adasio13 Opublikowano 17 Września 2012 Opublikowano 17 Września 2012 witam. od razu mówie że pierwszy raz podłączylem auto po vag'a i zrobiłem autoscan i coś takiego mi pokazało: VAG-COM Version: Release 311.2-N Chassis Type: 8D - Audi A4 B5 Scan: 01,02,03,08,15,17,25,35,45,55,56 Address 01 ------------------------------------------------------- Controller: 028 906 021 GN Component: 1,9l R4 EDC G00SG 1437 Coding: 00002 Shop #: WSC 06325 1 Fault Found: 65535 - Internal Control Module Memory Error 37-10 - Faulty - Intermittent Readiness: N/A Address 03 ------------------------------------------------------- Controller: 8E0 614 111 Component: ABS 5.3 FRONT D11 Coding: 0273004132 Shop #: BB 24303 No fault code found. Address 08 ------------------------------------------------------- Controller: 8L0 820 043 B Component: A4 KLIMAVOLLAUTOMAT_D73 Coding: 04143 Shop #: WSC 06325 No fault code found. Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 8D0 919 034 Component: B5-KOMBIINSTRUMENT D10 Coding: 00040 Shop #: WSC 19411 No fault code found. Address 25 ------------------------------------------------------- Controller: 4A0 953 234 F Component: IMMO AUZ9Z0V4174336 D77 Coding: 00000 Shop #: WSC 49484 No fault code found. Address 35 ------------------------------------------------------- Controller: 8LO 862 257 E Component: ZV-Pumpe D03 Coding: 00000 Shop #: WSC 65535 8 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01373 - Alarm triggered by Radio Ground Contact 35-00 - - End ------------------------------------------------------- prosze o zrozumienie jezeli coś nie tak, ale to mój pierwszy kontakt z programem i na dodatek po długich meczarniach z uruchomieniem vag'a bo mam win 7 64bit. da się coś z tego wyczytać?? bo nie ukrywam ze jestem w tym ciemny a moja audiczka słabsza jest niż była i wiecej pali.. prosze o pomoc
sokal Opublikowano 18 Września 2012 Opublikowano 18 Września 2012 Yhm, skasowałeś je? Zobacz czy wracają po skasowaniu ale generalnie z adresów 03, 08, 17 i 25 nie masz żadnych błędów. Z adresu 35 nie mają znaczenia przy spalaniu A te z 01 wydaje mi się że nie powinny wrócić po skasowaniu ale sprawdź
adasio13 Opublikowano 18 Września 2012 Autor Opublikowano 18 Września 2012 A jam sie kasuje? Mam vag 311.2
adasio13 Opublikowano 20 Września 2012 Autor Opublikowano 20 Września 2012 Ok dzięki. A gdzieś znalazłem ten kod błędu na jakiejś str (nie pamiętam juz jakiej) i tam było przy nim napisane uszkodzony sterownik ecu (czy jakos tak) ---------- Post dopisany at 21:18 ---------- Poprzedni post napisany at 15:45 ---------- skasowałem ten bład i na odpalonym na wolnych obrotach i na przygazówce do maksa oraz przy jezdzie do 2500 obrotów błedu nie było dopiero jak trzymałem powyżej 3500 obrotów na każdym biegu to błąd się pojawiał. i tak za każdym razem. co to moze oznaczac? ---------- Post dopisany 20-09-2012 at 20:18 ---------- Poprzedni post napisany 18-09-2012 at 21:18 ---------- a te z grupy normalnie to jak długo logować? ---------- Post dopisany at 20:21 ---------- Poprzedni post napisany at 20:18 ---------- a te grupy 000,003,004,011 to logować normalnie i wtedy osobno w basic settings?
