aras_85 0 Opublikowano 22 Lutego 2015 Udostępnij Opublikowano 22 Lutego 2015 (edytowane) ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Controller: 8E0 909 552 Component: 2.4L V6/5V 0004 Coding: 0011501 Shop #: WSC 63351 VCID: EBA9C4AF8A9D No fault code found. Readiness: 0000 1000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.LBL Controller: 8E0 614 517 Component: ABS/ESP front 1726 Coding: 04495 Shop #: WSC 06435 VCID: E5BDB2976C79 1 Fault Found: 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 35-00 - - ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-614-517.LBL Controller: Note: Can't Synch Baud Rate ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL Controller: 8E0 907 279 D Component: int. Lastmodul RDW 0203 Coding: 00011 Shop #: WSC 63351 VCID: 33199CCF122D No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-84.LBL Controller: 8E0 959 655 Component: Airbag 8.4E 5001 Coding: 0010602 Shop #: WSC 63351 VCID: F49BDFD3D7A3 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.LBL Controller: 8E0 953 549 L Component: Lenksáulenmodul 0308 Coding: 02001 Shop #: WSC 63351 VCID: 3C0BB7F33F73 1 Fault Found: 01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL Controller: 8E0 920 900 H Component: KOMBI+WEGFAHRS. RB4 D26 Coding: 00000 Shop #: WSC 21765 VCID: 29257EA7C0E1 WAUZZZ8E62A232016 AUZ6Z0A0340919 2 Faults Found: 00562 - Sensor for Oil Level/Temperature (G266) 29-10 - Short to Ground - Intermittent 00562 - Sensor for Oil Level/Temperature (G266) 27-00 - Implausible Signal ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL Controller: 8E0 959 433 AE Component: Komfortgerát T01 0315 Coding: 06720 Shop #: WSC 63351 VCID: 749B5FD357A3 1 Fault Found: 00532 - Supply Voltage B+ 37-10 - Faulty - Intermittent ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4Z7-907-357.LBL Controller: 4Z7 907 357 Component: dynamische LWR D07 Coding: 00060 Shop #: WSC 63351 VCID: 047B0F130703 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8E0-035-1xx-56.LBL Controller: 8E0 035 195 Component: symphony II NP2 0008 Coding: 00201 Shop #: WSC 00000 VCID: E4BBAF936743 No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 8E0-919-283-8E2.LBL Controller: 8E0 919 283 A Component: Parkingsyst. A4 RDW D08 Coding: 00104 Shop #: WSC 63351 VCID: 2E2F8DBBF90F 9 Faults Found: 01545 - Sensor for Parking Aid; Rear Left (G203) 31-00 - Open or Short to Ground 01546 - Sensor for Parking Aid; Rear Mid-Left (G204) 31-00 - Open or Short to Ground 01547 - Sensor for Parking Aid; Rear Mid-Right (G205) 31-00 - Open or Short to Ground 01548 - Sensor for Parking Aid; Rear Right (G206) 31-00 - Open or Short to Ground 01549 - Supply Voltage for Parking-Aid Sensor 29-00 - Short to Ground 01626 - Sensor for Parking-Aid; Front Right (G252) 31-00 - Open or Short to Ground 01627 - Sensor for Parking-Aid; Front Mid-Right (G253) 31-00 - Open or Short to Ground 01628 - Sensor for Parking-Aid; Front Mid-Left (G254) 31-00 - Open or Short to Ground 01629 - Sensor for Parking-Aid; Front Left (G255) 31-00 - Open or Short to Ground End -------------------------------------------------------------------------------------------------- Jak w opisie, nie dziala radio fm, parctronic, tylna klapa otwiera sie tylko z kluczyka, bardzo bym prosil o wyjasnienie bledow, szczegolnie pierwszy blad w silniku, pozdrawiam Edytowane 22 Lutego 2015 przez aras_85 Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
wrclaguna 343 Opublikowano 22 Lutego 2015 Udostępnij Opublikowano 22 Lutego 2015 w silniku nie masz błedów , skasuj i wklej ktore powracają . Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
aras_85 0 Opublikowano 22 Lutego 2015 Autor Udostępnij Opublikowano 22 Lutego 2015 w silniku nie masz błedów , skasuj i wklej ktore powracają . Address 01: Engine Labels: Redir Fail! Controller: 8E0 909 552 Component: 2.4L V6/5V 0004 Coding: 0011501 Shop #: WSC 63351 VCID: EBA9C4AF8A9D No fault code found. Readiness: 0000 1000 od czego to bedzie w takim razie? wszystkie powracaja z tej listy, ale nie wiem czy nie mam slabego aku, chociaz kreci ok, ale jak dluzej auto stoi to pojawia sie czerwona kontrola 'bremse', wyczytalem, ze to moze byc od slabego aku Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
wrclaguna 343 Opublikowano 22 Lutego 2015 Udostępnij Opublikowano 22 Lutego 2015 ALUMULATOR sprawdz 1 Fault Found: 00532 - Supply Voltage B+ Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
aras_85 0 Opublikowano 22 Lutego 2015 Autor Udostępnij Opublikowano 22 Lutego 2015 ok, poza tym bledy, ktore zostaja: Address 16 ------------------------------------------------------- Controller: 8E0 953 549 L Component: Lenksáulenmodul 0308 Coding: 02001 Shop #: WSC 63351 1 Fault Found: 01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent Address 46 ------------------------------------------------------- Controller: 8E0 959 433 AE Component: Komfortgerát T01 0315 Coding: 06720 Shop #: WSC 63351 1 Fault Found: 00532 - Supply Voltage B+ 37-10 - Faulty - Intermittent Address 76 ------------------------------------------------------- Controller: 8E0 919 283 A Component: Parkingsyst. A4 RDW D08 Coding: 00104 Shop #: WSC 63351 9 Faults Found: 01545 - Sensor for Parking Aid: Rear Left (G203) 31-00 - Open or Short to Ground 01546 - Sensor for Parking Aid: Rear Mid-Left (G204) 31-00 - Open or Short to Ground 01547 - Sensor for Parking Aid: Rear Mid-Right (G205) 31-00 - Open or Short to Ground 01548 - Sensor for Parking Aid: Rear Right (G206) 31-00 - Open or Short to Ground 01549 - Supply Voltage for Parking-Aid Sensor 29-00 - Short to Ground 01626 - Sensor for Parking-Aid: Front Right (G252) 31-00 - Open or Short to Ground 01627 - Sensor for Parking-Aid: Front Mid-Right (G253) 31-00 - Open or Short to Ground 01628 - Sensor for Parking-Aid: Front Mid-Left (G254) 31-00 - Open or Short to Ground 01629 - Sensor for Parking-Aid: Front Left (G255) 31-00 - Open or Short to Ground Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
wrclaguna 343 Opublikowano 22 Lutego 2015 Udostępnij Opublikowano 22 Lutego 2015 sprawdz Bezpiecznik od PDC Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
aras_85 0 Opublikowano 22 Lutego 2015 Autor Udostępnij Opublikowano 22 Lutego 2015 (edytowane) sprawdz Bezpiecznik od PDC sprawdzalem wszystkie nezpieczniki sprawne, chyba, ze jest on w jakims innym miejscu, obstawiam gdzie przerwa w obwodzie czy cos, bo nie dziala mi antena od radia, pdc ( dlugie pikniecie jak wrzuce wsteczny, pdc z przodu tez nie chodzi) tez nie dzia i klapa otwiera sie tylko recznie kluczykiem, moze przewod gdzies sie przelemal, zasniedziala jakas zlaczka czy cos, jakies propozycje? 01549 - Supply Voltage for Parking-Aid Sensor 29-00 - Short to Ground gdzie idzie ta wiazka kabli do pdc? obstawiam, ze to wina przewodu, dzis wymienilem sterownik pdc i to samo, nic nie pomoglo Edytowane 3 Marca 2015 przez aras_85 Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
