nyper123 Opublikowano 24 Grudnia 2009 Opublikowano 24 Grudnia 2009 wykonałem autoscan , czy trzeba wykonac analize innym sposobem aby wykryć więcej nieprawidłowości. co do błedów ABS to wiem ze mam zły czujnik VAG-COM Version: Release 311.2-N Chassis Type: 8D - Audi A4 B5 Scan: 01,02,03,08,15,17,25,35,45,55,56 Address 01 ------------------------------------------------------- Controller: 8D0 907 557 B Component: 1,6L R4/2V MOTR HS D08 Coding: 04001 Shop #: WSC 00000 10 Faults Found: 01249 - Fuel Injector for Cylinder 1 (N30) 26-10 - Output Open - Intermittent 01250 - Fuel Injector for Cylinder 2 (N31) 26-10 - Output Open - Intermittent 01251 - Fuel Injector for Cylinder 3 (N32) 26-10 - Output Open - Intermittent 01252 - Fuel Injector for Cylinder 4 (N33) 26-10 - Output Open - Intermittent 17978 - Engine Start Blocked by Immobilizer P1570 - 35-10 - - - Intermittent 00670 - Throttle Position Sensor (G127) 27-10 - Implausible Signal - Intermittent 00532 - Supply Voltage B+ 07-10 - Signal to Low - Intermittent 00561 - Mixture Adaptation 12-10 - Adaptation Limit (Mul) Exceeded - Intermittent 17736 - Knock-Control: Cylinder 4: Regulation Limit Exceeded P1328 - 35-10 - - - Intermittent 16885 - Vehicle Speed Sensor: Implausible Signal P0501 - 35-10 - - - Intermittent Readiness: N/A Address 03 ------------------------------------------------------- Controller: 4D0 907 379 D Component: ABS BOSCH 5 7402 Coding: 0265108005 Shop #: BB 37402 2 Faults Found: 00290 - ABS Wheel Speed Sensor: Rear Left (G46) 30-10 - Open or Short to B+ - Intermittent 00285 - ABS Wheel Speed Sensor: Front Right (G45) 30-00 - Open or Short to B+ Address 08 ------------------------------------------------------- Controller: 8D0 820 043 D Component: A4-KLIMAVOLLAUTOMAT_D63 Coding: 00000 Shop #: WSC 20510 1 Fault Found: 01273 - Fresh Air Blower (V2) 17-10 - Control Difference - Intermittent Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 8D0 919 033 C Component: B5-KOMBIINSTRUMENT D03 Coding: 00142 Shop #: WSC 00011 1 Fault Found: 00771 - Fuel Level Sensor (G) 30-10 - Open or Short to B+ - Intermittent Address 25 ------------------------------------------------------- Controller: 4A0 953 234 Component: IMMO AUZ9Z0S2291352 D76 Coding: 00000 Shop #: WSC 00000 No fault code found. End -------------------------------------------------------
