Radio ZF Output to Antenna Amplifier 36-10 - Open Circuit - Intermittent End ---------------------------------------------------------------------
Borys2409 Opublikowano 12 Września 2012 Opublikowano 12 Września 2012 Witam! Pod podpięciu komputera pod Audi A4 2,5 TDI wyskakuje mi błąd nr 668 ;nie działają mi żadne zegary, poduszka. Może listwa pod kierownicą jest do wymiany? Co możecie na to poradzić?
chudineze Opublikowano 12 Września 2012 Opublikowano 12 Września 2012 http://a4-klub.pl/diagnostyka-vag-32/baza-kodow-bladow-mozliwymi-awariami-rozwiazaniami-236498/
