_Bartek_ Opublikowano 20 Kwietnia 2015 Opublikowano 20 Kwietnia 2015 (edytowane) Witam Znajoma kupiła autko. Audi A3 3-drzwiowe, nawet nie wiem który rok. Dla mnie dość podejrzane. Na komputerze masa błędów. Proszę o opinię. Chassis Type: 1K0Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7DVIN: WAUZZZ8P54AXXXXX Mileage: 178360km/110827miles00-Steering Angle Sensor -- Status: OK 000001-Engine -- Status: Malfunction 001003-ABS Brakes -- Status: Malfunction 001008-Auto HVAC -- Status: Malfunction 001009-Cent. Elect. -- Status: Malfunction 001015-Airbags -- Status: OK 000016-Steering wheel -- Status: OK 000017-Instruments -- Status: OK 000019-CAN Gateway -- Status: Malfunction 001025-Immobilizer -- Status: OK 000042-Door Elect, Driver -- Status: OK 000044-Steering Assist -- Status: Malfunction 001046-Central Conv. -- Status: Malfunction 001047-Sound System -- Status: OK 000052-Door Elect, Pass. -- Status: OK 000056-Radio -- Status: Cannot be reached 11007D-Aux. Heat -- Status: Malfunction 0010-------------------------------------------------------------------------------Address 01: Engine Labels: 03G-906-016-BKC.lbl Part No SW: 03G 906 016 J HW: 028 101 138 3 Component: R4 1,9L EDC 0000SG 5347 Revision: 12345678 Serial number: AUX7Z0C8FN1017 Coding: 0000071 Shop #: WSC 66565 257 00032 VCID: 2A5000F6BAA53F4C8 Faults Found17058 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault P0674 - 000 - - Freeze Frame: RPM: 840 /min Torque: 62.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 13.91 V Bin. Bits: 00000100 Temperature: 16.2°C Bin. Bits: 1011000018051 - Please check DTC Memory of Electric Load Controller P1643 - 000 - - Freeze Frame: RPM: 1008 /min Torque: 50.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 13.38 V Bin. Bits: 00000111 Load: 51.4 % (no units): 1.018359 - Radiator Fan 2 (V177): Movement Restricted / Jammed P1951 - 000 - - Freeze Frame: RPM: 882 /min Torque: 36.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 13.76 V Bin. Bits: 00000111 Temperature: 73.8°C Duty Cycle: 25.1 %16990 - Internal Control Module: Processor Fault P0606 - 000 - - Freeze Frame: RPM: 2982 /min Torque: 0.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 10.94 V Bin. Bits: 00000000 (no units): 54.0 Torque: 0.0 Nm18058 - Powertrain Data Bus: Missing Message from Instrument Cluster P1650 - 000 - - - Intermittent Freeze Frame: RPM: 0 /min Torque: 174.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 12.08 V Bin. Bits: 00000100 Torque: 0.0 Nm Torque: 110.0 Nm18045 - Powertrain Data Bus: Missing Message from Electric Load Controller P1637 - 000 - - - Intermittent Freeze Frame: RPM: 0 /min Torque: 174.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 12.24 V Bin. Bits: 00000100 Bin. Bits: 11100000 (no units): 0.018043 - Powertrain Data Bus: Missing Message from A/C Controller P1635 - 000 - - - Intermittent Freeze Frame: RPM: 0 /min Torque: 174.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 12.24 V Bin. Bits: 00000100 Bin. Bits: 11100000 (no units): 144.017978 - Engine Start Blocked by Immobilizer P1570 - 000 - - - Intermittent Freeze Frame: RPM: 0 /min Torque: 174.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 11.78 V Bin. Bits: 00000100 Bin. Bits: 11100000 (no units): 0.0Readiness: 0 0 0 0 0-------------------------------------------------------------------------------Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No: 1K0 907 379 D Component: ESP FRONT MK60 0102 Coding: 0053894 Shop #: WSC 06435 000 00000 VCID: 336E1D926D6F7E843 Faults Found00474 - Control Module for Immobilizer 004 - No Signal/Communication - Intermittent01314 - Engine Control Module 013 - Check DTC Memory - Intermittent01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent-------------------------------------------------------------------------------Address 08: Auto HVAC Labels: 8P0-820-043.lbl Part No SW: 8P0 820 043 HW: 8P0 820 043 Component: KlimavollautomatH11 0130 Shop #: WSC 00000 000 00000 VCID: E9D23FFAFF2374542 Faults Found00483 - Control Module for Auxiliary Air Heater 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 141 Mileage: 178367 km Time Indication: 0 Date: 2015.04.19 Time: 18:44:46 Freeze Frame: ON01273 - Fresh Air Blower (V2) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 140 Mileage: 178082 km Time Indication: 0 Date: 2015.04.19 Time: 00:41:35 Freeze Frame: Temperature: 13.0°C Speed: 0.0 km/h (no units): 210.0 (no units): 32.0-------------------------------------------------------------------------------Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl Part No SW: 8P0 907 279 A HW: 8P0 907 279 A* Component: Bordnetz-SG 1.0 H29 0501 Revision: 00029000 Serial number: 00000000155376 Coding: Long Coding VCID: 3B7E35B2453FB6C4 Part No: 8P1 955 119 Component: Wischer WWS Audi350 0130 Coding: 16711696 Shop #: WSC 00000 10 Faults Found02395 - Parking Light Right Front (M3) 012 - Electrical Fault in Circuit - Intermittent02397 - Parking Light Right Rear (M2) 012 - Electrical Fault in Circuit - Intermittent02394 - Parking Light Left Front (M1) 012 - Electrical Fault in Circuit - Intermittent01314 - Engine Control Module 004 - No Signal/Communication - Intermittent00927 - Terminal 30 (Right) 011 - Open Circuit - Intermittent00906 - Horn (H1) 009 - Open or Short to Ground - Intermittent00926 - Terminal 30 011 - Open Circuit - Intermittent00834 - Signal for Activation of Heated Rear Window 009 - Open or Short to Ground - Intermittent01516 - Terminal 30; Left 011 - Open Circuit - Intermittent00059 - Terminal 30 for Interior Lighting 012 - Electrical Fault in Circuit - Intermittent-------------------------------------------------------------------------------Address 19: CAN Gateway Labels: 1K0-907-530.lbl Part No SW: 1K0 907 530 B HW: 1K0 907 951 Component: Gateway H08 0090 Revision: 08 Serial number: 2400103727CF56 Coding: 3D0F0B42070100 Shop #: WSC 06435 000 00000 VCID: 2648F4C6AEBD1B2C1 Fault Found01304 - Radio 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 254 Reset counter: 141 Mileage: 163749 km Time Indication: 0 Date: 2014.08.26 Time: 09:42:59-------------------------------------------------------------------------------Address 44: Steering Assist Labels: 1Kx-909-14x.lbl Part No: 1K1 909 144 D Component: EPS_ZFLS Kl.9 1201 Shop #: WSC 00000 000 00000 VCID: 2C5C06EEB051217C1 Fault Found02441 - Yellow Malfunction Lamp in Instrument Cluster 013 - Check DTC Memory - Intermittent Freeze Frame: Mileage: 8080 km Temperature: 12.0°C Voltage: 12.00 V Voltage: 11.90 V-------------------------------------------------------------------------------Address 46: Central Conv. Labels: 8P0-959-433.lbl Part No: 8P0 959 433 B Component: KSG H02 0040 Coding: 188800186D288505484A016000 Shop #: WSC 06435 000 00000 VCID: 3B7E35B2453FB6C4 Component: Sounder n.mounted Component: NGS n.mounted Component: IRUE n.mounted 3 Faults Found00352 - Terminal 30A 011 - Open Circuit - Intermittent00926 - Terminal 30 011 - Open Circuit - Intermittent00080 - Function Request - Sliding Roof 007 - Short to Ground - Intermittent-------------------------------------------------------------------------------Address 7D: Aux. Heat Labels: 1K0-963-235.lbl Part No SW: 1K0 963 235 C HW: 1K0 963 235 C Component: PTC-Element 0404 Revision: 00600000 Serial number: Shop #: WSC 00000 000 00000 VCID: 2B5E05F2B55F26441 Fault Found00361 - Heater Element for Auxiliary Heater (Z35) 014 - DefectiveEnd --------------------------------------------------------------------- Szyberdach w błędach, w aucie go nie ma... Być może jak wyżej. (tylko po co?!) Światłą świecą normalnie, błędy spalonych żarówek w komputerze jak widać. Nie działają czujniki otwartych drzwi, nie zapala się lampka po otwarciu auta z pilota. O odciętym lakierze na dachu i zaprószonym całym aucie nie wspomnę... Auto kupione w miejscowości z rej. EPA. Może od czyjegoś znajomego? Warto mu za to podziękować Edytowane 26 Maja 2015 przez _Bartek_
Homiczek Opublikowano 21 Kwietnia 2015 Opublikowano 21 Kwietnia 2015 skasuj i zobacz co zostanie.. ogólnie wygląda że po dzwonie blacharz nie pokasował pozostałości. no chyba że tak poskładali, że błędy wracają. kodowania bywają złe, bo np.ktoś wymienił moduł na taki z innego auta. albo co gorsze ktoś kupił i przyspawał dach bez szybra - a ten wcześniej był. ogólnie kiepsko to wygląda... można poszukać naklejki z kodami wyposażenia, albo w ASO wyciągnąć dane jakby naklejki nie było ( pewnie za $$)
