Analiza autoskanu
Cześć,
Pomoże ktoś zinterpretować błędy?
9457921 - Backup Battery
          B1916 04 [009] - Internal System Fault
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
65896 - Databus
          U1121 00 [008] - Missing Message
          [Tip-TNF 194781]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 163
                    Reset counter: 208
328449 - Expanded Bus Activity Active
          U1104 00 [013] - -
          [Tip-TNF 224118]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 168
                    Mileage: 121743 km
                    Date: 2023.11.26
                    Time: 13:32:55
                    Terminal 30A voltage: 11.83 V
                    Terminal 30B voltage: 11.85 V
                    Supply voltage for external components: 4.99 V
                    Reducing agent quality sensor: voltage terminal 31: 0.00 V
                    Pump for reducing agent: speed: 0 /min
                    Pump for reducing agent: current: 0.00 A
                    Reducing agent pump: operating state: OFF
                    Reducing agent pump: activation: 0.00 %
                    Reducing agent pump: end stage activation status: not active
                    Reducing agent pump: end stage temperature: 15 °C
                    Heating circuit 1 f. red. agent metering sys.: end stage temp.: 11 °C
                    Sensor for reducing agent tank temperature: temperature: 13 °C
                    Pressure sensor for reducing agent: voltage: 0.70 V
                    Sensor for reducing agent fill level: fill level height: 82 mm
                    Reducing agent quality sensor: urea concentration: 107.00 %
                    Sensor 2 for temp. reducing agent: act. value: 82.00 °C
                    Heating circuit 1 for reducing agent: power: 0 W
                    Heating circuit 1 for reducing agent: power set value: 0 W
                    Heating circuit 1 for reducing agent: power limitation: 130 W
                    Heating circuit 3 for reducing agent: power: 0 W
                    Heating circuit 3 for reducing agent: power set value: 0 W
                    Heating circuit 3 for reducing agent: power limitation: 78 W
                    Heating circuit 2 for reducing agent metering: power: 0 W
                    Heating circuit 2 for reducing agent metering: activation: not active
                    Dataset_Elements: F41049
66848 - Control Module for Reductant Quality
          U02A2 00 [013] - No Communications
          [Tip-TNF 242842]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 168
                    Mileage: 121743 km
                    Date: 2023.11.26
                    Time: 13:32:56
                    Terminal 30A voltage: 11.85 V
                    Pressure sensor for reducing agent: voltage: 0.69 V
Log-A4.txt
Ktoś pomoże?
