Turbo problem 1,8 tfsi 170km
Witam mam problem z turbo ,wymieniony DV bez efektu.
Ktoś może podpowiedzieć co z tym dalej ,mam problem z VCDS -niema pełnej wersji nie widzę bloków pomiarowych
Oto komunikat błąd
1 Fault Found:
14914 - Boost Pressure Regulation
          P0299 00 [167] - Control Range Not Reached
          MIL ON - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 26676 km
                    Date: 2018.03.02
                    Time: 18:33:28
                    Engine speed: 2605.25 /min
                    Normed load value: 34.1 %
                    Vehicle speed: 56 km/h
                    Coolant temperature: 62 °C
                    Intake air temperature: 3 °C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 13.515 V
                    Unlearning counter according OBD: 40
                    Engine: operating status: PL
                    STATE_BPA[0]: OPM
                    Charge air pressure control valve position: target value-POSN_SP_BPA[0]: -0.00 %
                    Charge air pressure control valve position: actual value-POSN_BPA[0]: 0.061 %
                    MAP_MES_SAE: 92 kPa
                    Charge air pressure control valve activation pulse duty factor-PWM_BPA[0]: -29.562 %
                    Charge air pressure control valve voltage: position closed-VP_BPA_AD_BOL[0]: 4.3945 V
