[B6 AVB] Problem z AIRBAG
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 038 906 019 LF
Component: 1,9l R4 EDC 0000SG 4907
Coding: 00002
Shop #: WSC 63251
WAUZZZ8E14A084263 AUZ6Z0C0237282
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04155
Shop #: WSC 06435
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 AB
Component: A4 Klimaautomat 1219
Coding: 00000
Shop #: WSC 63251
1 Fault Found:
01794 - Control Module Incorrect Chassis (VIN) Number
35-00 - -
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00001
Shop #: WSC 63251
1 Fault Found:
35-00 - -
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 S
Component: Lenksáulenmodul 0611
Coding: 00012
Shop #: WSC 63251
1 Fault Found:
35-00 - -
Address 17 -------------------------------------------------------
Controller: 8E0 920 930 R
Component: KOMBI+WEGFAHRS. RB4 D37
Coding: 00000
Shop #: WSC 11111
1 Fault Found:
01300 - Control Module for Navigation with CD-Rom (J401)
49-10 - No Communications - Intermittent
Address 37 -------------------------------------------------------
Controller: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0050
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 BA
Component: Komfortgerát TA7 1310
Coding: 06976
Shop #: WSC 06435
2 Faults Found:
01559 - Drivers Door
59-10 - Can't Unlock - Intermittent
01705 - Selection Switch for Mirror-Adjust (E48)
27-10 - Implausible Signal - Intermittent
Address 56 -------------------------------------------------------
Controller: 8E0 035 152 C
Component: chorus II GRO 0001
Coding: 01010
Shop #: WSC 63251
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
Address 76 -------------------------------------------------------
Controller: 8E0 919 283 A
Component: Parkingsyst. A4 RDW D08
Coding: 00114
Shop #: WSC 63251
End -------------------------------------------------------
Witam Ostatnio na spocie Kolega podłączył vaga pod moje autko i w rezultacie otrzymałem coś takiego.
ogólnie jest parę błędów, ale najbardziej interesuje mnie Skipping Address 15-Airbags jaka może być tego przyczyna ?
mile widziane tez info o innych błędach
co do błędu z navi to widziałem ze nie tylko ja taki mam ale to nie utrudnia pracy navi.
27-10 - Implausible Signal - Intermittent Czy ten błąd może być związany z niedziałającym podgrzewaniem jednego z lusterek ?
z góry THX
Tak miał zaznaczone w AutoScan i dlatego pominęło poduszki.
Cioś kombinowałeś z przekładaniem elementów?
Panel klimy z niepoprawnym VIN-em.
ja nie :(
no to pare rzeczy jest źle pokodowane i nie przuczone VINu :)
