policja78 0 Opublikowano 25 Stycznia 2008 Udostępnij Opublikowano 25 Stycznia 2008 Prosze o przeanalizowanie logów mojego autka. "VAG-COM Version: Release 311.2-N Chassis Type: 8D - Audi A4 B5 Scan: 01,02,03,08,15,17,25,35,45,55,56 Address 01 ------------------------------------------------------- Controller: 028 906 021 F Component: 1,9l R4 EDC SG D3I Coding: 00000 Shop #: WSC 00000 1 Fault Found: 01117 - Generator Terminal DF Load Signal 27-10 - Implausible Signal - Intermittent Readiness: N/A Address 03 ------------------------------------------------------- Controller: 4D0 907 379 D Component: ABS BOSCH 5 7402 Coding: 0265108005 Shop #: BB 37402 No fault code found. Address 08 ------------------------------------------------------- Controller: 8D0 820 043 F Component: A4-KLIMAVOLLAUTOMAT_D64 Coding: 00043 Shop #: WSC 63133 7 Faults Found: 00787 - Temperature Sensor in Fresh Air intake duct (G89) 30-10 - Open or Short to B+ - Intermittent 00779 - Outside Air Temp Sensor (G17) 30-00 - Open or Short to B+ 00603 - Footwell/defroster Flap Positioning Motor (V85) 41-10 - Blocked or No Voltage - Intermittent 01272 - Positioning Motor for Central Flap (V70) 41-10 - Blocked or No Voltage - Intermittent 01274 - Air Flow Flap Positioning Motor (V71) 41-10 - Blocked or No Voltage - Intermittent 01273 - Fresh Air Blower (V2) 17-10 - Control Difference - Intermittent 00797 - Sunlight Photo Sensor (G107) 30-10 - Open or Short to B+ - Intermittent Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 8D0 919 033 A Component: B5_KOMBIINSTRUMENT D06 Coding: 00140 Shop #: WSC 41987 No fault code found. Address 25 ------------------------------------------------------- Controller: 4A0 953 234 Component: IMMO AUZ9Z0S8490948 D76 Coding: 00000 Shop #: WSC 00000 No fault code found. End ------------------------------------------------------- " Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Pikuś 2 Opublikowano 25 Stycznia 2008 Udostępnij Opublikowano 25 Stycznia 2008 A gdzie te logi?? Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
policja78 0 Opublikowano 28 Stycznia 2008 Autor Udostępnij Opublikowano 28 Stycznia 2008 Przepraszam, ale to są błędy podane jakie mi wyskoczyły. Pierwszy raz używałem programu i sam wida do końca niewiem jak zrobic właściwe logi...[br]Dopisany: 28 Styczeń 2008, 23:57 _________________________________________________Wreszcie znalazłem chwile wolnego czasu i zrobiłem właściwe logi. Bardzo prosze o analize : http://www.fotosik.pl/pokaz_obrazek/pelny/65b051cc5848ed58.html http://www.fotosik.pl/pokaz_obrazek/pelny/4dff0fc4bb96b094.html http://www.fotosik.pl/pokaz_obrazek/pelny/151449b0bcc90060.html http://www.fotosik.pl/pokaz_obrazek/pelny/6c936023124ae0d8.html http://www.fotosik.pl/pokaz_obrazek/pelny/93a2ee9550fb5b6f.html http://www.fotosik.pl/pokaz_obrazek/pelny/a67a84f18d07053c.html http://www.fotosik.pl/pokaz_obrazek/pelny/fabef0755ea09ed9.html Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
sokolnh 0 Opublikowano 28 Stycznia 2008 Udostępnij Opublikowano 28 Stycznia 2008 a dynamiczne ? kąt wtrysku do przestawienia Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
policja78 0 Opublikowano 28 Stycznia 2008 Autor Udostępnij Opublikowano 28 Stycznia 2008 Dynamicznych nie mam jak zrobić, ponieważ w laptopie mam uszkodzone ogniwa baterii... A co do temperatury silnika to chyba termostat mam do wymiany ponieważ wyższej temperatury nie łapie, na klimatroniku wyświetla taką samą temperature. Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
sokolnh 0 Opublikowano 28 Stycznia 2008 Udostępnij Opublikowano 28 Stycznia 2008 Dynamicznych nie mam jak zrobić, ponieważ w laptopie mam uszkodzone ogniwa baterii... A co do temperatury silnika to chyba termostat mam do wymiany ponieważ wyższej temperatury nie łapie, na klimatroniku wyświetla taką samą temperature. no to zmien jak najszybciej ten termostat i wrzuc dynamiczne probowałes skasowac te błedy ? Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
policja78 0 Opublikowano 28 Stycznia 2008 Autor Udostępnij Opublikowano 28 Stycznia 2008 Błędy wykasowałem, zostały 2 z klimatronika i airbagu. Po wymianie termostatu zrobie ponownie logi i sprawdze błędy to wrzuce tutaj. Dynamicznych nie mam możliwości zrobienia bez sprawnych akumulatorów w laptopie. Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
