[B6 BFB] Analiza błędów BRYNIOWOZU
Rzućcie okiem i niech się fachowcy wypowiedzą w temacie co dolega i co zrobić
W imieniu Pani Dyrektor dziękuję z góry :>
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 03 -------------------------------------------------------
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04475
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 H
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63251
1 Fault Found:
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-00 - Open or Short to B+
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00011
Shop #: WSC 63351
Address 15 -------------------------------------------------------
Controller: 8E0 959 655 B
Component: Airbag 8.4EP 2000
Coding: 0010602
Shop #: WSC 63251
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 02012
Shop #: WSC 63351
1 Fault Found:
01304 - Radio
49-10 - No Communications - Intermittent
Address 17 -------------------------------------------------------
Controller: 8E0 920 900 L
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 01100
Shop #: WSC 00260
WAUZZZ8E53A224328 AUZ6Z0B0285562
1 Fault Found:
01176 - Key
07-10 - Signal to Low - Intermittent
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AR
Component: Komfortgerát T85 1310
Coding: 06976
Shop #: WSC 63351
Address 55 -------------------------------------------------------
Controller: 4Z7 907 357
Component: dynamische LWR D08
Coding: 00060
Shop #: WSC 63351
Address 56 -------------------------------------------------------
Controller: 8E0 035 186
Component: concert II GRO 0008
Coding: 01404
Shop #: WSC 00450
1 Fault Found:
00852 - Loudspeaker(s): Front
36-10 - Open Circuit - Intermittent
Address 76 -------------------------------------------------------
Controller: 8E0 919 283 A
Component: Parkingsyst. A4 RDW D08
Coding: 00114
Shop #: WSC 63351
1 Fault Found:
01545 - Sensor for Parking Aid: Rear Left (G203)
37-00 - Faulty
End -------------------------------------------------------
mcm dzięki za logi :notworthy:, za tytułowanie będą baty na następnym spocie :gwizdanie:
Bardzo proszę o analizę, przede wszystkim zobaczcie co z tym parktronickiem zrobić :>
zmieniłem :wink4:[br]Dopisany: 20 Marzec 2009, 22:28_________________________________________________tyle co ja znalazłem
01176 - Key Faulty: Signal too Low
Possible Causes
* Low voltage in key-battery
* Bad connections between immo reader coil and immo control module
Possible Solutions
* Replace key-battery
* If more than one key acts like this, check / clean the connector between immo reader coil and immo control module, the contacts tend to oxidize
01304 - Radio
01304 - Radio: No Signal/Communication
Possible Symptoms
* Reduced Functionality
Possible Causes
* Communication from/to Radio faulty
* Wiring/Connectors from/to Radio faulty
Possible Solutions
* Check Communication from/to Radio
o See Measuring Value Blocks (MVB)
* Check Wiring/Connectors from/to Radio
01304 - Radio: Implausible Signal
Possible Symptoms
Possible Causes
* Radio Coding incorrect
Possible Solutions
* Check Radio Coding
00604
nl Potentiemeter (G113) in Motor voor Recirculatieklep (V71)
du Potentiometer (G113) im Stellmotor (V71) (für Staudruckklappe)
en Potentiometer (G113) in Positioning Motor for Air Flow Flap (V71)
Extra info bij de foutcodes. Intermittent
Mogelijke verschijnselen:
* Onbekend
Mogelijke oorzaken:
* Bedrading en aansluitingen
* G113 defect
Mogelijke oplossingen:
* Check meetwaardeblokken
* Repareer bedrading en aansluitingen
* Vervang G113
00852 - Loudspeaker(s) Front
00852 - Loudspeaker(s) Front: Open Circuit
Possible Causes
* Wiring/Connectors from/to Front Loudspeaker(s) faulty
* Front Loudspeaker(s) faulty
Possible Solutions
* Check Wiring/Connectors from/to Front Loudspeaker(s)
* Check Front Loudspeaker(s)
Special Notes
* Due to 3rd Party Installations (e.g. Phone Kits) the Open Circuit Recognition may be triggered.
01545
nl Sensor voor Parkeerhulp achter-links (G203)
du Geber für Einparkhilfe hinten links (G203) Kurzschluß nach Plus - Unterbrechung/Kurzschluß nach Masse - unplausibles Signal
en Sensor for PDC Rear Left (G203)
* Beperkte werking van de parkeerhulp
Mogelijke oorzaken:
* Lees het desbetreffende measuringblock uit
* Draadbreuk of kortsluiting van de ECU naar de sensor (G203)
* G203 defect
* Kontroleer bedrading en aansluitingen van de sensor G203 naar de ECU
* G203 vervangen
trzeba by to przetłumaczyć na nasze :)
jesli chodzi o parktronik,to czujnik padl, lub kabel sie oderwal :wink4:
glosniki,sprawdzilbym wiazke w drzwiach,moze sie kabel zlamal i nie styka
immo-spiralka na stacyjce do czyszczenia(styki)
radio-kostki,antena do sprawdzenia(jesli dziala) jesli radio nie dziala,to blad przy wpisywaniu kodu
klima-silniczek od klapki nawiewu-niedziala prawidlowo, z jakichs przyczyn nie domyka sie i/lub sie nie otwiera do konca
nie ma za co Aniu... :wink4: darmo dostalem i za darmo oddaje... :wink4: ....a tak poza tym,to po to tutaj jestesmy...
