Diagnostyka VAG - coś z turbo
Zrobiłem u siebie logi, bo nagle zaczęło mi odcinać turbo. Widzę, że jest kilka błędów, także prosiłbym o diagnozę
1 Fault Found:
17564 - Manifold Pressure Sensor (G71): Open/Short to Ground
           P1156 - 35-10 -  -  - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
  Part No: 8E0 614 517
  Component: ABS/ESP front       1726
  Coding: 04255
  Shop #: WSC 06435
  VCID: E5C535A757A1
No fault code found.
Address 08: Auto HVAC        Labels: 8E0-820-043.lbl
  Part No: 8E0 820 043
  Component:   A4 Klimaautomat   0712
  Coding: 00000
  Shop #: WSC 63351
  VCID: DEB71A4B72F7
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
  Part No: 8E0 907 279 B
  Component: int. Lastmodul  RDW 1512
  Coding: 00001
  Shop #: WSC 00000
  VCID: 316D11F7D3E9
3 Faults Found:
00985 - Right Tail Light (M2)
           57-00 - Electric Circuit Failure
01503 - Bulb for 3rd Brake Light (M25)
01504 - Bulb for License-Plate Light (X)
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
  Part No: 8E0 959 655
  Component: Airbag 8.4E         4001
  Coding: 0010602
  Shop #: WSC 63351 000 00000
  VCID: F4E358E3EC7B
Address 16: Steering wheel        Labels: 8E0-953-549.lbl
  Part No: 8E0 953 549 F
  Component: Lenksáulenmodul     0308
  Coding: 00011
  Shop #: WSC 63351
  VCID: 366722EB3A87
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
  Part No: 8E0 920 900 G
  Component: KOMBI+WEGFAHRS. RB4 D25
  Coding: 00000
  Shop #: WSC 11111
  VCID: 285BFC93E033
  WAUZZZ8E42A153038     AUZ6Z0A0287952
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
  Part No: 8E0 959 433 AE
  Component: Komfortgerát T01    0315
  Coding: 06720
  Shop #: WSC 63351
  VCID: 74E3D8E36C7B
  Subsystem 1 - Part No: 8E1959801B
  Component: Tõrsteuer.FS BRM 0002
  Subsystem 2 - Part No: 8E1959802B
  Component: Tõrsteuer.BF BRM 0002
  Subsystem 3 - Part No: 8E0959801A
  Component: Tõrsteuer.HL BRM 0002
  Subsystem 4 - Part No: 8E0959802A
  Component: Tõrsteuer.HR BRM 0002
1 Fault Found:
01562 - Right Rear Door
           61-00 - Won't De-Safe
Address 55: Xenon Range        Labels: 4Z7-907-357.lbl
  Part No: 4Z7 907 357
  Component: dynamische LWR       D06
  Coding: 00060
  Shop #: WSC 63351
  VCID: 040388233CDB
End   ---------------------------------------------------------------------
17564 Czujnik ciśnienia w kolektorze ssącym - zwarcie do masy/przerwa
brak osprzętu / nie związany ze sprzętem
może być czujnik temperatury w dolocie
Dodaj logi statyczne i dynamiczne 010, oraz 011. Możliwe, że czujnik ciśnienia doładowania do wymiany.
VAGLOG - wklej logi z VCDS/VAG-COM
Zrobiłem dziś logi dynamiczne. Generalnie do objawów dodam to, że turbo działa jak auto uruchmię rano ... to tak przez 15 min jest ok. Potem się wyłączy. Drugi objaw taki, że jak w trakcie jazdy nagle turbo się obudzi i dam po pi... to po takiej szarży gasi mi się motor
Sprawdz wtyczke do czujnika ciśnienia doładowania... szukaj czujnika na podmianę...
No czujnik za 60 zł bodajże dostanę. Ostatnio wyczyściłem go trochę i przez chwilę było ok .. to pewnie coś z nim. A co generalnie mowią logi ?
No własnie ze cos nie halo z nim... :-)
