Błędy Audi A4 B7
Witam.Bardzo proszę o pomoc w rozszyfrowaniu tych błędów.Sunday,28,September,2014,09:42:50:10074
VCDS Version: Beta 11.2.0
Data version: 20110305
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUDF78E06A121183 Mileage: 134720km/83711miles
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8E0 910 115 M HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0060
Revision: --H15--- Serial number:
Coding: 0104010A190F0120
Shop #: WSC 22302 444 82921
VCID: 2B51039FF1C5
1 Fault Found:
005668 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 134727 km
Time Indication: 0
Freeze Frame:
RPM: 1390 /min
Load: 25.5 %
Speed: 0.0 km/h
Temperature: 39.0°C
Temperature: 20.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.970 V
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E1 910 156 C HW: 09L 927 156 B
Component: AG6 09L 2.0TFSI USA 0030
Revision: --H01--- Serial number: 4094216
Coding: 0000002
Shop #: WSC 06335 000 00000
VCID: 2759FFAFED2D
3 Faults Found:
009783 - Torque Management Feedback Signal A
P2637 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 26
Mileage: 134150 km
Time Indication: 0
049412 - No Communication with Cruise Control Module
U0104 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 134727 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 21.0°C
T.B. Angle: 60.0°
049408 - No Communication with Engine Control Module (SAE:ECM/PCM)
U0100 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 134727 km
Time Indication: 0
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 E HW: 8E0 614 517 AL
Component: ESP8 quattro H05 0120
Revision: 00000000 Serial number: 00000000000000
Coding: 0004528
VCID: 295DF997FB39
3 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
Freeze Frame:
Fault Priority: 3
Fault Frequency: 63
Reset counter: 37
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4202
Hex Value: 0x0024
Hex Value: 0x019E
Hex Value: 0x0001
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0702
Hex Value: 0x0013
Hex Value: 0x8591
Hex Value: 0x0001
00493 - ESP-Sensor Unit (G419)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 27
Time Indication: 0
Freeze Frame:
Hex Value: 0x02C0
Hex Value: 0x4202
Hex Value: 0x001B
Hex Value: 0x34AD
Hex Value: 0x0001
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2832
Coding: 00000
Shop #: WSC 00000
VCID: 6DD5CD870F51
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0504
Coding: 00001
Shop #: WSC 06335
VCID: 3B7133DF01A5
No fault code found.
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H11 3540
Revision: 91H1135 Serial number: 0036N00105KF
Coding: 0032607
VCID: 3C7330C304AB
Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 002 0070
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 02041
Shop #: WSC 06335
VCID: 418D41376349
1 Fault Found:
01426 - Controls in Steering Wheel (E221)
49-10 - No Communications - Intermittent
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 951 G HW: 8E0 920 951 G
Component: KOMBI+WFS 4 H12 0110
Revision: 0110 Serial number: 00000000000000
Coding: 0023141
Shop #: WSC 01234 512 00000
VCID: 2E570A8BC2D7
5 Faults Found:
00779 - Outside Air Temp Sensor (G17)
010 - Open or Short to Plus - Intermittent
01176 - Key
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
01304 - Radio
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 D HW: 8E0 035 192 D
Component: RNS-E HIGH EU H72 0750
Revision: 00S Serial number: AUZBZ7E1968435
Coding: 0301717
Shop #: WSC 00000 785 00200
VCID: 2545F5A79721
7 Faults Found:
00532 - Supply Voltage B+
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 8
Reset counter: 21
Time Indication: 0
Date: 2013.07.09
Time: 23:10:47
Freeze Frame:
Voltage: 12.50 V
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 13
Reset counter: 21
Time Indication: 0
Date: 2013.07.09
Time: 20:34:24
Freeze Frame:
Voltage: 10.80 V
Mileage: 655350 km
Count: 1002
Clock: 17:49
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 102
Time Indication: 0
Date: 2005.02.10
Time: 00:24:53
Freeze Frame:
Mileage: 655350 km
Count: 1002
Clock: 00:24
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 254
Reset counter: 225
Time Indication: 0
Date: 2005.02.10
Time: 00:24:50
Freeze Frame:
Mileage: 655350 km
Count: 1002
Clock: 01:05
00857 - CD Changer Unit (R41)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 102
Time Indication: 0
Date: 2005.02.10
Time: 00:25:30
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 102
Time Indication: 0
Date: 2005.02.10
Time: 00:24:51
02446 - Disk Drive Mechanical Malfunction
Freeze Frame:
Fault Priority: 5
Fault Frequency: 82
Reset counter: 58
Time Indication: 0
Date: 2014.05.30
Time: 21:05:17
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BT
Component: Komfortgerát T7B 3332
Coding: 11832
Shop #: WSC 06335
VCID: 84030823BCDB
Subsystem 1 - Part No: 8E1959801G
Component: Tőrsteuer.FS BRM 0506
Subsystem 2 - Part No: 8E1959802E
Component: Tőrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801E
Component: Tőrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tőrsteuer.HR BRM 0506
5 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
01369 - Alarm triggered by Hood Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
00955 - Key 1
35-10 - - - Intermittent
00956 - Key 2
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0301717
VCID: 2545F5A79721
7 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 21
Time Indication: 0
Date: 2013.07.09
Time: 23:10:47
Freeze Frame:
Voltage: 12.50 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 13
Reset counter: 21
Time Indication: 0
Date: 2013.07.09
Time: 20:34:24
Freeze Frame:
Voltage: 10.80 V
Mileage: 655350 km
Count: 1002
Clock: 17:49
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 102
Time Indication: 0
Date: 2005.02.10
Time: 00:24:53
Freeze Frame:
Mileage: 655350 km
Count: 1002
Clock: 00:24
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 225
Time Indication: 0
Date: 2005.02.10
Time: 00:24:50
Freeze Frame:
Mileage: 655350 km
Count: 1002
Clock: 01:05
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 102
Time Indication: 0
Date: 2005.02.10
Time: 00:25:30
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 102
Time Indication: 0
Date: 2005.02.10
Time: 00:24:51
Freeze Frame:
Fault Priority: 5
Fault Frequency: 82
Reset counter: 58
Time Indication: 0
Date: 2014.05.30
Time: 21:05:17
