prośba o analizę błędów
Witam, w koncu udało mi się podłączyć auto pod kompa (ufffff), zrobiłem auto-scan i wyszły takie czary:
VCDS-Lite Version: Release 1.0
Saturday, 21 September 2013, 16:17:44:0
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76,77
Address 01: Engine Labels: Redir Fail!
Controller: 8D0 906 018 D
Component: 1.8L R4/5V MOTR 0006
Coding: 05001
Shop #: WSC 06335
7 Faults Found:
17924 - Intake Manifold Valve (N156): Open Circuit
P1516 - 35-10 - - - Intermittent
17645 - Shareware Version. To Decode all DTCs
P1237 - 35-10 - Please Register/Activate - Intermittent
17647 - Shareware Version. To Decode all DTCs
P1239 - 35-10 - Please Register/Activate - Intermittent
17648 - Fuel Injector for Cylinder 4 (N33): Open Circuit
P1240 - 35-10 - - - Intermittent
17646 - Shareware Version. To Decode all DTCs
P1238 - 35-10 - Please Register/Activate - Intermittent
17834 - Shareware Version. To Decode all DTCs
P1426 - 35-10 - Please Register/Activate - Intermittent
17976 - Throttle Actuator (J338): Mechanical Failure
P1568 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.LBL
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
No fault code found.
Address 08: Auto HVAC Labels: 8D0-820-043-1D.LBL
Controller: 8D0 820 043 N
Component: A4 KLIMAAUTOMAT D54
Coding: 00040
Shop #: WSC 06335
Address 15: Airbags Labels: Redir Fail!
Controller: 8D0 959 65 J
Component: Airbag Front+Seite 0001
Coding: 00104
Shop #: WSC 06335
1 Fault Found:
01217 - Side Airbag Igniter; Driver Side (N199)
32-00 - Resistance too High
Address 17: Instruments Labels: 8D0-919-xxx-17.LBL
Controller: 8D0 919 881 J
Component: B5-KOMBIINSTR. VDO D15
Coding: 05042
Shop #: WSC 00000
IMMO-IDENTNR: AUZ7Z0X0987447
Address 25: Immobilizer Labels: None
Controller: Bit teA dre ssv
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35: Centr. Locks Labels: 8D0-862-257.LBL
Controller: 8D0 862 257 B
Component: ZV-Pumpe, Funk D12
Coding: 12865
Shop #: WSC 06335
Address 55: Xenon Range Labels: 4B0-907-357-AUT.LBL
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00011
Shop #: WSC 06335
Address 56: Radio Labels: 8D0-035-1xx-56.LBL
Controller: 4B0 035 186
Component: Radio 0001
Coding: 00207
Shop #: WSC 06335
End --------------------------------------------------------------------------------------------------
Ktoś mógłby mi powiedzieć co czym jest nie tak? Chłopaki chciałbym dowiedzieć się jak się kasuje błędy programem vcds lite (tylko on działa na win7 64bit). Ze scanowaniem sobie w koncu poradziłem ale jak usunąć błąd w angielskojęzycznym programie to nie mam pojęcia.
Edit. Znalezione i odczytane błedy:
17645 Obwód wtrysku paliwa do cylindra #1 - obwód otwarty
17646 Obwód wtrysku paliwa do cylindra #2 - obwód otwarty
17647 Obwód wtrysku paliwa do cylindra #3 - obwód otwarty
17648 Obwód wtrysku paliwa do cylindra #4 - obwód otwarty
17834 Zawór wentylacji zbiornika - obwód otwarty
o co chodzi?!?!
17924 - nie znalazlem ale jest cos takiego ale: Zawór zmiany długości kolektora dolotowego - N156, Cewka zmiany przewodu rurowego
Co do tej usterki to sprawa wyglada tak ze te rury łaczone od wlotu powietrza (nad chłodnica) sa uszkodzone tzn ta rura powinna trzymać się nad chłodnicą a tak nie jest, trzyma się luźno, nie wiem czy poprzedni właściciel miał delikatnego dzwona z przodu badź boku pasażera i trochę pekła ta plastikowa rura. Czy to moze być przyczyną? udało mi się zrobić foto:
17976 - nie znalazlem ale jest cos takiego ale: Moduł sterujący przepustnicę - J338, Moduł kontroli stanu przepustnicy - J338
Co do przepustnicy to jakiś czas temu dałem mechanikowi do czyszczenia ponieważ delikatnie mi falują obroty (na luzie nie trzyma 900 tylko są wahania w granicach 900-950), mowi ze przeczyścił przepustnice i zaadaptował (chodź efektów w ogóle dalej delikatnie falują). Czy tu chodzi o adaptacje?
1217 Zapalnik bocznej poduszki powietrznej, strona kierowcy - N199
Czy ja mam boczną poduszkę powietrzną kierowcy? Zawsze wydawało mi się że mam tylko tą co strzela z kierownicy. I jak rozwiązać ten problem?
---------- Post dopisany 22-09-2013 at 10:40 ---------- Poprzedni post napisany 21-09-2013 at 20:03 ----------
prosił bym o pomoc
Coding: 05001
Shop #: WSC 06335
1 Fault Found:
Wraca tylko ten błąd z pierwszego postu. Ktoś wie o co chodzi?
Powtórzę to co napisałem w pierwszym poście:
17976 - nie znalazlem na liście takiego błędu ale jest cos takiego: Moduł sterujący przepustnicę - J338, Moduł kontroli stanu przepustnicy - J338
---------- Post dopisany 31-10-2013 at 17:57 ---------- Poprzedni post napisany 30-09-2013 at 14:46 ----------
Panowie zostało tylko to:
Coding: 00104
Shop #: WSC 06335
1 Fault Found:
jak to usunąć? błąd powraca zaraz po usunięciu.
