Masa błędów po odpięciu niebieskiej wtyczki licznika
setho
Tak jak w temacie panowie. Pomógłby ktoś to ogarnąć ?
Błędy z VAGa:
VCDS-Lite Version: Release 1.2
Saturday, 16 July 2016, 15:09:44:0
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77
Address 01: Engine Labels: 038-906-019-AJM.LBL
Controller: 038 906 019 JL
Component: 1,9l R4 EDC G200SG 1519
Coding: 00002
Shop #: WSC 63351
VCID: 6AA741AB0567
WAUZZZ8E23A021767 AUZ6Z0B0132518
2 Faults Found:
18107 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
P1699 - 35-00 - -
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
VCID: E5BDB2976C79
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Controller: 8E0 820 043 L
Component: A4 Klimaautomat 1015
Coding: 00000
Shop #: WSC 63351
VCID: 2A2781ABC5E7
3 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
49-00 - No Communications
00474 - Control Module for Immobilizer
27-00 - Implausible Signal
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00011
Shop #: WSC 00000
VCID: 341B9FD31723
4 Faults Found:
79-00 - Please Check Fault Codes
01312 - Powertrain Data Bus
Address 15: Airbags Labels: 8E0-959-655-84.LBL
Controller: 8E0 959 655
Component: Airbag 8.4E 5001
Coding: 0010702
Shop #: WSC 63351
VCID: F49BDFD3D7A3
Address 16: Steering wheel Labels: 8E0-953-549.LBL
Controller: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 00042
Shop #: WSC 00000
VCID: 3C0BB7F33F73
2 Faults Found:
Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
Controller: 8E0 920 930 J
Component: KOMBI+WEGFAHRS. RB4 D28
Coding: 00700
Shop #: WSC 00006
VCID: 2E2F8DBBF90F
12 Faults Found:
00771 - Fuel Level Sensor (G)
30-00 - Open or Short to Plus
00779 - Outside Air Temp Sensor (G17)
00562 - Sensor for Oil Level/Temperature (G266)
00457 - Control Module for Network (J519)
01330 - Central Control Module for Central Convenience (J393)
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01334 - Door Control Module; Rear Right (J398)
01333 - Door Control Module; Rear Left (J388)
00466 - Control Module for Steering Column Electronics (J527)
01320 - Control Module for Climatronic (J255)
01304 - Radio
Address 37: Navigation Labels: None
Controller: 8E0 035 192 B
Component: RNS 4.2 H06 BNO 0102
VCID: 23396C8FA2CD
Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
Controller: 8E0 959 433 AF
Component: Komfortgerát T03 0316
Coding: 06976
Shop #: WSC 63351
VCID: 759D62D75CD9
2 Faults Found:
01560 - Passenger Door
61-00 - Won't De-Safe
Address 55: Xenon Range Labels: 4Z7-907-357.LBL
Controller: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00060
Shop #: WSC 63351
VCID: 047B0F130703
Address 56: Radio Labels: None
Component: Radio BNO 0001
Coding: 00207
Shop #: WSC 47392
VCID: 23396C8FA2CD
Address 57: TV Tuner Labels: None
Controller: 4D0 919 146 B
Component: TV Tuner H05 0704
Coding: 0000010
Shop #: WSC 00000
VCID: 28237BA3DBEB
Przepraszam za zamieszanie ale wyszło że wtyk nie był dociśnięty do końca ;/ Z drugiej strony mam jeszcze jedno pytanie: Pojawił mi sie komunikat OIL MIN (żółty) oleju była już mało dolałem tak żeby było pośrodku ale komunikat na FISie dalej świeci. Czy procedura rejestrowana przez komputer wygląda tak:
Otwieram maskę( czujnik sygnalizuje to na FISie, dolewam olej, zamykam maskę (FIS pokazuje zamkniętą). Odkryłem że w VCDS 46- Central Con. w bloku pomiarowym nr 5. podaje mi że engine hood contact switch is NOT INSTALLED czyli tak jakby go nie było Wymontowałem czujnik sprawdziłem czy kablami dochodzi napięcie (jest 11v) no ale po wciśnięciu go nic się nie dzieje. Wcześniej działał za każdym razem. Da się jakos komunikat z FISa usunąc ?
