[B6 AMB] Błędy do sprawdzenia
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 8E0 909 518 F
Component: 1.8L R4/5VT G 0001
Coding: 0016701
Shop #: WSC 63351
19 Faults Found:
17511 - Oxygen (Lambda) Sensor Heating: B1 S1: Performance too Low
P1103 - 008 - Implausible Signal - Intermittent
17951 - Angle Sensor 1 for Throttle Actuator (G187): Signal too Small
P1543 - 002 - Lower Limit Exceeded - Intermittent
17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
P1172 - 002 - Lower Limit Exceeded - Intermittent
16497 - Intake Air Temp. Sensor (G42): Signal too High
P0113 - 002 - Lower Limit Exceeded - Intermittent
17987 - Throttle Actuator (J338): Adaptation Not Started
P1579 - 001 - Upper Limit Exceeded - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 002 - Lower Limit Exceeded - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - Implausible Signal - Intermittent
16687 - Cylinder 3 Misfire Detected
P0303 - 001 - Upper Limit Exceeded - Intermittent
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 008 - Implausible Signal - Intermittent
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 002 - Lower Limit Exceeded - Intermittent
17939 - Camshshaft Timing Adjustment: Open Circuit
P1531 - 004 - No Signal/Communication - Intermittent
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 004 - No Signal/Communication - Intermittent
16685 - Cylinder 1 Misfire Detected
P0301 - 008 - Implausible Signal - Intermittent
16686 - Cylinder 2 Misfire Detected
P0302 - 008 - Implausible Signal - Intermittent
16522 - Oxygen (Lambda) Sensor B1 S2: Signal too High
P0138 - 001 - Upper Limit Exceeded - Intermittent
16840 - EVAP System: Very Small Leak Detected
P0456 - 002 - Lower Limit Exceeded
17978 - Engine Start Blocked by Immobilizer
P1570 - 008 - Implausible Signal - Intermittent
17658 - Fuel Level too Low
P1250 - 008 - Implausible Signal
Readiness: 0000 0000
witam co sądzicie o tych błedach
jestem w tym zielony
pozdro
Witam
Proponuję wykasowanie błędów i ponowne sczytanie po przejechaniu kilkudziesięciu kilometrów.
  • 2 miesiące temu...
Witam praktycznie wszystkich tamtych błędach nie ma śladu natomiast teraz co jakieś 300km wyskakuje mi taki błąd
powiedzcie mi co to jest i gdzie szukać przyczyny tego błędu, chodzi o jakąś małą nieszczelność ale gdzie czego i jak,
Bardzo proszę o pomoc i z góry dziękuję.
PS. Mam małą nieszczelność w dolocie do turbiny, zakleiłem ale nie wiem na ile skutecznie czy ten błąd dotyczy właśnie tej nieszczelności ??
