Analiza błędów
Błędy kasowane, niektóre wracają od razu, niektóre po czasie ale wracają :kwasny:
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 8E0 909 518
Component: 1.8L R4/5VT 0001
Coding: 0011701
Shop #: WSC 09019
1 Fault Found:
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 008 - Implausible Signal - Intermittent
Readiness: 0000 1000
Address 03 -------------------------------------------------------
Controller: 4B0 614 517 G
Component: ABS/ESP front 3428
Coding: 04275
Shop #: WSC 00000
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8E0 820 043
Component: A4 Klimaautomat 0712
Coding: 00000
Shop #: WSC 63351
5 Faults Found:
00757 - Right Vent Temp Sensor (G151)
30-00 - Open or Short to B+
00601 - Potentiometer On Positioning Motor for Central Flap (G112)
01842 - Potentiometer/Actuator for Temperature Flap: Right (G221)
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to B+ - Intermittent
01206 - Signal for Duration of Ignition: OFF
27-00 - Implausible Signal
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 C
Component: int. Lastmodul RDW 0203
Coding: 00001
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00002
Shop #: WSC 63351
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
Address 17 -------------------------------------------------------
Controller: 8E0 920 950 G
Component: KOMBI+WEGFAHRS. RB4 D22
Coding: 01003
Shop #: WSC 00000
WAUZZZ8E92A155156 AUZ6Z0A0195689
3 Faults Found:
00438 - Fuel Supply Sensor 2 (G169)
01320 - Control Module for Climatronic (J255)
01304 - Radio
49-00 - No Communications
Address 45 -------------------------------------------------------
Controller: 8E0 951 177
Component: Innenraumueberw. 0504
Coding: 00001
Shop #: WSC 00000
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AH
Component: Komfortgerát T1B 0617
Coding: 08026
Shop #: WSC 00067
2 Faults Found:
01559 - Drivers Door
61-00 - Won't De-Safe
01334 - Door Control Module: Rear Right (J398)
80-00 - Single-Wire Operation
Address 76 -------------------------------------------------------
Controller: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D07
Coding: 00114
Shop #: WSC 63351
End -------------------------------------------------------
