[B6 AVF] prośba o analize logów
Witam
przeprowadzałem je pierwszy raz :)
Thursday 28 June 2007 20:22:45
038 906 019 LJ 1.9l R4 EDC 0000SG 4910
Group A: '003
Engine speed MAF (specified) MAF (actual) EGR duty cycle
TIME 790-870 230-310 210-350 40-75%
MARKER STAMP /min mg/R mg/R %
43.95 1554 850.0 695.8 4.8
44.36 1659 850.0 847.7 4.8
44.76 1806 850.0 1024.1 4.8
45.16 1932 850.0 1205.4 4.8
45.56 2100 850.0 1029.0 4.8
45.95 2268 850.0 1078.0 4.8
46.35 2457 850.0 1112.3 4.8
46.74 2583 850.0 1151.5 4.8
47.13 2730 850.0 1141.7 4.8
47.52 2898 850.0 1131.9 4.8
47.92 3045 850.0 1107.4 4.8
48.31 3171 850.0 1102.5 4.8
48.69 3318 850.0 1092.7 4.8
49.09 3444 850.0 1107.4 4.8
49.48 3570 850.0 1112.3 4.8
49.87 3696 850.0 1092.7 4.8
50.26 3822 850.0 1073.1 4.8
50.65 3927 850.0 1063.3 4.8
51.04 4053 850.0 1038.8 4.8
51.43 4137 850.0 1024.1 4.8
51.82 4263 850.0 1004.5 4.8
52.21 4389 850.0 984.9 4.8
52.60 4473 850.0 965.3 4.8
Group A: '008
Engine speed IQ driver's req IQ via rpm(Torq) IQ via MAF
TIME 2850-3150 65-70 47-51 47-60
MARKER STAMP /min mg/R mg/R mg/R
0.00 1512 50.8 48.0 22.0
0.39 1512 69.7 48.0 28.0
0.78 1533 69.7 48.9 35.7
1.17 1596 69.7 50.0 41.5
1.56 1680 69.7 51.9 51.9
1.95 1785 69.7 54.4 57.6
2.34 1911 69.7 55.7 57.6
2.73 2037 69.7 54.6 57.9
3.13 2184 69.7 53.8 57.6
3.53 2331 69.7 53.0 57.6
3.92 2457 69.7 52.7 57.4
4.32 2583 69.5 52.2 57.1
4.72 2709 68.9 51.6 56.8
5.11 2835 68.4 51.3 56.3
5.50 2940 68.1 51.1 56.0
5.89 3066 67.5 50.8 55.7
6.29 3150 67.3 50.2 55.5
6.68 3276 66.7 50.0 55.2
7.07 3381 66.4 49.4 55.2
7.47 3465 66.2 49.1 54.9
7.85 3549 65.9 48.6 54.6
8.25 3633 65.6 48.3 54.6
8.64 3759 65.1 48.0 54.4
9.03 3843 64.8 47.5 54.1
9.42 3948 64.5 47.2 53.8
9.81 4032 64.0 46.7 53.5
10.20 4137 63.7 45.6 52.7
Group A: '011
Engine speed Spec. intake press. Actual intake press. D.cycle MAP
TIME 2850-3150 2200-2400 2100-2600 35-80%
MARKER STAMP /min %
1.17 1575 2004.0 1380.0 21.9
1.57 1659 2076.0 1608.0 23.1
1.97 1764 2172.0 1908.0 41.0
2.39 1932 2244.0 2232.0 53.8
2.79 2058 2280.0 2448.0 66.1
3.17 2205 2304.0 2244.0 56.2
3.57 2394 2328.0 2244.0 57.0
3.97 2541 2340.0 2304.0 59.0
4.36 2709 2340.0 2352.0 62.6
4.75 2856 2340.0 2352.0 63.8
5.14 3024 2340.0 2340.0 65.3
5.53 3150 2340.0 2328.0 64.9
5.92 3318 2340.0 2304.0 64.9
6.31 3423 2340.0 2328.0 65.7
6.71 3570 2340.0 2328.0 66.1
7.10 3696 2340.0 2364.0 68.1
7.49 3843 2340.0 2364.0 68.1
7.88 3948 2316.0 2352.0 69.7
8.27 4074 2304.0 2316.0 69.3
8.66 4179 2280.0 2268.0 70.5
9.04 4284 2256.0 2232.0 70.1
9.44 4368 2196.0 2196.0 68.5
Group A: '013
Cyl 1 Cyl 2 Cyl 3 Cyl 4
TIME -2.8 to +2.8 mg/H -2.8 to +2.8 mg/H -2.8 to +2.8 mg/H -2.8 to +2.8 mg/H
MARKER STAMP mg/R mg/R mg/R mg/R
0.00 -0.38 0.85 0.07 -0.56
0.39 -0.42 0.87 0.12 -0.61
0.78 -0.42 0.87 0.12 -0.61
1.17 -0.42 0.87 0.12 -0.61
1.57 -0.42 0.87 0.12 -0.61
1.97 -0.42 0.87 0.12 -0.61
2.36 -0.42 0.87 0.12 -0.61
2.75 -0.42 0.87 0.12 -0.61
3.14 -0.42 0.87 0.12 -0.61
3.54 -0.42 0.87 0.12 -0.61
3.94 -0.42 0.87 0.12 -0.61
4.35 -0.42 0.87 0.12 -0.61
4.74 -0.42 0.87 0.12 -0.61
5.14 -0.42 0.87 0.12 -0.61
5.54 -0.42 0.87 0.12 -0.61
5.94 -0.42 0.87 0.12 -0.61
6.33 -0.42 0.87 0.12 -0.61
6.72 -0.42 0.87 0.12 -0.61
7.11 -0.42 0.87 0.12 -0.61
7.50 -0.42 0.87 0.12 -0.61
7.89 -0.42 0.87 0.12 -0.61
8.28 -0.42 0.87 0.12 -0.61
8.67 -0.42 0.87 0.12 -0.61
9.06 -0.42 0.87 0.12 -0.61
9.45 -0.42 0.87 0.12 -0.61
9.84 -0.42 0.87 0.12 -0.61
10.22 -0.42 0.87 0.12 -0.61
Mam jeszcze jeden problem
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to B+ - Intermittent
Znowu się pojawił co musze wymienić ???
Dziękuję za wszystkie uwagi.
G2 jest polaczone z g62 (przynajmniej tak byc powinno, trzeba sprawdzic dokladnie w etce)
przeplywka daje duzo tlenu a turbawa pompuje zadane - dziwne. Dawki lekko dowalone :gwizdanie: masz jakis dziwny chips?
jedynie do czego można się doczepić to grupa 003 reszta to OK , wskazane było by podmienić przepływkę i zrobić logi jeszcze raz
a dawki to co? niby norma?? Jak to ma czipsa (a tego nikt nie wie bez przegladniecia map) to nie polapirmy sie nic a nic po logach (wg dobrego tunera, bez problemu da sie oszukac wsazania)
sugerujecie, że mam czipa ???
"wskazane było by podmienić przepływkę i zrobić logi jeszcze raz"
jest uwalona ??? czy coś nie tak z nią jest ???
