Co dolega mojemu exeo ? Logi do analizy
Prośba o analizę błędów
VCDS
Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 Data version: 20130910
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Saturday,10,September,2016,01:23:28:62939
VIN: VSSZZZ3RZBR009427 License Plate: 123
Mileage: 224240km-139336mi Repair Order:
Chassis Type: 3R (3R - Seat Exeo (2010 >))
Scan: 01 02 03 08 09 10 15 16 17 25 37 36 45 46 4C 55 56 77
VIN: VSSZZZ3RZBR009427 Mileage: 224240km/139336miles
Address 01: Engine (J623-CAGC) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 019 DE HW: 03L 906 022 GE
Component: R4 2,0L EDC H10 7084
Revision: 11H10--- Serial number:
Coding: 0304002C18072920
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_ECM20TDI03L906019DE A01002
ROD: EV_ECM20TDI03L906019DE.rod
VCID: 71E9334FA05CC1966BD-8024
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
Component: ESP8 FRONT H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004401
Shop #: WSC 06441 785 00200
VCID: 2C57E23B8FFEEC7E18B-8079
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BL
Component: A4 Klimaautomat 3233
Coding: 00000
Shop #: WSC 06441
VCID: 6CD7223B1C7E2C7E58B-50E6
VCDS
Self-Diagnosis Log
Page 2
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 11101
Shop #: WSC 05311
VCID: 3D71DF7F378475F6BF5-4A3A
1 Fault Found:
01326 - Control Module for Multi-Function Steering Wheel (J453)
49-10 - No Communications - Intermittent
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 3R0 919 475 HW: 3R0 919 475
Component: PARKHILFE 4K H07 0004
Revision: -------- Serial number: 19731026018393
Coding: 010002
Shop #: WSC 04941 000 00000
VCID: F8FF8E6B4B2610DE2C3-80AD
Address 15: Airbags Labels: 3R0-959-655.clb
Part No SW: 3R0 959 655 HW: 3R0 959 655
Component: 04 Airbag 9.41 H15 0010
Revision: 91H15001 Serial number: 003E90017EBG
Coding: 0012340
VCID: FCF7927BBF1E3CFE48B-80A9
Subsystem 1 - Serial number: 6332DRB40C5D90B4.
Subsystem 2 - Serial number: 6342DRB40C418F10P
Subsystem 3 - Serial number: 6352ARB405C0A58ESubsystem
4 - Serial number: 6362ARB405C0AA04O
Subsystem 5 - Serial number: 63747RB405D05ACB$
Subsystem 6 - Serial number: 63847RB405D05B68W
VCDS
Self-Diagnosis Log
Page 3
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0801
Coding: 03042
Shop #: WSC 06441
VCID: 4189A38F4B7C1116DBD-4A3A
Address 17: Instruments Labels: 3R0-920-xxx-17.clb
Part No SW: 3R0 920 830 H HW: 3R0 920 830 H
Component: KOMBI+WFS 4 H04 0030
Revision: 0030 Serial number: 00000000000000
Coding: 0006118
Shop #: WSC 80093 222 69422
VCID: 3365F94751C0B386591-5072
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0006118
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 3R0 035 192 HW: 3R0 035 192
Component: RNS-E PU EU H05 0220
Revision: 0000011S Serial number: SEZBZ7K6902222
Coding: 0318755
Shop #: WSC 23230 202 90699
VCID: E9D9DB2FC38CB956A3D-5000
VCDS
Self-Diagnosis Log
Page 4
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CL
Component: Komfortgerát T01 4336
Coding: 07024
Shop #: WSC 06441
VCID: 7DF11F7F7704B5F6FF5-4A3A
Subsystem 1 - Part No: 8E1959801G
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0706
Subsystem 3 - Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
VCDS
Self-Diagnosis Log
Page 5
Address 4C: Tire Pressure II Labels: 3R0-907-274.clb
Part No SW: 3R0 907 274 HW: 3R0 907 274
Component: J793 RKA+ H02 0002
Revision: 00000311 Serial number: 00003110352699
Coding: 0000065
VCID: F2EBBC43ED5A7A8E127-80A7
1 Fault Found:
02214 - Tire Pressure Warning
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 6
Mileage: 223921 km
Time Indication: 0
Freeze Frame:
Hex Value: 0x0070
Hex Value: 0x0000
Hex Value: 0x0007
Voltage: 13.70 V
Temperature: 22.0°C
(no units): 65.0
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0318755
z bledow wynika ze siadla Ci multifunkcja w kierownicy. To wszystko
Co rozumiesz przez to za siadła - ja nie zauważyłem jakiegoś braku.
Sterowanie radiem jest, przycisk PTT działa, mode działa.
Piszesz logi do analizy i gdzie one są?
Bo widzę tylko kody błędów.
Jaki masz problem z silnikiem?
