[ALL B6] Faluje na niskich obrotach
Hej
Mój silnik faluje na niskich obrotach. same obroty w sobie są niskie bo koło 740 760
Prosze spojrzec na błędy jak i powiedzieć mi jakie logi zrobić
Licze na pomoc
VAG-COM Version: Release 409.1-S
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01: Engine
Controller: 8E0 906 018 AF
Component: 1,6LR4/2VSIMOS3 0002
Coding: 0006271
Shop #: WSC 00105
No fault code found.
Readiness: N/A
Address 03: ABS Brakes
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04175
Shop #: WSC 06435
Address 08: Auto HVAC
Controller: 8E0 820 043 AJ
Component: A4 Klimaautomat 2731
Coding: 00000
Shop #: WSC 00000
2 Faults Found:
00474 - Control Module for Immobilizer
49-10 - No Communications - Intermittent
01794 - Control Module Incorrect Chassis (VIN) Number
35-00 - -
Address 09: Cent. Elect.
Controller: 8E0 907 279
Component: int. Lastmodul RDW 0510
Coding: 00001
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16: Steering wheel
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00001
Shop #: WSC 63351
1 Fault Found:
Address 17: Instruments
Controller: 8E0 920 950 G
Component: KOMBI+WEGFAHRS. RB4 D22
Coding: 00000
Shop #: WSC 07777
WAUZZZ8E22A101729 AUZ6Z0A0195640
3 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
27-00 - Implausible Signal
01176 - Key
07-10 - Signal too Low - Intermittent
01304 - Radio
49-00 - No Communications
Address 46: Central Conv.
Controller: 8E0 959 433 AD
Component: Komfortgerát T85 0315
Coding: 06848
Shop #: WSC 63351
1 Fault Found:
01331 - Door Control Module: Driver Side (J386)
80-00 - Single-Wire Operation
End --------------------------------------------------------------------------------------------------
