Sprawdzennie log
Witam, prosiłbym o interpretację loga , dodam ze problem z dpf, podczas jazdy auto zgasło i wszystko się wyłączyło, możliwy jest problem z kluczykiem ?
Spoiler
Monday,25,September,2017,23:12:20:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAUZZZ8K39A223502   License Plate:
Mileage: 226710km-140871mi   Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 03 05 07 08 09 0E 10 15 16 17 19 1E 37 42 46 47 52 53 56
          62 69 72 77
VIN: WAUZZZ8K39A223502   Mileage: 226710km/140871miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CGKA)       Labels: 059-907-401-CAP.clb
   Part No SW: 8K1 907 401 K    HW: 8K1 907 401 A
   Component: 2.7TDI EDC17  H01 0008
   Revision: 15H01---
   Coding: 010C002C18070118
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_ECM27TDI0118K1907401K 001009
   ROD: EV_ECM27TDI.rod
   VCID: 3467FA5B9FCEB4BE40B-8061
4 Faults Found:
4807 - EGR System
          P0401 00 [096] - Insufficient Flow
          Intermittent - Not Confirmed - Tested Since Memory Clear
18660 - Start Interruption due to Insufficient Engine Speed
          P151D 00 [032] - -
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 32
                    Mileage: 226689 km
                    Date: 2017.09.23
                    Time: 17:55:56
5308 - Throttle Body Actuator Bank 1 (J338)
          P0638 00 [175] - Implausible Signal
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 12
                    Mileage: 226689 km
                    Date: 2017.09.23
                    Time: 17:55:59
5418 - Cylinder 6 Glow Plug Circuit (Q15)
          P0676 00 [109] - Electrical Fault
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 210131 km
                    Date: 2016.09.03
                    Time: 08:44:38
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
   Part No SW: 8K0 907 379 AG    HW: 8K0 907 379 AG
   Component: ESP8 front    H04 0240
   Revision: --------    Serial number: --------------
   Coding: 198D00
   Shop #: WSC 47091 141 00222
   VCID: 7EF31873E902AEEEE6F-802B
No fault code found.
Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.clb
   Part No SW: 8K0 907 064 M    HW: 8K0 907 064 M
   Component: BCM2 1.1      H80 0145
   Revision: 00002001
   Coding: 030200
   VCID: 3A7BD463B5AA42CE9A7-806F
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H37 0060
   Subsystem 2 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Component: J764 ELV MLB  H36 0042
Address 07: Control Head        Labels: Redir Fail!
   Part No SW: 8T0 035 769 C    HW: 4L0 035 730 B
   Component: MMI Cockpit     H60 0630
   Revision: C61030BE    Serial number: AUZ6Z3I3IB07S3
   Coding: 0164301
   Shop #: WSC 00493 128 73884
   VCID: 3D71DF7F648475F6BF5-8068
   Subsystem 1 - Part No: 8T0 919 609
   Component: E0380 BedienteilH08 0100
   Subsystem 2 - Serial number: 00000000254923
   Subsystem 3 - Serial number: 0114.03.090000000100010034˙
   Subsystem 4 - Serial number: 010034˙
Address 08: Auto HVAC (J255)       Labels: Redir Fail!
   Part No SW: 8T1 820 043 AA    HW: 8T1 820 043 AA
   Component: KLIMA 1 ZONE  H06 0150
   Revision: A1000000    Serial number: 01250320090582
   Coding: 36000000
   VCID: 70EF364BA356C89E643-8025
Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.clb
   Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
   Component: BCM1 1.0      H24 0253
   Revision: 05024001    Serial number: 00000000342905
   Coding: 690040B1003400010001000300005F5F0F1C260800000001000000
   VCID: 306FF64B63D6889E243-8065
   Subsystem 1 - Part No SW: 8K1 955 119 A    HW: 8T1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 250309  H06 0070
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 941 531 P    HW: 8K0 941 531 P
   Component: E1 - LDS  H07 0090
2 Faults Found:
01517 - Control Module for Trailer/Towing Sensor (J345)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 6
                    Fault Frequency: 254
                    Reset counter: 211
                    Mileage: 210125 km
                    Time Indication: 0
                    Date: 2016.08.31
                    Time: 18:25:00
02071 - Local Databus
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 202
                    Mileage: 226430 km
                    Time Indication: 0
                    Date: 2017.09.20
                    Time: 16:30:00
Address 0E: Media Player 1        Labels: None
   VCID: 55A167DFBCF48DB6975-8000
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 F    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0040
   Revision: 11001001    Serial number: 40140908211015
   Coding: 010003
   VCID: 3C77D27BBF9E7CFE88B-8069
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H27 0410
   Serial number: 0038JD1EZ73H
   Coding: 30343435363030303030554A304C384B3053
   ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 3C77D27BB79E7CFE88B-8069
   Crash sensor for side airbag; driver side:
   Serial number: 6334MSME46350B63B
   Crash sensor for side airbag; passenger side:
   Serial number: 6344MSME455419024
   Crash sensor for side airbag; rear driver side:
   Serial number: 6352QSME721C5738M
   Crash sensor for side airbag; rear passenger side:
   Serial number: 6362QSME621E0F0CS
   Crash sensor for front airbag; driver side:
   Serial number: 63732SME5D212F02$
   Crash sensor for front airbag; passenger side:
   Serial number: 63832SME581E4F06A
Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
   Part No SW: 8K0 953 568 F    HW: 8K0 953 568 F
   Component: Lenks.Modul   H16 0014
   Revision: --------    Serial number: 90315ICP0002Z
   Coding: 000017
   VCID: 3D71DF7FA48475F6BF5-8068
   Component: E221 - MFL  H02 0003
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 900 D    HW: 8K0 920 900 D
   Component: KOMBIINSTR.   H18 0224
   Revision: 00000000    Serial number: 9DT207L39
   Coding: 0F04100003000008000000
   VCID: 2B55E1274AF0EB46111-807E
Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
   Part No SW: 8T0 907 468 P    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0095
   Revision: EB500046    Serial number: 4600E093170144
   Coding: 000303
   VCID: 4E9388B31922FE6E56F-801B
   Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
   Component: J367-BDM  H06 0160
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Reset counter: 211
                    Mileage: 210125 km
                    Time Indication: 0
                    Date: 2016.08.31
                    Time: 18:25:59
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 8T1 035 110 C    HW: 8T1 035 110 C
   Component: MP3-Changer     H43 0390
   Revision: 00043003    Serial number: AUZ5ZBI8772991
   Shop #: WSC 00000 000 00000
   VCID: 2A5BE423850AF24EEA7-807F
Address 37: Navigation        Labels: Redir Fail!
   Coding: 0164301
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Component: TSG FA        H11 0250
   Revision:             Serial number: 0000008686368
   Coding: 011C02204000410001
   VCID: 4189A38FD87C1116DBD-8014
Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
   Revision: 00002001    Serial number: 0117791138
   Coding: 0100062020390040012002
Address 47: Sound System (J525)       Labels: 8T0-035-223-BAM.clb
   Part No SW: 8T0 035 223 AE    HW: 8T0 035 223 R
   Component: DSP Basic     H08 0300
   Revision: S2600000
   Coding: 010101
   VCID: 71E9334FA85CC1966BD-8024
Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Component: TSG BF        H11 0250
   Revision:             Serial number: 0000008693857
   VCID: 408FA68BD376181ED43-8015
Address 53: Parking Brake (J540)       Labels: 8K0-907-801-V1.clb
   Part No SW: 8K0 907 801 G    HW: 8K0 907 801 G
   Component: EPB Audi B8   H08 0080
   Revision: 00000003    Serial number: 00000000336659
   VCID: 3365F94792C0B386591-8066
Address 56: Radio        Labels: Redir Fail!
   Coding: 0164301
Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
   Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
   Component: TSG HL        H10 0251
   Revision:             Serial number: 0000008695095
   Coding: 010C02204000210001
   VCID: 4487AA9BC76E043EF0B-8011
Address 69: Trailer        Labels: 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Component: Anhaenger     H07 0070
   Coding: 0100000000000000
   VCID: 3663C05381B2A6AE7EF-8063
5 Faults Found:
02562 - Trailer; Brake Lamps
            015 - Cannot Be Tested at this Time - Intermittent - MIL ON
02563 - Trailer; Right Tail Lamps (M61)
            001 - Upper Limit Exceeded
02564 - Trailer; Left Tail Lamps (M60)
            001 - Upper Limit Exceeded - MIL ON
02565 - Trailer; Right Turn Signals (M63)
            010 - Open or Short to Plus - Intermittent - MIL ON
02566 - Trailer; Left Turn Signals (M62)
Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
   Component: TSG HR        H10 0251
   Revision:             Serial number: 0000008695119
Address 77: Telephone        Labels: 4E0-910-336.lbl
   Part No SW: 4E0 910 336 M    HW: 4E0 862 335
   Component: Handyvorb2      H20 1130
   Revision: 00000000    Serial number: 00000005309566
   Coding: 0020910
   VCID: 2C57E23B8FFEEC7E18B-8079
End   ---------------------------------------------------------------------
Wygląda że klapa gasząca zacięła się. Zdjemij rurę doprowadzającą powietrze do silnika (obok lampy od strony kierowcy) i rozruszaj klapkę. Jeżeli pomoże i odpali to wyczyść całość, ale bardzo możliwe że nastawnik do wymiany będzię bo sie mogł rozsypać w środku.
