grzesiekk23 1 Opublikowano 5 Maja 2009 Udostępnij Opublikowano 5 Maja 2009 Witam. Koledzy czy ktoś powie mi co to za błędy mi wyskoczyły i jakie mogą być tego przyczyny. Tuesday,05,May,2009,15:11:48:59303 VAG-COM Version: Release 704.1 Data version: 20070422 Chassis Type: 8E - Audi A4 B6/B7 Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUZZZ8E36A132932 Mileage: 146570km/91074miles ------------------------------------------------------------------------------- Address 01: Engine Labels: None Part No SW: 03G 906 016 FP HW: 028 101 212 8 Component: R4 2,0L EDC G000SG 9383 Coding: 0000072 Shop #: WSC 31780 1 Fault Found: 000564 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition) P0234 - 000 - - - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 1 Fault Frequency: 1 Mileage: 146201 km Time Indication: 0 Freeze Frame: RPM: 2289 /min Speed: 94.0 km/h Load: 30.6 % Voltage: 13.91 V Bin. Bits: 00101000 Absolute Pres.: 1540.2 mbar Absolute Pres.: 2080.8 mbar Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-910-517.LBL Part No SW: 8E0 910 517 D HW: 8E0 614 517 AK Component: ESP8 front H05 0120 Coding: 0004401 Shop #: WSC 06325 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.LBL Part No: 8E0 820 043 BJ Component: A4 Klimaautomat 2832 Coding: 00000 Shop #: WSC 00000 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.LBL Part No: 8E0 907 279 L Component: int. Lastmodul ECE 0504 Coding: 10001 Shop #: WSC 06325 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-94.LBL Part No SW: 8E0 959 655 G HW: 8E0 959 655 G Component: Airbag 9.41 H11 3530 Coding: 0033622 Shop #: WSC 06325 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.LBL Part No: 8E0 953 549 Q Component: Lenksáulenmodul 0601 Coding: 04042 Shop #: WSC 06325 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8EC.LBL Part No SW: 8E0 920 931 P HW: 8E0 920 931 P Component: KOMBI+WFS 4 H12 0110 Coding: 0006041 Shop #: WSC 23299 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: None Part No: 4B0 919 887 E Component: BNS 4.2 H05 BNO 0060 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MIN.LBL Part No: 8E0 959 433 BP Component: Komfortgerát T85 3332 Coding: 07024 Shop #: WSC 06325 Part No: 8E1959801H Component: Tőrsteuer.FS BRM 0506 Part No: 8E1959802B Component: Tőrsteuer.BF BRM 0205 1 Fault Found: 00955 - Key 1 35-10 - - - Intermittent ------------------------------------------------------------------------------- Address 56: Radio Labels: 8E0-035-1xx-56.LBL Part No: 8E0 035 186 D Component: concert II GRO 0004 Coding: 01075 Shop #: WSC 06325 1 Fault Found: 00858 - Connection; Radio ZF Output to Antenna Amplifier 29-10 - Short to Ground - Intermittent ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 8E0-919-283-8EC.LBL Part No SW: 8E0 919 283 D HW: 8E0 919 283 D Component: Parkhilfe 4-Kan H06 0010 Coding: 0000014 Shop #: WSC 06325 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 8P0-862-335.LBL Part No SW: 8P0 862 335 F HW: 8P0 862 335 F Component: FSE_255x BT H21 0190 Coding: 0011811 Shop #: WSC 06325 No fault code found. End -------------------------------------------------------------------------------------------------- Szukałem po kodach ale niestety nie znalazłem Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
spanky 7 Opublikowano 5 Maja 2009 Udostępnij Opublikowano 5 Maja 2009 1 Fault Found: 000564 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition) P0234 - 000 - - - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 1 Fault Frequency: 1 Mileage: 146201 km Time Indication: 0 Freeze Frame: RPM: 2289 /min Speed: 94.0 km/h Load: 30.6 % Voltage: 13.91 V Bin. Bits: 00101000 Absolute Pres.: 1540.2 mbar Absolute Pres.: 2080.8 mbar przeladowanie turbulum ... [w dynamicznych bedzie lepiej widac ] Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Patrox 3 Opublikowano 5 Maja 2009 Udostępnij Opublikowano 5 Maja 2009 Turbo do czyszczenia albo zawór N75. Ty masz 2,0 8v z DPF Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
grzesiekk23 1 Opublikowano 5 Maja 2009 Autor Udostępnij Opublikowano 5 Maja 2009 Tak 8V z DPF. Hmm... nie wiem czy ma to coś wspólnego z tymi błędami ale tak ok 300 km wcześniej silnik wszedł w tryb awaryjny po tym jak załączył się DPF zagapiłem się i wrzuciłem 6-bieg wtedy auto weszło w tryb awaryjny. Po zatrzymaniu się i odpaleniu wszystko wróciło do normy i DPF zregenerował się już w odpowiednich warunkach do dnia dzisiejszego bez problemu (DPF regenerował mi się wczoraj ) Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
remus_kraków 0 Opublikowano 19 Lipca 2011 Udostępnij Opublikowano 19 Lipca 2011 Tak 8V z DPF. Hmm... nie wiem czy ma to coś wspólnego z tymi błędami ale tak ok 300 km wcześniej silnik wszedł w tryb awaryjny po tym jak załączył się DPF zagapiłem się i wrzuciłem 6-bieg wtedy auto weszło w tryb awaryjny. Po zatrzymaniu się i odpaleniu wszystko wróciło do normy i DPF zregenerował się już w odpowiednich warunkach do dnia dzisiejszego bez problemu (DPF regenerował mi się wczoraj ) u mnie było podobnie. po zgaszeniu i ponownym odpaleniu śmiga bez problemów do dzisiaj. Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
grzesiekk23 1 Opublikowano 27 Lipca 2011 Autor Udostępnij Opublikowano 27 Lipca 2011 I czym to wyleczyłeś? Ustąpiło ? Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
