[ALL B5] Licznik 1/2 FIS, rozpiska pinów
Witam koledzy.
Poszukuje schematu podłaczenia licznika 1/2 FIS z 2000r
Chodzi o rozpiske pinów w tym liczniku. 2 wtyczki x 32pin
:szukaj::wallbash:
cytuję z tematu http://www.a4-klub.pl/smf/all_b5_efekt_wymiany_licznika_na_fis-t10354.120.html#quickreply
Ja sie niezle naszukalem , wiec teraz sie z innymi podziele :decayed: mam nadzieje ze sie przyda :good::hi:
Licznik po 2000 r.
connector for basic functions, 32-pin, blue
1 -Terminal 15
2 -Wear of brake pads
3 -Speedometer output 1
4 -not used
5 -Fuel gauge sender
6 -Fuel gauge warning OBD 2
7 -Terminal 31 (sensor earth)
8 -Coolant temperature
9 -Terminal 31 (load earth)
10 -Oil pressure 2 (high)
11 -Engine-speed signal
12 -Air conditioner shutoff
13 -Electronic throttle/ pre-glow control
14 -Self-levelling suspension
15 -Terminal 58d
16 -Trailer turn signal
17 -Main beam
18 -Left turn signal
19 -not used
20 -Terminal 58s
21 -Door contact, driver's side
22 -Low coolant level
23 -Terminal 30
24 -Terminal 31 (load earth)
25 -Consumption signal
26 -Right parking light
27 -Left parking light
28 -Speedometer input
29 -Brake
30 -S-contact
31 -Speedometer output 2
32 -ESP/TCS
connector for additional functions, 32-pin, green
1 -Door contact (all doors)
2 -Transponder 1
3 -not used
4 -not used
5 -W wire
6 -Tailgate
7 -Right turn signal
8 -External buzzer
9 -External gong
10 -Airbag
11 -Service life output
12 -Terminal 61
13 -Parking brake
14 -CHECK
15 -Oil level / temperature
16 -not used
17 -Transponder 2
18 -CAN high speed (drive) (high +)
19 -CAN high speed (drive) (low -)
20 -CAN high speed (drive) (screen)
21 -ABS
22 -CAN low speed (Convenience) (high +)
23 -CAN low speed (Convenience) (low -)
24 -CAN low speed (Convenience) (screen)
25 -Bonnet
26 -not used
27 -Belt buckle
28 -K wire
29 -Ambient temperature input
30 -not used
31 -Selection range
32 -not used
connector for multifunction display, 32-pin, grey
1 -Switch menu guide (menu)
2 -Switch menu guide (out A)
3 -Switch menu guide (out B)
4 -Switch menu guide (Enter)
5 -CAN high speed Display (high +)
6 -CAN high speed Display (low -)
7 -CAN high speed Display (screen)
8 -Door contact, passenger side
9 -Door contact, rear right
10 -Door contact, rear left
11 -Enable
12 -Clock
13 -Data
14 -Brake light
15 -Washer fluid level
16 -Tail lights/dipped beams
17 -On-board computer, left
18 -On-board computer, right
19 -On-board computer reset
20 -not used
21 -not used
22 -not used
23 -Key branch 1 Navigation system
24 -Key branch 2 Navigation system
25 -Key branch Telematics
26 -not used
27 -not used
28 -not used
29 -not used
30 -not used
31 -not used
32 -not used
Ale ja chciałem od 1/2 Fis A to jest rozpiska od pelnego fisa.
Czy na 1000% jest to samo ???
Do posiadaczy 1/2 Fis. Pokazuje wam koledzy otwarta maske ??
mi maski nie pokazuje :)
i nie będzie pokazywał :cool1:
