Prośba o analizę logów statycznych i sprawdzenie błędów
Audi A4 B6 19TDI 131KM
VAGLOG - wklej logi z VCDS/VAG-COM
Oraz sprawdzenie błędów:
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 038 906 019 LJ
Component: 1,9l R4 EDC 0000SG 4910
Coding: 00002
Shop #: WSC 63251
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04255
Shop #: WSC 79014
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 AC
Component: A4 Klimaautomat 1319
Coding: 00000
Shop #: WSC 63251
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00111
Shop #: WSC 00012
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 S
Component: Lenksáulenmodul 0611
Coding: 01012
Shop #: WSC 63251
Address 17 -------------------------------------------------------
Controller: 8E0 920 930 R
Component: KOMBI+WEGFAHRS. RB4 D38
Coding: 00000
Shop #: WSC 65535
WAUZZZ8E64A122957 AUZ6Z0C0348655
Address 37 -------------------------------------------------------
Controller:
Note: Excessive Comm Errors
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 BA
Component: Komfortgerát TA7 1310
Coding: 06976
Shop #: WSC 63251
Address 55 -------------------------------------------------------
Controller: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63251
Address 56 -------------------------------------------------------
Controller:
End -------------------------------------------------------
Vag nie znajduje żadnych błędów co by mogło wskazywać na to że raczej wszystko z Twoją b6 w porządku, powiedz na jakiej podstawie podajesz logi, co się dzieje z autem że testujesz je Vagiem? Na kanale 37 masz Error bo nie masz nawigacji a na 56 nie wiem dlaczego, być może masz niestandardowe radio
silnik się dosyć mocno kołysze i coś czasami stuka na postoju, poza tym chciałem sprawdzić czy wszystko w porządku, co do błędów to pewnie dlatego że wymieniałem nawigację w samochodzie z RNS-D na RNS-E nie wiem czy mam to jakoś zaadoptować wagiem wymianę czy wystarczy skasować błędy, dzięki za pomoc :)
