Potrzebuję pomocy w diagnozie z VCDS Poniżej logi
Tuesday,14,April,2015,17:09:17:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAUZZZ8KX License Plate:
Mileage: 256060km-159108mi Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 46 52 53 56 62 72 77
VIN: WAUZZZ8KX9A Mileage: 256060km/159108miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAGB) Labels: None
Part No SW: 03L 906 022 JQ HW: 03L 906 022 B
Component: R4 2,0L EDC H01 3176
Revision: 11H01---
Coding: 0104002C02072118
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM20TDI03L906022JQ A01003
ROD: EV_ECM20TDI03L906022C.rod
VCID: 7DFBE1B4EC0FAFF6FF5-8028
2 Faults Found:
5120 - Oxygen (Lambda) Sensor B1 S1
P2196 00 [237] - Signal too High (Rich)
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 255973 km
Date: 2015.04.11
Time: 10:21:22
4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 00 [108] - Incorrect Correlation
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Mileage: 255937 km
Date: 2015.04.10
Time: 16:51:05
Readiness: 1 1 0 0 0
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 T HW: 8T1 820 043 T
Component: KLIMA 1 ZONE H06 0140
Revision: A0000000 Serial number: 0114.08.080990
Coding: 34000001
Shop #: WSC 06325 123 12345
VCID: 42815248DD71100EC27-8017
1 Fault Found:
01271 - Positioning Motor for Temperature Flap (V68)
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 250
Mileage: 255913 km
Time Indication: 0
Date: 2015.04.08
Time: 20:41:35
Freeze Frame:
Voltage: 13.40 V
Temperature: 13.0°C
Temperature: 12.0°C
Count: 11221
Count: 11658
Bin. Bits: 00000000
Bin. Bits: 00000111
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 HW: 8K0 907 063
Component: BCM1 1.0 H22 0253
Revision: 01022001 Serial number: 00000000107715
Coding: 490042B54334BE000001000000005F5F401C460800000001000000
VCID: ECDD5CF00F75B67ED8B-80B9
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 010312 H07 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 941 531 B HW: 8K0 941 531 B
Component: E1 - LDS H07 0070
1 Fault Found:
01771 - Control Module for Headlight Range (J431)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 200
Mileage: 255731 km
Time Indication: 0
Date: 2015.03.29
Time: 19:24:00
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0094
Revision: 4GB20042 Serial number: 4200G088058186
Coding: 000303
VCID: 46894E58F1592C2EEEF-8013
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
1 Fault Found:
03041 - Energy Management Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 28
Reset counter: 218
Mileage: 255579 km
Time Indication: 0
Date: 2015.03.23
Time: 00:50:00
End ---------------------------------------------------------------------
Mialem ten sam problem - rozwiazaniem byla wymiana zestawu lancucha( u mnie ) rozrzadu. Calosc byla delikatnie rzecz ujmujac na skraju zerwania.
http://a4-klub.pl/index.php?/topic/313629-blad-engine-4096-bank-1-cmp-sensor-g40-engine-speed-sensor-g28/
Sprawa jest o tyle powazna ze jak juz sie zerwie to wchodzisz w inna kategorie cenowa naprawy.
Nie masz halogenów ? zle kodowanie w MCE 09
Mam halogeny, ale pogrzebałem VCDS em i coś przestawiłem.
Teraz już po omacku nie chcę grzebać.
A co do błędu 4096 to przygotowuję się do wymiany rozrządu i wtedy się zobaczy.
Sondę lambda kupiłem używaną za 20 Pln i jest wszystko ok.
Został mi tylko błąd 01771 - Control Module for Headlight Range (J431)
Dzięki za podpowiedzi :)
Edytowane przez HRUMPS
