Witam.
Koledzy czy ktoś powie mi co to za błędy mi wyskoczyły i jakie mogą być tego przyczyny.
Tuesday,05,May,2009,15:11:48:59303
VAG-COM Version: Release 704.1
Data version: 20070422
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E36A132932 Mileage: 146570km/91074miles
Address 01: Engine Labels: None
Part No SW: 03G 906 016 FP HW: 028 101 212 8
Component: R4 2,0L EDC G000SG 9383
Coding: 0000072
Shop #: WSC 31780
1 Fault Found:
000564 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
P0234 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 1
Fault Frequency: 1
Mileage: 146201 km
Time Indication: 0
Freeze Frame:
RPM: 2289 /min
Speed: 94.0 km/h
Load: 30.6 %
Voltage: 13.91 V
Bin. Bits: 00101000
Absolute Pres.: 1540.2 mbar
Absolute Pres.: 2080.8 mbar
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.LBL
Part No SW: 8E0 910 517 D HW: 8E0 614 517 AK
Component: ESP8 front H05 0120
Coding: 0004401
Shop #: WSC 06325
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Part No: 8E0 820 043 BJ
Component: A4 Klimaautomat 2832
Coding: 00000
Shop #: WSC 00000
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.LBL
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0504
Coding: 10001
Shop #: WSC 06325
Address 15: Airbags Labels: 8E0-959-655-94.LBL
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H11 3530
Coding: 0033622
Shop #: WSC 06325
Address 16: Steering wheel Labels: 8E0-953-549.LBL
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 04042
Shop #: WSC 06325
Address 17: Instruments Labels: 8E0-920-9xx-8EC.LBL
Part No SW: 8E0 920 931 P HW: 8E0 920 931 P
Component: KOMBI+WFS 4 H12 0110
Coding: 0006041
Shop #: WSC 23299
Address 37: Navigation Labels: None
Part No: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0060
Address 46: Central Conv. Labels: 8E0-959-433-MIN.LBL
Part No: 8E0 959 433 BP
Component: Komfortgerát T85 3332
Coding: 07024
Shop #: WSC 06325
Part No: 8E1959801H
Component: Tőrsteuer.FS BRM 0506
Part No: 8E1959802B
Component: Tőrsteuer.BF BRM 0205
1 Fault Found:
00955 - Key 1
35-10 - - - Intermittent
Address 56: Radio Labels: 8E0-035-1xx-56.LBL
Part No: 8E0 035 186 D
Component: concert II GRO 0004
Coding: 01075
Shop #: WSC 06325
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
29-10 - Short to Ground - Intermittent
Address 76: Park Assist Labels: 8E0-919-283-8EC.LBL
Part No SW: 8E0 919 283 D HW: 8E0 919 283 D
Component: Parkhilfe 4-Kan H06 0010
Coding: 0000014
Shop #: WSC 06325
Address 77: Telephone Labels: 8P0-862-335.LBL
Part No SW: 8P0 862 335 F HW: 8P0 862 335 F
Component: FSE_255x BT H21 0190
Coding: 0011811
Shop #: WSC 06325
End --------------------------------------------------------------------------------------------------
Szukałem po kodach ale niestety nie znalazłem
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 146201 km
Time Indication: 0
Freeze Frame:
RPM: 2289 /min
Speed: 94.0 km/h
Load: 30.6 %
Voltage: 13.91 V
Bin. Bits: 00101000
przeladowanie turbulum ... [w dynamicznych bedzie lepiej widac :wink4:]
Turbo do czyszczenia albo zawór N75. Ty masz 2,0 8v z DPF
Tak 8V z DPF.
Hmm... nie wiem czy ma to coś wspólnego z tymi błędami ale tak ok 300 km wcześniej silnik wszedł w tryb awaryjny po tym jak załączył się DPF zagapiłem się i wrzuciłem 6-bieg wtedy auto weszło w tryb awaryjny. Po zatrzymaniu się i odpaleniu wszystko wróciło do normy i DPF zregenerował się już w odpowiednich warunkach do dnia dzisiejszego bez problemu (DPF regenerował mi się wczoraj )
  • 2 lata później...
Tak 8V z DPF.
u mnie było podobnie. po zgaszeniu i ponownym odpaleniu śmiga bez problemów do dzisiaj.
