Prośba o analizę błędów
maxus24
witam znalazlo mi pare bledow czy ktos moze napisac co oznaczaja ? jeden to cos z czujnikiem plynu chlodzacego tylko ktory? z gory dziekuje i pozdrawiam
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 8E0 909 557 H
Component: 2.0L R4/5VS 0002
Coding: 0011501
Shop #: WSC 63351
3 Faults Found:
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 002 - Lower Limit Exceeded - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 002 - Lower Limit Exceeded
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04275
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 L
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 F
Component: int. Lastmodul RDW 0416
Coding: 01101
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00011
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8E0 920 900 L
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 00000
Shop #: WSC 21023
WAUZZZ8E33A319860 AUZ6Z0B0463257
Address 45 -------------------------------------------------------
Controller: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 BD
Component: Komfortgerát TBF 1411
Coding: 06730
Shop #: WSC 63351
6 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01573 - Alarm triggered by Door Contact Switch: Left Rear
35-00 - -
01366 - Opened Due to Crash Signal
36-10 - Open Circuit - Intermittent
00955 - Key 1
35-10 - - - Intermittent
Address 56 -------------------------------------------------------
Controller: 8E0 035 195 C
Component: symphony II NP2 0151
Coding: 01001
Shop #: WSC 63481
Address 76 -------------------------------------------------------
Controller: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D09
Coding: 00104
Shop #: WSC 63351
End -------------------------------------------------------
Czy masz w tej chwili jakiś problem z chłodzeniem?
Jeżeli nie, to skasuj błędy, przejedź z 500km i wklej tutaj, to co Ci wyskoczy - wtedy będzie można coś więcej powiedzieć.
---------- Post dopisany at 12:00 ---------- Poprzedni post napisany at 12:00 ----------
tak problem jest taki ze odrazu po uruchomieniu samochodu wlacza sie wentylator od chlodnicy i silnik niechce sie rozgrzac do 90 stopni znaczy sie rozgrzewa sie ale bardzo pozno okolo 10 kilometrow przejechalem i dopiero bylo 90 stopni i przedtem check engine swiecilo ale zgasnelo na drugi dzien
a wie ktos czy ten czujnik (16502 - Engine Coolant Temp. Sensor (G62): Signal too High) to niejest przypadkiem ten za silnikiem przy podszybiu ? taki zielony czujnik zblokowany na zawleczke /spinke ?
Po prawej stronie, jak stoisz przed samochodem, na dolnej rurze wody wychodzącej z chłodnicy.
a jai ten czujnik ma numer zebym go mogl kupic ?
---------- Post dopisany at 12:53 ---------- Poprzedni post napisany at 12:53 ----------
a jaki ten czujnik ma numer zebym go mogl kupic ?
---------- Post dopisany 07-05-2012 at 09:17 ---------- Poprzedni post napisany 05-05-2012 at 12:53 ----------
Odnosnie 17545 - Fuel Trim: Bank 1 (Add): System too Rich
Sprawdz jakie masz koretky mieszanki, blok pomiarowy 032. Pamietaj, ze po skasowaniu beledow beda tam zera.
a czy te korekty moga miec cos wspolnego z tym ze mam instalacje LPG ?
---------- Post dopisany at 09:17 ---------- Poprzedni post napisany at 09:17 ----------
kurde wymienilem ten czujnik na dolnym wezu od chlodnicy i wentylator ten po prawej od kierowcy dalej sie kreci , malo powiedziane ze kreci on wyje jak wsciekly nawet na zimnym silniku rano zaraz po odpaleniu samochodu , wie ktos co to moze byc ?
u mnie np ten wentylator jak patrzę z przodu na auto to wciąż się kręci. Czy auto zimne czy nie zawsze się kręci. I niby tak jest dobrze. Natomiast ten z lewej włącza się jak załączysz klime albo auto się Zagrzeje. Ale to potrzeba czasu. Jak kupiłem auto to chciałem go Zagrząc i nici. Chodził ok godz i wentylator się nie załączyl. Ale na krótko podłączyłem to działa.
---------- Post dopisany at 23:07 ---------- Poprzedni post napisany at 23:01 ----------
a jeżeli kręci i wyje to wisko jest zepsute pewnie. Idzie to sprawdzić samemu jeżeli będzie dobre to jak przytrzymasz śmigi i drugi odpali to nie będzie się kręcił. A jak jest zepsuty to Ciężko ci będzie go zatrzymać. Uważaj na ręce. Jak coś źle napisałem to Proszę mnie poprawić.
---------- Post dopisany at 23:07 ---------- Poprzedni post napisany at 23:07 ----------
hmm a czy jesli by bylo zepsute wisko to czy by sie wylaczalo bo to sie wylacza po jakims czasie ,czy moze caly czas by krecilo ? no i dlaczego jest ten blad od czujnika ?
mam pytanie na jakim blocku w silniku 2,0 ALT mozna sprawdzic vagiem temp bo w engine i 07 niemam nic ?
jakie blocki przeskanowac w 2,0 ALT ?
