[ALL TDI] Audi A3 L8 1.9 Tdi ASV problem z sensorem
Witam mam problem z A3 wyskoczył mi ostatnio taki dziwny blad na desce sensor. Sprawdziłem błędy i wyskoczyło takie cos dodam ze mam problem z turbina przeładowanie czyściłem ja ale po 400 km bład znowu powrócił. Wklejam błędy
VCDS-Lite Version: Release 1.0
Monday, 16 January 2012, 11:52:34:0
Control Module Part Number: 038 906 012 BB
Component and/or Version: 1,9l R4 EDC 0000SG 2809
Software Coding: 00002
Work Shop Code: WSC 06435
2 Faults Found:
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-00 - -
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
Monday, 16 January 2012, 11:56:28:0
Control Module Part Number: 8L0 920 900
Component and/or Version: AB-KOMBIINSTR. VDO D09
Software Coding: 00040
Work Shop Code: WSC 00000
Additional Info: ˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙ AUZ7Z0X1200699
1 Fault Found:
00562 - Sensor for Oil Level/Temperature (G266)
30-00 - Open or Short to Plus
Monday, 16 January 2012, 12:05:26:0
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,16,17,22,35,37,45,55,56,57,75,76
Address 01: Engine Labels: 038-906-012-AGR.LBL
Controller: 038 906 012 BB
Component: 1,9l R4 EDC 0000SG 2809
Coding: 00002
Shop #: WSC 06435
1 Fault Found:
P1654 - 35-00 - -
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.LBL
Controller: 1J0 907 379 Q
Component: ABS/EDS 20 IE CAN 0001
Coding: 13304
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC Labels: 8L0-820-043-2D.LBL
Controller: 8L0 820 043 M
Component: A3 KLIMAVOLLAUTOMAT_D77
Coding: 03143
Shop #: WSC 06435
Address 15: Airbags Labels: 8L0-959-655-AI8.LBL
Controller: 8L0 959 655 G
Component: Airbag Front+Seite 1007
Coding: 00104
Shop #: WSC 06435
Address 17: Instruments Labels: 8L0-920-xxx-17.LBL
Controller: 8L0 920 900
Component: AB-KOMBIINSTR. VDO D09
Coding: 00040
Shop #: WSC 00000
1 Fault Found:
Address 35: Centr. Locks Labels: 8D0-862-257.LBL
Controller: 8L0 862 257 L
Component: ZV-Pumpe D10
Coding: 00000
Shop #: WSC 06435
3 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01360 - Switch for Anti-Theft Alarm; Open
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to Plus
Logi statyczne:
Grupy: 000 - http://vaglog.rtnet.pl/lukaszpuma_69124.html
Grupy: 001 - http://vaglog.rtnet.pl/lukaszpuma_69129.html
Grupy: 003 - http://vaglog.rtnet.pl/lukaszpuma_69126.html
Grupy: 004 - http://vaglog.rtnet.pl/lukaszpuma_69123.html
Grupy: 007 - http://vaglog.rtnet.pl/lukaszpuma_69128.html
Grupy: 010 - http://vaglog.rtnet.pl/lukaszpuma_69125.html
Grupy: 011 - http://vaglog.rtnet.pl/lukaszpuma_69122.html
Grupy: 013 - http://vaglog.rtnet.pl/lukaszpuma_69121.html
Grupy: 023 - http://vaglog.rtnet.pl/lukaszpuma_69127.html
Basic Settings:
Grupy: 003 - http://vaglog.rtnet.pl/lukaszpuma_69130.html
Grupy: 000 - http://vaglog.rtnet.pl/lukaszpuma_69131.html
Grupy: 004 - http://vaglog.rtnet.pl/lukaszpuma_69132.html
czujnik znajduje się u dołu miski olejowej, przykręcony na 3 śruby na klucz imbus chyba nr. 5 lub 6.
możesz sprawdzić podłączenie tzn. kostkę przy samym czujniku i dalej kable, lub spróbować wyczyścić czujnik (może to coś da (takie gdybanie jak czyszczenie przepływki)).
18062- "prosi" osprawdzenie bledow zapisanych w liczniku, jedna z przyczyn MOZE
byc uszkodzony czujnik oleju( moze wystapic rowniez podczas braku
komunikacji zegarow z ECU lub problemach z masa w okolicach akumulatora).
Z logów wynikałoby, że czujnik temperatury płynu chłodzącego szwankuje - wartość skacze w dół i w górę.
Należy skasować wszystkie błędy, najlepiej połączyć się z każdym modułem i wykasować.
Jeśli powrócą to wrzuć listę co zostało.
Błąd 17965 może świadczyć o chwilowym przeładowaniu turbiny - należy zrobić logi dynamiczne (011) - przynajmniej 3 razy logować na 3 biegu od 1500-4200 obr.
