perfectas Opublikowano 30 Marca 2008 Opublikowano 30 Marca 2008 Witam Dziś byłem na spocie świdnickiem i po podłączeniu do VAG pokazały mi się następujące błędy. Mam wielką prośbę o ich analizę :> VAG-COM Version: Release 311.2-N Chassis Type: 8D - Audi A4 B5 Scan: 01,02,03,08,15,17,25,35,45,55,56 Address 01 ------------------------------------------------------- Controller: 038 906 018 R Component: 1,9l R4 EDC 00SG 1632 Coding: 00002 Shop #: WSC 06335 2 Faults Found: 00522 - Engine Coolant Temperature Sensor (G62) 30-10 - Open or Short to B+ - Intermittent 00575 - Intake Manifold Pressure 17-10 - Control Difference - Intermittent Readiness: N/A Address 03 ------------------------------------------------------- Controller: 8E0 614 111 AB Component: ABS 5.3 FRONT D00 Coding: 0273004281 Shop #: BB 24548 No fault code found. Address 08 ------------------------------------------------------- Controller: 8L0 820 043 D Component: A4 KLIMAVOLLAUTOMAT_D75 Coding: 04143 Shop #: WSC 06335 1 Fault Found: 01274 - Air Flow Flap Positioning Motor (V71) 41-10 - Blocked or No Voltage - Intermittent Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 8D0 919 861 A Component: B5-KOMBIINSTR. VDO D09 Coding: 00140 Shop #: WSC 00000 IMMO-IDENTNR: AUZ7Z0W0612563 No fault code found. Address 25 ------------------------------------------------------- Controller: Bitte Adress Component: e 17 eingeben No Faults Found or DTCs not supported by controller or a communication error ocurred Address 35 ------------------------------------------------------- Controller: 8L0 862 257 L Component: ZV-Pumpe D10 Coding: 00000 Shop #: WSC 06335 1 Fault Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - End -------------------------------------------------------
adamq Opublikowano 30 Marca 2008 Opublikowano 30 Marca 2008 00522 - Engine Coolant Temperature Sensor (G62) 30-10 - Open or Short to B+ - Intermittent Czujnik temperatury chłodziwa (albo uszkodzony czujnik, albo otwarty obwód, czyt. niepodłączony, albo zwarcie). Sprawdź VAGiem czy w blokach pomiarowych wskazuje dobrą temperaturę. 00575 - Intake Manifold Pressure 17-10 - Control Difference - Intermittent Prawdopodobnie coś z doładowaniem. Na początek zrób logi pracy turbinki. 01274 - Air Flow Flap Positioning Motor (V71) 41-10 - Blocked or No Voltage - Intermittent Spróbuj zaadaptować klapki klimatronika VAGiem. 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - Błąd sporadyczny pompki zamka centralnego. U wielu osób widziałem ten błąd. Jeżeli nie będzie się często powtarzał, to można zignorować.
perfectas Opublikowano 1 Kwietnia 2008 Autor Opublikowano 1 Kwietnia 2008 Oki dzięki wielkie za odpowieź przy najbliższej okazji zrobię nowe logi.
