Jakie wyposażenie mam w samochodzie
Witam. Chcialbym sie dowiedziec jakie mam wyposazenie w aucie bo nie wiem tak do konca, jak to mozna sprawdzic. Jestem poczatkujacy i szukalem ale albo nie umiem albo nic nie ma. Prosze o podpowiedz albo jakis link
Zobacz czy we wnęce koła zapasowego albo w książce serwisowej nie masz wlepki z kodami wyposażenia. Jak znajdziesz, to w necie są dekodery wyposażenia.
Pokaż zdjęcia to Ci powiemy :D
E0A = No special edition
7MG = Emission standard EU5
4UE = Air bag for driver and front seat passenger
6XD = Exterior mirrors: electrically adjustable/heated
5SL = Left exterior mirror: aspherical
6TS = Right exterior mirror: aspherical, large viewing field
1KW = Disc brakes, rear
J0P = Battery 580A (105 Ah)
1LT = Disc brakes, front
1AT = Electronic stabilization program (ESP)
1BA = Standard suspension/shock absorption
3FE = Electric slide/tilt sunroof with sun screen/sunblind
5TE = Decorative aluminum inserts
7X1 = Park distance control
F0A = No special purpose vehicle, standard equipment
8GU = Alternator 140 A
0G1 = Gearshift lever
0YG = Weight range 7 installation control only, no requirement forecast
0JG = Weight category front axle weight range 7
TH3 = 4-cylinder diesel engine 2.0 L unit 03L.B
3NZ = Rear seat bench unsplit, backrest split folding
8BP = Bi-functional headlight with gas discharge lamp
U1A = Instrument insert with km/h speedometer,clock, tachometer and trip odometer
X4J = National sales program Poland
1N1 = Power steering
1XW = Leather trimmed multi-function sports steering wheel
8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving)
9Q8 = Multi-function display/on-board computer
8Z5 = Not hot country
D93 = 4-cyl. turbo dies. eng. 2.0 l/125 kW 4V TDI common rail Base engine is TG3/TH3/TL4/TM4/TP4/TU3
7T6 = Navigation system (MID)
C7R = Alloy wheels 7.5J x 17
7K6 = Flat tire indicator
4X3 = Side air bag front with curtain air bag
2K1 = Reinforced bumpers
3L3 = Manual height adjustment for front seats
4KC = Side and rear windows in heat-insulatingglass
3Y0 = Without roll-up sun screen
4K4 = Radio remote controlled central locking
5D7 = Carrier frequency 868 MHz without panic button
1SA = Without additional front underbody guard
Q1D = Sports front seats
4GF = Windshield in heat-insulating glass
Dziekuje bardzo
Albo wpisz w Google dekorowanie wyposażenia i wyskoczy kilka stron które Ci pomogą.
Wysłane z mojego C6903 przy użyciu Tapatalka
