Herdas 1 Opublikowano 7 Czerwca 2015 Udostępnij Opublikowano 7 Czerwca 2015 Panowie po paru modyfikacjach mianowicie -zmiana radia z nieoryginalnego na Ori BNS plus zmieniarka do tego kiera multi -ostatnio pakiet światło w boczki naszło mnie na skanowanie całego auta i taki oto wynik: Sunday,07,June,2015,12:56:54:62939 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 12.12.0.0 Data version: 20130910 VIN: WAUZZZ8E05A573321 License Plate: Mileage: 237170km-147370mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008)) Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUZZZ8E05A573321 Mileage: 237170km/147370miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BKE.lbl Part No SW: 03G 906 016 FE HW: 028 101 212 7 Component: R4 1,9L EDC G000SG 9820 Revision: 12345678 Serial number: AUX6Z0E0074076 Coding: 0000071 Shop #: WSC 60925 124 07124 VCID: 6BD5212749702B46511-5000 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-910-517.clb Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT Component: ESP8 front H04 0180 Revision: 00000000 Serial number: 00000000000000 Coding: 0004401 Shop #: WSC 06325 000 09555 VCID: 264310139112D62ECEF-8073 1 Fault Found: 00285 - ABS Wheel Speed Sensor; Front Right (G45) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 13 Reset counter: 40 Time Indication: 0 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x0002 Hex Value: 0x00FF Hex Value: 0xFF99 Hex Value: 0x00FF ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 AK Component: A4 Klimaautomat 2831 Coding: 00000 Shop #: WSC 00000 VCID: 6ADB2423168A324E2A7-5000 3 Faults Found: 01172 - Temperature Sensor; Driver's Heated Seat (G59) 30-00 - Open or Short to Plus 01171 - Temperature Sensor; Passenger Side Heated Seat (G60) 30-00 - Open or Short to Plus 01336 - Data Bus for Comfort System 80-00 - Single-Wire Operation ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl Part No: 8E0 907 279 L Component: int. Lastmodul ECE 0504 Coding: 10001 Shop #: WSC 06325 VCID: 3B75D16729907BC6811-4A3A 1 Fault Found: 01336 - Data Bus for Comfort System 80-00 - Single-Wire Operation ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-94.lbl Part No SW: 8E0 959 655 G HW: 8E0 959 655 G Component: Airbag 9.41 H11 3530 Revision: 91H1135 Serial number: 0036M004ME2U Coding: 0033622 Shop #: WSC 06325 000 00000 VCID: 3B75D1677A907BC6811-806E Subsystem 1 - Serial number: 6332DRB4015D8C8D0 Subsystem 2 - Serial number: 6342DRB4018945A8T Subsystem 3 - Serial number: 6352ARB40064D039H Subsystem 4 - Serial number: 6362ARB400605E46I Subsystem 5 - Serial number: 63729RB4006A73A7Q Subsystem 6 - Serial number: 63829RB4006A6D0FY No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 Q Component: Lenksáulenmodul 0701 Coding: 02042 Shop #: WSC 06335 VCID: 4189A38F4B7C1116DBD-4A3A No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl Part No SW: 8E0 920 900 P HW: 8E0 920 900 P Component: KOMBI+WFS 3 H12 0030 Revision: 0030 Serial number: AUX6Z0E0074076 Coding: 0006101 Shop #: WSC 80093 222 69422 VCID: 3169F34FABDC81962BD-5072 1 Fault Found: 00470 - Combination comfort Databus in Single Wire 012 - Electrical Fault in Circuit ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl Part No SW: 8E0 920 900 P HW: 8E0 920 900 P Component: KOMBI+WFS 3 H12 0030 Revision: 0030 Serial number: AUX6Z0E0074076 Coding: 0006101 Shop #: WSC 80093 222 69422 VCID: 3169F34FABDC81962BD-5000 1 Fault Found: 00470 - Combination comfort Databus in Single Wire 012 - Electrical Fault in Circuit ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl Part No: 8E0 959 433 BP Component: Komfortgerát T85 3332 Coding: 07024 Shop #: WSC 06325 VCID: 800FE68B80F6581E143-4A3A Subsystem 1 - Part No: 8E1959801H Component: Tőrsteuer.FS BRM 0406 Subsystem 2 - Part No: 8E1959802B Component: Tőrsteuer.BF BRM 0205 4 Faults Found: 01336 - Data Bus for Comfort System 80-00 - Single-Wire Operation 00957 - Key 3 35-10 - - - Intermittent 01331 - Door Control Module; Driver Side (J386) 80-00 - Single-Wire Operation 01332 - Door Control Module; Passenger Side (J387) 80-00 - Single-Wire Operation End --------------------------------------------------------------------- Bład wgrupu 8 Auto HVAC 01171 i 01172 jest dlatego ze nie zamontowalem jeszce wazki na grzane fotele co sie niebawem stanie najbardziej interesuja mnie błedy z ABS -wywala kontrolke ABS i ESP na konsoli oraz IMO od jakiegos czasu mi pokazuje 00470 jak pozbyć się błedów Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
wrclaguna 342 Opublikowano 7 Czerwca 2015 Udostępnij Opublikowano 7 Czerwca 2015 ABS 03 ---> http://www.gerritspeek.nl/vag-com_dtc-00285.htmlKOMFORT 46 zmieniany był KOMFORT ? bo nie widzi silniczow tylnych drzwi ( moze kodowanie ) Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Herdas 1 Opublikowano 7 Czerwca 2015 Autor Udostępnij Opublikowano 7 Czerwca 2015 ABS 03 ---> http://www.gerritspeek.nl/vag-com_dtc-00285.html KOMFORT 46 zmieniany był KOMFORT ? bo nie widzi silniczow tylnych drzwi ( moze kodowanie ) ja bynajmiej nie zmienialem(czytaj:2lata) Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
wrclaguna 342 Opublikowano 9 Czerwca 2015 Udostępnij Opublikowano 9 Czerwca 2015 sprawdz adapatcje KOMFORTU : Kodowanie modułu komfortuWybieramy opcję CODING 07 (aby aktywować dane funkcje dodajemy do siebie poniższe wartości i ich sumę zapisujemy jako kodowanie sterownika):+1 – aktywacja alarmu (wersja dla UK i Irlandii)+2 – potwierdzenie aktywacji/deaktywacji alarmu przez odpowiednią sygnalizację diody w drzwiach kierowcy+4 – selektywny centralny zamek (podczas otwierania auta z pilota, jedno naciśnięcie przycisku otworzy tylko drzwi kierowcy, klapkę wlewu paliwa i wyłączy funkcję SAFE - drugie naciśnięcie otworzy pozostałe drzwi oraz odblokuje zamki maski i bagażnika)+8 – aktywacja alarmu+16 – blokada zamka klapy bagażnika po przekroczeniu 5km/h (zamek odblokuje się automatycznie po zwolnieniu poniżej 5km/h)+32 – blokada zamków wszystkich drzwi po przekroczeniu 10km/h (zamki zostają otwarte dopiero po wyjęciu kluczyka z zapłonu, bądź przez manualne otworzenie drzwi przy pomocy przycisków zamka centralnego w tapicerce drzwi kierowcy)+64 – aktywacja dodatkowych funkcji modułu komfortu (możliwość otwierania/zamykania szyb oraz szyberdachu przy pomocy zamka w drzwiach i pilota)+128 – pojazd z kierownicą po prawej stronie+256 – aktywacja czujników zbicia tylnych bocznych szyb (tylko dla nadwozia Avant wyposażonego w fabryczny alarm)+512 – potwierdzenie udanego zamknięcia wszystkich zamków przy pomocy pilota przez pojedyncze mrugnięcie kierunkowskazami+1024 – dodatkowe potwierdzenie aktywacji alarmu przez pojedynczy sygnał dźwiękowy z syreny alarmu+2048 – zasady dot. zasilania podnośników szyb (po wyłączeniu zapłonu i wyjęciu kluczyka ze stacyjki podnośniki szyb będą zasilane jeszcze przez 10 minut lub do czasu aż nie zostaną otwarte drzwi)+4096 – dodatkowe funkcje przeciwwłamaniowe W przypadku otwierania auta kluczykiem zostaną odblokowane tylko drzwi kierowcy, pozostałe drzwi i zamki zostaną odblokowane po włączeniu zapłonu. W przypadku gdy auto posiada fabryczny alarm po otwarciu drzwi kierowcy kluczykiem – zapłon musi zostać włączony w ciągu 15 sekund (w przeciwnym przypadku nastąpi wyzwolenie alarmu).+8192 – wyłączenie funkcji SAFE (tylko dla USA i Kanada – wersje samochodów przeznaczone na ten rynek mają tylko jeden silnik w zamku, pozostałe auta mają dwa – jeden zamyka zamek a drugi aktywuje funkcję SAFE czyli brak możliwości odblokowania auta z wewnątrz - włącznik w tapicerce drzwi kierowcy - po zamknięciu samochodu pilotem lub kluczykiem)+16384 – informacja dla silników szyb o zamontowanych szybach dwuwarstwowychAdaptacja modułu komfortuWariant modułu komfortu – ADAPTATION 10, kanał 61:0 – bez dodatkowego oświetlenia przestrzeni stóp, szyby tylnych drzwi w elektryce1 – bez dodatkowego oświetlenia przestrzeni stóp, szyby tylnych drzwi w korbach2 – dodatkowe oświetlenie stóp, szyby tylnych drzwi w elektryce3 – dodatkowe oświetlenie stóp, szyby tylnych drzwi w korbachAktywacje poszczególnych opcji komfortu – ADAPTATION 10, kanał 62:+1 – Komfortowe zamykanie szyb pilotem+2 – Komfortowe otwieranie szyb pilotem+4 – Komfortowe zamykanie szyb kluczykiem+8 – Komfortowe otwieranie szyb kluczykiem+16 – Komfortowe zamykanie szyberdachu pilotem+32 – Komfortowe otwieranie szyberdachu pilotem+64 – Komfortowe zamykanie szyberdachu kluczykiem+128 – Komfortowe otwieranie szyberdachu kluczykiem Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Herdas 1 Opublikowano 9 Czerwca 2015 Autor Udostępnij Opublikowano 9 Czerwca 2015 adaptacja 61- wartosc 1 z tylu korby 62- wartosc 95 auto tylko przod elektro bez szyber sprawdz adapatcje KOMFORTU : Kodowanie modułu komfortuWybieramy opcję CODING 07 (aby aktywować dane funkcje dodajemy do siebie poniższe wartości i ich sumę zapisujemy jako kodowanie sterownika):+1 – aktywacja alarmu (wersja dla UK i Irlandii)+2 – potwierdzenie aktywacji/deaktywacji alarmu przez odpowiednią sygnalizację diody w drzwiach kierowcy+4 – selektywny centralny zamek (podczas otwierania auta z pilota, jedno naciśnięcie przycisku otworzy tylko drzwi kierowcy, klapkę wlewu paliwa i wyłączy funkcję SAFE - drugie naciśnięcie otworzy pozostałe drzwi oraz odblokuje zamki maski i bagażnika)+8 – aktywacja alarmu+16 – blokada zamka klapy bagażnika po przekroczeniu 5km/h (zamek odblokuje się automatycznie po zwolnieniu poniżej 5km/h)+32 – blokada zamków wszystkich drzwi po przekroczeniu 10km/h (zamki zostają otwarte dopiero po wyjęciu kluczyka z zapłonu, bądź przez manualne otworzenie drzwi przy pomocy przycisków zamka centralnego w tapicerce drzwi kierowcy)+64 – aktywacja dodatkowych funkcji modułu komfortu (możliwość otwierania/zamykania szyb oraz szyberdachu przy pomocy zamka w drzwiach i pilota)+128 – pojazd z kierownicą po prawej stronie+256 – aktywacja czujników zbicia tylnych bocznych szyb (tylko dla nadwozia Avant wyposażonego w fabryczny alarm)+512 – potwierdzenie udanego zamknięcia wszystkich zamków przy pomocy pilota przez pojedyncze mrugnięcie kierunkowskazami+1024 – dodatkowe potwierdzenie aktywacji alarmu przez pojedynczy sygnał dźwiękowy z syreny alarmu+2048 – zasady dot. zasilania podnośników szyb (po wyłączeniu zapłonu i wyjęciu kluczyka ze stacyjki podnośniki szyb będą zasilane jeszcze przez 10 minut lub do czasu aż nie zostaną otwarte drzwi)+4096 – dodatkowe funkcje przeciwwłamaniowe W przypadku otwierania auta kluczykiem zostaną odblokowane tylko drzwi kierowcy, pozostałe drzwi i zamki zostaną odblokowane po włączeniu zapłonu. W przypadku gdy auto posiada fabryczny alarm po otwarciu drzwi kierowcy kluczykiem – zapłon musi zostać włączony w ciągu 15 sekund (w przeciwnym przypadku nastąpi wyzwolenie alarmu).+8192 – wyłączenie funkcji SAFE (tylko dla USA i Kanada – wersje samochodów przeznaczone na ten rynek mają tylko jeden silnik w zamku, pozostałe auta mają dwa – jeden zamyka zamek a drugi aktywuje funkcję SAFE czyli brak możliwości odblokowania auta z wewnątrz - włącznik w tapicerce drzwi kierowcy - po zamknięciu samochodu pilotem lub kluczykiem)+16384 – informacja dla silników szyb o zamontowanych szybach dwuwarstwowychAdaptacja modułu komfortuWariant modułu komfortu – ADAPTATION 10, kanał 61:0 – bez dodatkowego oświetlenia przestrzeni stóp, szyby tylnych drzwi w elektryce1 – bez dodatkowego oświetlenia przestrzeni stóp, szyby tylnych drzwi w korbach2 – dodatkowe oświetlenie stóp, szyby tylnych drzwi w elektryce3 – dodatkowe oświetlenie stóp, szyby tylnych drzwi w korbachAktywacje poszczególnych opcji komfortu – ADAPTATION 10, kanał 62:+1 – Komfortowe zamykanie szyb pilotem+2 – Komfortowe otwieranie szyb pilotem+4 – Komfortowe zamykanie szyb kluczykiem+8 – Komfortowe otwieranie szyb kluczykiem+16 – Komfortowe zamykanie szyberdachu pilotem+32 – Komfortowe otwieranie szyberdachu pilotem+64 – Komfortowe zamykanie szyberdachu kluczykiem+128 – Komfortowe otwieranie szyberdachu kluczykiem Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
