Prośba o analize błedów
witam Program diagnostyczny VAG 311.2 pokazał mi takie błędy, proszę o wyjaśnienie błędów i co naprawić ewentualnie kupić:
VAG-COM Version: Release 311.2-N
1o9lo0m-n6r12p-o9ko4x-kkjahh-568f
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 8E0 906 018 AH
Component: 1.6L R4/2VSIM3 0002
Coding: 0006271
Shop #: WSC 63351
1 Fault Found:
16726 - Camshaft Position Sensor (G40): Signal too Low
P0342 - 009 - Open or Short to Ground - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04175
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 H
Component: A4 Klimaautomat 1016
Coding: 00000
Shop #: WSC 63351
5 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
41-10 - Blocked or No Voltage - Intermittent
00727 - Potentiometer in Positioning Motor for Defrost Flap (G135)
30-10 - Open or Short to B+ - Intermittent
01841 - Potentiometer/Actuator for Temperature Flap: Left (G220)
01810 - Actuating Motor for Temperature Flap: Right (V159)
00532 - Supply Voltage B+
53-10 - Supply Voltage Too Low - Intermittent
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 C
Component: int. Lastmodul RDW 0203
Coding: 00001
Shop #: WSC 00000
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00001
Shop #: WSC 63351
1 Fault Found:
01332 - Door Control Module: Passenger Side (J387)
49-00 - No Communications
Address 17 -------------------------------------------------------
Controller: 8E0 920 950 K
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 00100
Shop #: WSC 05311
WAUZZZ8E33A109582 AUZ6Z0B0201501
2 Faults Found:
01316 - ABS Control Module
49-10 - No Communications - Intermittent
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AR
Component: Komfortgerát T85 1210
Coding: 06848
Shop #: WSC 63351
10 Faults Found:
01331 - Door Control Module: Driver Side (J386)
01561 - Left Rear Door
59-00 - Can't Unlock
61-00 - Won't De-Safe
01562 - Right Rear Door
01366 - Opened Due to Crash Signal
35-00 - -
00955 - Key 1
35-00 - -
37-10 - Faulty - Intermittent
01705 - Selection Switch for Mirror-Adjust (E48)
27-10 - Implausible Signal - Intermittent
Address 56 -------------------------------------------------------
Controller: 8E0 035 186
Component: concert II GRO 0008
Coding: 01001
Shop #: WSC 63351
1 Fault Found:
00858 - Connection: Radio ZF Output to Antenna Amplifier
36-00 - Open Circuit
End -------------------------------------------------------
Zrób tak:
podładuj akumulator, sprawdź ładowanie na zimnym (14-14,4V) i rozgrzanym silniku (13,6-14V), pokasuj wszystkie błędy i pojeździj z kilka dni. A potem zobacz które powróciły. Bo większość z nich mogła powstać z powodu niedostatecznego napięcia zasilania,
zlikwidowałem większość usterek, po stronie kierowcy był kable przerwany, polutowałem szyba wróciła do życia, po stronie pasażera brakowało całego modułu, miałem zapasowy i wszystko gra, podładowałem aku i pokasowałem błędy tyle z nich zostało :
Coding: 0006271
Shop #: WSC 63351
Readiness: N/A
Coding: 04175
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 63351
Coding: 00001
Shop #: WSC 00000
Coding: 00001
Shop #: WSC 63351
2 Faults Found:
Coding: 00100
Shop #: WSC 05311
3 Faults Found:
Coding: 06848
Shop #: WSC 63351
Coding: 01001
Shop #: WSC 63351
2 Faults Found:
00852 - Loudspeaker(s): Front
36-10 - Open Circuit - Intermittent
Edytowane przez diabel1924
Brak komunikacji z J386/J387 świadczyć może o przetartej wiązce przewodów w gumie-harmonijce łączącej drzwi kierowcy i pasażera z kastą. To przewody łączące moduł komfortu z modułami w przednich drzwiach.odpowiadające min. za sterowanie szybami i zamkami.
Błąd z głośnikiem może mieć podobną przyczynę.
Z anteną to nie wiem... w ciągu dnia sprawdzę ile ma połączeń pośrednich, może na którejś kostce nie łączy.
Przetrzep też dobrze CAN-napędu, ale dziwne, że błąd komunikacji z ABS-em wywala tylko zestaw wskaźników... :mysli:
Z tego co widzę na schematach to kable antenowe HF i ZF (ten drugi jest używany jeśli masz radio Concert lub Symphony, radio Chorus go nie używa) idą bezpośrednio do anten. Sprawdź zatem połączenia przy radiu i tuż przy antenach.
Edytowane przez BeyerBrown
  • 10 miesięcy temu...
witam ja tez jestem nowy i mma pytanie
chce zdiagnozowac swoje auto samodzielni epodlaczyc go pod kompa tylko nie posiadam programu do diagnostyki gdzi etakowy moge dostac wiadomo przewod allegro a program i jaki najlepiej
