Patryk94 Opublikowano 17 Listopada 2019 Opublikowano 17 Listopada 2019 Kolega ma problem kontrolka check engine. Ma takie błedy: Friday,15,November,2019,21:05:53:39744 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 17.1.3.0 (x64) Data version: 20170203 DS267.2 www.Ross-Tech.com VIN: WAUZZZ4F57N035062 License Plate: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Control Module Part Number: 03G 906 016 GC HW: 03G 906 016 GC Component and/or Version: R4 2,0L EDC G000CG 9887 Software Coding: 0000076 Work Shop Code: WSC 25712 136 85175 VCID: 6ADC19EA45E4A91157-803E 3 Faults Found: 012546 - Motor for Intake Manifold Flap (V157) P3102 - 000 - No Signal - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 1 Fault Frequency: 24 Reset counter: 255 Time Indication: 0 Freeze Frame: RPM: 0 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 12.16 V Bin. Bits: 00101000 Torque: 0.0 Nm Torque: 300.1 Nm 012545 - Motor for Intake Manifold Flap (V157) P3101 - 000 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 11100000 Fault Priority: 1 Fault Frequency: 24 Reset counter: 255 Time Indication: 0 012545 - Motor for Intake Manifold Flap (V157) P3101 - 000 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 1 Fault Frequency: 3 Reset counter: 255 Mileage: 250804 km Time Indication: 0 Date: 2019.11.09 Time: 14:14:39 Freeze Frame: RPM: 1134 /min Speed: 43.0 km/h Load: 0.0 % Voltage: 13.76 V Bin. Bits: 00101000 Torque: 156.2 Nm Torque: 0.0 Nm Readiness: 1 1 0 0 0
Tom A4 Opublikowano 17 Listopada 2019 Opublikowano 17 Listopada 2019 Problem z klapą gaszącą albo sama w sobie jest uszkodzona albo jej połączenie z ecu. Do sprawdzenia wiązka i bezpiecznik.
