max0107 Opublikowano 5 Lipca 2009 Opublikowano 5 Lipca 2009 koledzy powiedzcie czy to poprawnie zrobiony log, czy coś w nim nie tak ? Błędy: Chassis Type: 8D - Audi A4 B5 Scan: 01,02,03,08,15,17,25,35,45,55,56 ------------------------------------------------------------------------------- Address 01: Engine Controller: 038 906 019 BR Component: 1,9l R4 EDC 0000SG 1064 Coding: 00002 Shop #: WSC 06325 1 Fault Found: 18057 - Powertrain Data Bus: Missing Message from ABS Controller P1649 - 35-00 - - Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Controller: 8E0 614 111 AH Component: ABS/ASR 5.3 FRONT D10 Coding: 00012 Shop #: WSC 06435 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Controller: 8D0 820 043 P Component: A4 KLIMAAUTOMAT D57 Coding: 00043 Shop #: WSC 06325 No fault code found. ------------------------------------------------------------------------------- Skipping Address 15-Airbags ------------------------------------------------------------------------------- Address 17: Instruments Controller: 4B0 920 900 CX Component: C5-KOMBIINSTR. VDO D11 Coding: 00160 Shop #: WSC 00054 ˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙ AUZ7Z0Y1560387 1 Fault Found: 00668 - Supply Voltage Terminal 30 53-10 - Supply Voltage Too Low - Intermittent ------------------------------------------------------------------------------- Address 25: Immobilizer Controller: Bit teA dre ssu Component: e 17 eingeben No Faults Found or DTCs not supported by controller or a communication error ocurred ------------------------------------------------------------------------------- Address 35: Centr. Locks Controller: 8D0 862 257 C Component: ZV-Pumpe D12 Coding: 02123 Shop #: WSC 30011 1 Fault Found: 00991 - Interior Lights 28-00 - Short to B+ ------------------------------------------------------------------------------- Address 56: Radio Controller: 8D0 035 195 Component: Radio D00 Coding: 00201 Shop #: WSC 06325 No fault code found. End --------------------------------------------------------------------------------------------------
truckmaniac Opublikowano 5 Lipca 2009 Opublikowano 5 Lipca 2009 Grupy robimy pojedynczo, żeby oczopląsu nie dostać
antonio Opublikowano 5 Lipca 2009 Opublikowano 5 Lipca 2009 brakuje dynamicznych i BS na dodatek logi nie pełne brak jeszcze wielu grup
spanky Opublikowano 6 Lipca 2009 Opublikowano 6 Lipca 2009 http://www.a4-klub.pl/smf/tdi_diagnostyka_aktualizacja_30_vii_2008-t18478.0.html
