[B6 AVF] Prośba o pomoc przy analizie błędów VagCom
Witam serdecznie, dzisiaj pierwszy raz przeskanowałem moje A4 VagCom 311n2. Następnie skasowałem błedy i jeszcze raz przeskanowałem. I oto wyniki:
Address 01 -------------------------------------------------------
Controller: 038 906 019 JT
Component: 1,9l R4 EDC G000SG 1572
Coding: 00002
Shop #: WSC 63351
WAUZZZ8E23A215666 AUZ6Z0B0240080
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 P
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
3 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
41-10 - Blocked or No Voltage - Intermittent
01841 - Potentiometer/Actuator for Temperature Flap: Left (G220)
30-10 - Open or Short to B+ - Intermittent
01810 - Actuating Motor for Temperature Flap: Right (V159)
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63351
Address 15 -------------------------------------------------------
Controller: 8E0 959 655 B
Component: Airbag 8.4EP 2000
Coding: 0010702
Shop #: WSC 63351
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 02042
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8E0 920 930 RX
Component: KOMBI+WEGFAHRS. RB4 D38
Coding: 00101
Shop #: WSC 11111
Address 37 -------------------------------------------------------
Controller: 8E0 035 192 B
Component: RNS 4.2 H06 BNO 0105
Address 45 -------------------------------------------------------
Controller: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 BD
Component: Komfortgerát TBF 1310
Coding: 06986
Shop #: WSC 63351
1 Fault Found:
01134 - Alarm Horn (H12)
29-00 - Short to Ground
Address 56 -------------------------------------------------------
Component: Radio BNO 0001
Coding: 00205
Shop #: WSC 52311
Address 76 -------------------------------------------------------
Controller: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D09
Coding: 00114
Shop #: WSC 63351
Proszę doświadczonych kolegów o pomoc? Wogule się przeraziłem że tyle tego:( Najbardzie boję się teg ABS/ESP z 3 grupy. W najbliższym czasie mam przegląd a Niemcy podobno skanują na przeglądzie i jak coś z ABS albo ESP to można zapomnieć o TUV.
W grupie ABS nie masz żadnego błędu.
Błędy są od klap w układzie klimatyzacji.
Trzeba wyjąć siłowniki i je wyczyścić, jak już wszystko będzie na wierzchu to sprawdzić czy nie przycinają się same klapy.
Acha faktycznie, "No fault code found" oznacza nie znaleziono błędu:) Znajomość ang się kłania:)
Czyli tylko coś z klapami klimy i syrena alarmu. Dzięki jarek_ns uspokoiłeś mnie bo już patrzyłem ile mam na koncie na ewentualne naprawy:)
I tak pewnie trzeba będzie zajrzeć do portfela, jak nie da się reanimować siłowników od klap.
Pewnie tak ale to nie tak strasznie, bo na początku myślałem że w każdej grupie coś wyskoczyło:) :facepalm:
Najważniejsze że ten ABS jest ok bo jestem teraz w niemczech a tu na przeglądzie podobno się czepiają jak coś z ABS wyskoczy u nich na Vagu:(
I chyba coś jest z klaksonem od alarmu.
Ale naprawdę jestem dużo spokojniejszy:)
Muszę poszukać co te błędy oznaczają bo w informacjach od Viakena znalazłem tylko niepełny spis kodów błędów.
Jeśli chodzi o klapy klimy to zrób najpierw nastawy podstawowe, może coś się poprawi. Opis jak to zrobić znajdziesz na forum:wink:
Mam nadzieje ze po skasoaniu błedu kolega troszke pojezdził autkiem...?
Bo napisane jest ze błedy skasowane i od razu skanowane od nowa.
Mozliwe ze po chwilce jazdy i ponownym skanowaniu nie bedzie zadnego błedu.
Przynajmniej u mnie tak to wyglada.
Oczywiscie kolega Jarek ma racje ze wczesniej czy pozniej nalezałoby zajac sie klapami klimy.
No faktycznie od razu przeskanowałem bez jeżdzenia. Ale Na przyszłość będę wiedział co i jak:) Dziękuję wszystkim za pomoc:hi:
proszę Admina o zamknięcie tematu
