[ALL B6] Błąd ABS\ESP i wiele innych..
Witam kolegów, postanowiłem sobie dziś wyszukać błędy, i otrzymałem coś takiego:
Moglibyście powiedzieć mi cokolwiek na temat tych błędów? Najbardziej zmartwił mnie błąd Abs\Esp, o co tu chodzi???
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 038 906 019 FP
Component: 1,9l R4 EDC 0000SG 1538
Coding: 00002
Shop #: WSC 60551
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
1 Fault Found:
18258 - Powertrain Data Bus: Missing Message from ECU
P1850 - 35-10 - - - Intermittent
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 H
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
5 Faults Found:
01842 - Potentiometer/Actuator for Temperature Flap: Right (G221)
30-10 - Open or Short to B+ - Intermittent
00716 - Air recirculation Flap Positioning Motor (V113)
41-10 - Blocked or No Voltage - Intermittent
01207 - Control Module for Auxiliary Heater (J364)
49-00 - No Communications
01593 - Heated Windshield (Z2)
36-10 - Open Circuit - Intermittent
01794 - Control Module Incorrect Chassis (VIN) Number
35-00 - -
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 C
Component: int. Lastmodul RDW 0203
Coding: 00001
Shop #: WSC 63351
1 Fault Found:
35-00 - -
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00001
Shop #: WSC 63351
1 Fault Found:
35-00 - -
Address 17 -------------------------------------------------------
Controller: 8E0 920 900 G
Component: KOMBI+WEGFAHRS. RB4 D27
Coding: 00001
Shop #: WSC 11111
WAUZZZ8E72A241713 AUZ6Z0B0152111
3 Faults Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01304 - Radio
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AD
Component: Komfortgerát T85 0316
Coding: 06720
Shop #: WSC 63351
5 Faults Found:
01562 - Right Rear Door
59-00 - Can't Unlock
61-00 - Won't De-Safe
01366 - Opened Due to Crash Signal
01332 - Door Control Module: Passenger Side (J387)
80-00 - Single-Wire Operation
01560 - Passenger Door
58-10 - Can't Lock - Intermittent
End -------------------------------------------------------
A odlaczales ostatnio klemy akumulatora(lub masz slaby aku)??, po skasowaniu wiekszosc bledow powinna zniknac
nie, klem nie odłączałem, a aku mam nowy, ale co do niektórych błędów, to mogę się odnieść z praktyki, np odnośnie zamka prawych tylnich drzwi: nie działa oświetlenie i czujnik otwarcia, tzn czasem działa czasem nie... a reszta błędów nic mi nie mówi :)
a po wymianie aku na nowy błedy pokasowałeś??[br]Dopisany: 08 Listopad 2011, 22:24_________________________________________________
a sprawdzałeś wiązke która jest przy drzwiach
Nie, nie kasowałem bo wymieniał go poprzedni właściciel, i nie przypuszczałem że ma to jakiś związek z błędami, bo skąd np pewność, że błąd dot ESP nie jest jakimś błędem fizycznym?
A co do tej wiązki, to jak się do niej dobrać? drzwi trzeba rozbierać?
nie miedzy drzwiami a słupkiem jest guma, trzeba ja sciagnac i popatrzec dokładnie czy żaden kabel nie jest przetarty
co do błedu 01794 to mam dla ciebie niemiła wiadomość http://www.elektroda.pl/rtvforum/topic1929777.html
na początek trzeba skasować wszystko co się będzie dało żeby uporządkować cały bałagan powstały raczej na pewno po słabym lub rozładowanym Aku (podobnie miałem u siebie). Następnie sprawdzić co dalej się będzie pokazywać. Błąd w Abs -ie to wygląda na błąd magistrali CAN tak jak zresztą połowa innych. Co do drzwi i zamków to faktycznie sprawdził bym połączenie między słupkiem a drzwiami. w adresie 08 masz błąd grzani szyby - ciekawe czy masz takowe fizycznie w aucie - możliwy błąd w kodowaniu sterownika.
odnosnie błędów VIN trzeba poprostu przypisać numery VIN... często wynika z głębokiego rozładowania aku..
poszukaj w moich postach - też to przerabiałem i wszystko śmiga ok
  • 4 tygodnie później...
Witam,
VCDS pokazuje mi te błędy - są to błedy stałe gdyż są one wykrywane przez interfejs pomimo czyszczenia sterowników:
"Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Coding: 04255
Shop #: WSC 05311
VCID: E5CA33CA133B5034
2 Faults Found
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 G
Component: KOMBI+WEGFAHRS. RB4 D22
Coding: 00000
Shop #: WSC 05311
VCID: 2854FAFEA4A90D5C
WAUZZZ8E82A090235 AUZ6Z0A0231556
2 Faults Found
01304 - Radio
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 AD
Component: Komfortgerát T85 0315
Coding: 06976
Shop #: WSC 05311
VCID: 73EEDD922DEF3E84
Part No: 8E1959801B
Component: Tőrsteuer.FS BRM 4.11
Part No: 8E1959802B
Component: Tőrsteuer.BF BRM 4.11
5 Faults Found
01561 - Left Rear Door
59-10 - Can't Unlock - Intermittent
61-10 - Won't De-Safe - Intermittent
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186
Component: concert II GRO 0001
Coding: 01001
Shop #: WSC 52311
VCID: E4CC2ECE1801293C
1 Fault Found
00858 - Connection; Radio ZF Output to Antenna Amplifier
36-00 - Open Circuit
End ---------------------------------------------------------------------"
W tym temacie są opinie, że część z nich może być winą słabego aku. Otóż mój jest niewymieniany od czasów gdy zjechał z taśmy w Ingolstadt (początek 2002). Dodatkowo mam problemy czasami z odpalaniem auta. Zauważyłem że lepiej pali jak wyłączę przy uruchamianiu radio i ogrzewanie. Drugą opcją może być zły kąt synchronizacji? Czy mogę jakoś to wykluczyć za pomocą VCDS-a?[br]Dopisany: 30 Listopad 2011, 19:45_________________________________________________Odnośnie błędu 18258 to może być wg Wiki Ross-Tech:
  • Spalony bezpiecznik modułu sterowania
  • Problem z kablami
  • Uszkodzony moduł
Więc pytanie do doświadczonych użytkowników. Który bezpiecznik odpowiada za ECU?
Wymień aku :wallbash: co do bezpieczników masz pełną rozpiskę w aucie na deklu. Sprawdź kostkę na słupku A przy kierowcy (czarna z tego co pamiętam) Kiedyś tez podobne błędy mi wywalało w ABS jak jej zapomniałem podłączyć :decayed:
mnie np wywalolo bledy esp abs na okreta przez xenon nie orginalny odpiolem i wszystko smiga jak nalezy :notworthy:
Ale ja mam wszystko oryginalne, mam tylko podpięte audio a dokładniej skrzynię basową.[br]Dopisany: 09 Grudzień 2011, 11:27_________________________________________________Dziś chciałem zakupić akumulator, lecz przed zakupem postanowiłem sprawdzić ładowanie i pobór prądu. Aku trzyma jeszcze nominalne paramerty, ładowanie OK, lecz pobór prądu w trakcie postoju to 0.1 A. Podobno norma to połowa z tego - 0.05 A. Jak będę miał czas to pobawię się w wypinanie bezpieczników w aucie i sprawdzanie co jest winowajcą takiego stanu rzeczy. Czy przy odłączaniu poszczególnych obwodów na coś mam uważać, któryś nie wypinać?
:mysli: dziwne moze masz jakies problem ze modulami abs esp to tez czeste w vag group
najpierw poszukaj przyczyne poboru pradu
moze to byc tuba albo lampka w bagazniku
co do abs-u to masz uszkodzenie sterownika ale to nie ma wplywu na odpalanie
