July 6, 201610 yr Zmieniłem autko na Passat B7 i po przeskanowaniu auta wyszło parę błędów. Czy ktoś ze Szczecina byłby wstanie mi pomóc z ogarnięciem tego czy tylko serwis?? 1 Fault Found:5523 - Engine Start Blocked by ImmobilizerP1570 00 [096] - -Intermittent - Not Confirmed - Tested Since Memory ClearFreeze Frame:2 Faults Found:13701440 - Function Restricted due to Missing Message(s)U1111 00 [008] - -Intermittent - Confirmed - Tested Since Memory ClearFreeze Frame:Fault Status: 00000001Fault Priority: 6Fault Frequency: 15Reset counter: 233Mileage: 129061 kmDate: 2016.06.10Time: 05:57:049478421 - Diagnostic Line for Front Air BlowerB10A1 15 [008] - Open or Short to PlusIntermittent - Confirmed - Tested Since Memory ClearFreeze Frame:Fault Status: 00000001Fault Priority: 2Fault Frequency: 12Reset counter: 233Mileage: 129108 kmDate: 2016.06.12Time: 11:32:481 Fault Found:01207 - Control Module for Auxiliary Heater (J364)004 - No Signal/Communication - IntermittentFreeze Frame:Fault Status: 00100100Fault Priority: 6Fault Frequency: 63Reset counter: 234Mileage: 128142 kmTime Indication: 0Date: 2016.04.23Time: 19:45:52Freeze Frame:Term 15 OffVoltage: 12.30 VOFFONOFFOFFOFF1 Fault Found:00664 - Fuel gauge002 - Lower Limit Exceeded - IntermittentFreeze Frame:Fault Status: 00100010Fault Priority: 7Fault Frequency: 2Reset counter: 205Mileage: 129059 kmTime Indication: 0Date: 2016.06.09Time: 21:55:511 Fault Found:01207 - Control Module for Auxiliary Heater (J364)004 - No Signal/Communication - IntermittentFreeze Frame:Fault Status: 00100100Fault Priority: 2Fault Frequency: 66Reset counter: 234Mileage: 128142 kmTime Indication: 0Date: 2016.04.23Time: 19:45:501 Fault Found:00862 - Antenna for GPS Navigation (R50/R52)007 - Short to Ground - IntermittentFreeze Frame:Fault Status: 00100111Fault Priority: 5Fault Frequency: 2Reset counter: 234Mileage: 128493 kmTime Indication: 0Date: 2016.05.28Time: 09:51:594 Faults Found:02864 - Passenger's Door Handle Touch Sensor Incorrectly Installed000 - - - IntermittentFreeze Frame:Fault Status: 00100000Fault Priority: 4Fault Frequency: 1Reset counter: 219Mileage: 128142 kmTime Indication: 0Date: 2016.04.22Time: 18:32:3802866 - Rear Right Door Handle Touch Sensor Incorrectly Installed000 - -Freeze Frame:Fault Status: 01100000Fault Priority: 4Fault Frequency: 1Reset counter: 142Mileage: 128142 kmTime Indication: 0Date: 2016.04.22Time: 18:32:3800180 - Access/Start Authorization Antenna; Passenger Side (R135)012 - Electrical Fault in CircuitFreeze Frame:Fault Status: 01101100Fault Priority: 4Fault Frequency: 254Reset counter: 147Mileage: 0 kmTime Indication: 000191 - Passenger's Door Handle Touch Sensor (G416)004 - No Signal/CommunicationFreeze Frame:Fault Status: 01100100Fault Priority: 4Fault Frequency: 1Reset counter: 179Mileage: 129280 kmTime Indication: 0Date: 2016.06.24Time: 14:21:41Fault Found:01317 - Control Module in Instrument Cluster (J285)013 - Check DTC MemoryFreeze Frame:Fault Status: 01101101Fault Priority: 6Fault Frequency: 5Reset counter: 152Mileage: 128142 kmTime Indication: 0Freeze Frame:Term 15 OnReverse OFFCount: 3BBardzo proszę o pomoc w rozwiązaniu tych problemów.
July 6, 201610 yr Pierwsze co zrób to wykasuj błędy i zobacz za kilka dni co wróci. Wysłane z iPhone za pomocą Tapatalk
Create an account or sign in to comment
