Pytanie o bledy 01274,00710
Witam mam pytanie pierwszy blad to od silniczka pod schowkiem pasazera, a czy te dwa pozostale ,00710 to nie jestem pewny ale kiedys mialem tak w b6 ze zerwalo sie sprzeglo sprezarki czy moze brak czynnika w ukladzie i stad te bledy ?
dziekuje pozdrawiam
                Address 08: Auto HVAC       Labels: Redir Fail!
Control Module Part Number: 8T1 820 043 AH    HW: 8T1 820 043 AH
  Component and/or Version: KLIMA 1 ZONE  H08 0180
           Software Coding: 24300000
            Work Shop Code: WSC 06335 123 12345
                      VCID: 77E9CEC39FCDBDBA2ECAF51-8022
3 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
            003 - Mechanical Failure - Intermittent
             Freeze Frame:
                    Fault Status: 00100011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 192654 km
                    Time Indication: 0
                    Date: 2018.11.08
                    Time: 17:56:21
             Freeze Frame:
                    Voltage: 14.30 V
                    Temperature: 22.0°C
                    Temperature: 12.0°C
                    Count: 11073
                    Count: 2027
                    Bin. Bits: 01000000
                    Bin. Bits: 10001011
                    Time: 255.00 s
00710 - Defroster Flap Positioning Motor (V107)
            001 - Upper Limit Exceeded
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 145
                    Mileage: 192815 km
                    Time Indication: 0
                    Date: 2018.11.13
                    Time: 21:09:32
             Freeze Frame:
                    Voltage: 13.20 V
                    Temperature: 14.0°C
                    Temperature: 11.0°C
                    Count: 11281
                    Count: 11610
                    Bin. Bits: 01000000
                    Bin. Bits: 10000011
                    Time: 36.00 s
             Freeze Frame:
                    Fault Status: 01100011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 192960 km
                    Time Indication: 0
                    Date: 2018.11.19
                    Time: 20:42:29
             Freeze Frame:
                    Voltage: 14.00 V
                    Temperature: 5.0°C
                    Temperature: 5.0°C
                    Count: 0
                    Count: 23701
                    Bin. Bits: 01000000
                    Bin. Bits: 10000011
                    Time: 98.00 s
