[ALL B6] Proszę o analizę grupy 13 (korekcje PD)
,Group A:,'013,,,,Group B:, Not Running,,,,Group C:, Not Running
,,Cyl 1,Cyl 2,Cyl 3,Cyl 4,,,,,,,,,,
,TIME,-2.8 to +2.8 mg/H,-2.8 to +2.8 mg/H,-2.8 to +2.8 mg/H,-2.8 to +2.8 mg/H,TIME,,,,,TIME,,,,
Marker,STAMP, mg/str, mg/str, mg/str, mg/str,STAMP,,,,,STAMP,,,,
,0.00,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,0.34,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,0.72,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,1.07,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,1.43,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,1.79,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,2.15,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,2.50,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,2.85,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,3.21,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,3.57,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,3.93,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,4.29,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,4.66,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,5.05,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,5.43,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,5.83,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,6.22,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,6.61,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,7.00,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,7.39,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,7.78,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,8.17,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,8.56,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,8.95,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,9.34,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,9.73,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,10.12,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,10.51,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,10.90,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,11.26,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,11.62,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,11.97,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,12.33,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,12.69,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,13.05,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,13.41,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,13.77,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,14.13,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,14.49,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,14.85,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,15.21,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,15.57,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,15.93,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,16.29,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,16.66,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,17.02,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,17.41,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,17.81,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,18.20,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,18.59,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,18.98,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,19.36,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,19.71,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,20.07,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,20.43,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,20.80,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,21.15,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,21.51,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,21.86,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,22.22,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,22.58,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,22.94,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,23.30,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,23.66,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,24.02,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,24.38,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,24.74,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,25.10,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,25.46,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,25.82,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,26.18,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,26.54,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,26.90,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,27.26,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,27.64,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,28.03,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,28.42,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,28.81,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,29.20,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,29.59,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,29.95,-1.25,-0.16,0.66,0.73,,,,,,,,,,
,30.31,-1.25,-0.16,0.66,0.73,,,,,,,,,,
jaki przebieg ??
jedna troche przypchana jest ;) a reszta raczej nie ma co sie przejmowac :)
ja mam podobne przy przebiegu 300 kkm ;)
jedna pompka odstaje ...
pewnie przez to ze masz zalanego castrola i wkładke KN a to TDI tego nie lubi :)
mam motula specific 5w30 SAE, czyli 1 pd leje co moze wystarczy to uszczelnic ???
:polew: :polew: :polew: :polew: :polew: :polew: :polew:
a jak to uszczelnisz :):polew: :polew: :polew: :polew: :polew: :polew: :polew:
i nie leje tylko przypchany jest ;)
nic nie ruszaj zalej STP
supr koncentrat do diesli na cały zbiornik moze pomoże
:polew: :polew: :polew: :polew: :polew: :polew: uszczelnić no rozjebałes mnie
sam robisz programy a nie znasz podstaw :polew: :polew:
takie korekcje sa ok nie przejmuj sie az tak strasznie a jak cie to denerwuje to kup nowe :)
zostaw i jezdzij ...
jak jak przeciesz jest miedziana uszczelka pod pompka a potem o ring i niewiem z czego sie smiejesz czlowieczku ,problem jest taki ze jak sie silnik nagrzeje to telepoce silnikiem i moze to byc powod
jak telepie motorem to moze pompka pada ... zrob 018 i 023 ...
poza tym bylo kilka postów na ten temat poszukaj ... :wink4:
statyczne czy dynamiczne :kox:
najpierw statyczne ... na zimnym i na rozgrzanym ...
śmieje sie z tego co piszesz
to ze telepie to jest jeszcze przynajmniej jakies 10 róznych przyczyn ja z tym walcze od 1,5 roku i jakos mi sie nie udało
i zacznij lepiej precyzowac to o co ci chodzi
a poza tym było na forum na ten temat juz obszerny topic wiec radze poszukać
mam duzo lepsze korekcje i tez telepie wiec raczej nie lezy to po tej stronie
hmmm to moze kola dwumas albo plecionka bo co jeszcze ????
dwumas by było słychać
plecionka jak najbardziej
moze którys wieszak w wydechu
moze poduszka silnika / skrzyni
moze zły kąt / korekcja rozrządu
kurde pewnie jeszcze by sie cos znalazło
spróbuj wgrac seryjny program moze sie poprawi
HGW to jest naprawde trudny temat
kiedys pamietam jak jeden z forumowiczów zrobił jedeną rzecz :) zdjął obudowe wypia sterowanie PDkami i pomogło podobno tego nie robiełm szczerze Ci powiem ale mozesz spróbować
n o wlasnie ze mam juz serie i dalej ,a jak by plecionka to tak by bujalo silnikiem na prawo i lewo ???
poduszki pod silnikiem ??
hmmmm poduszkiii to czemu tylko na cieplym silniku telepoce
no jak na zimnym sa wieksze obroty to niweluje te telepanie mam to samo
