[B5 1Z] Prośba o analizę logów
Witam
sorki za prefiks ale odpowiedniego nie znalazłem
Jestem na etapie zakupu auta
To co udało mi sie zlogować jest poniżej
Octavia 1,9 tdi 90 koni 1997r oznaczenie silnika ---- chyba AGR
i uprzedzam wiecej logów nie mam
chciałbym chociaż z tych dowiedzieć sie czegoś o kondycji silnika
Za wczesny wtrysk widze sam
BŁĘDY:
VAG-COM Version: Release 311.2-N
Chassis Type: 1U - Skoda Octavia
Scan: 01,02,03,08,15,17,19,35,46,56
Address 01 -------------------------------------------------------
Controller: 038 906 018 BC
Component: 1,9l R4 EDC 00SG 1822
Coding: 00005
Shop #: WSC 90025
2 Faults Found:
01282 - Intake Manifold Flap change-over Valve (N239)
31-10 - Open or Short to Ground - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1J0 907 379
Component: ABS ITTAE 20 GI V00
Coding: 03604
Shop #: WSC 00000
No fault code found.
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1U1 919 033 G
Component: A+-KOMBIINSTR. VDO V08
Coding: 02140
Shop #: WSC 90025
IMMO-IDENTNR: SKZ7Z0T0020673
1 Fault Found:
01176 - Key
07-00 - Signal to Low
Address 46 -------------------------------------------------------
Controller: 3B0 959 799 S
Component: Zentral-SG Komfort V41
Coding: 04097
Shop #: WSC 31480
11 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
37-00 - Faulty
49-10 - No Communications - Intermittent
00960 - Switch for Central Locking: Driver Side (F59)
29-10 - Short to Ground - Intermittent
27-10 - Implausible Signal - Intermittent
00928 - Locking Module for Central Locking: Front Driver Side (F220)
27-00 - Implausible Signal
01332 - Door Control Module: Passenger Side (J387)
37-00 - Faulty
00944 - Heated Exterior Mirror: Passenger Side (Z5)
35-00 - -
00930 - Locking Module for Central Locking: Rear Left (F222)
End -------------------------------------------------------
co oznacza w 004 BTDC --- w ogóle jest inne i zalecane zanizone a aktualne zawyżone
czy ktoś kombinował druciarstwo w związku ze znanym problemem z odpalaniem tego typu silnika ?????
BTDC - Before Top Dead Center - Przed Gornym Martwym Punktem- Przed Zwrotem Zewnetrznym
ATDC - After Top Dead Center - Po Gornym Martwym Punkcie - Po Zwrocie Zewnetrzym
Nomenklatura stosowana przy okreslaniu polozenia tloka w silniku spalinowym.
Błędy jakie są widzę
Mniemam że różnice BTDC wynikają ze zbyt wczesnego kąta wtrysku????? czy TAK?
Dodam że robiłem również 003 BS ale nie zapisałem -- brak reakcji na EGR chyba zaślepione
Pytanie o kondycje tego motorka czy jest sens pchać sie w to auto jeżeli chodzi o silnik oczywiście ?
Co z 008 bo dawki są wyższe ale na tych samych obrotach przepływka w 003 również zawyża..... jedno jak rozumiem zależy od drugiego.
Czy to wina chińskiej przepływki?? --- myżlę że jakby był wirus to turbo też by więcej sie wkręcało --- czy mam rację??
A może wynika to z zaślepionego EGR-a ???
turbo 011 chyba raczej OK
Czy mój tok myślenia jest prawidłowy ?
Podziekowania dla kolegi Przemika za wyjaśnienie --- równie dobrze mogłem dostać ochrzan za pytanie o BTDC...
